Control stick bending
Kellym
PostPosted: Thu Apr 09, 2015 7:28 am    Post subject: Control stick bending Reply with quote
I know some have said they have bent their sticks for panel clearance. I
don't recall seeing any specifics, other than ua hydraulic press.
How much did you need to bend? What did you do to protect the shape of
the tubing?
Any comments on technique, how hard to bend, how to prevent weakening
the tubing would be appreciated.
I have Tosten grips and Aerosport carbon fiber panel, along with cutting
stick as much as possible and still be able to secure grips.
I currently only have 20 degrees of nose down travel when stick grips
hit panel.
Kelly
Been finishing forever.
Kelly McMullen
KCHD
rv10flyer(at)live.com
PostPosted: Thu Apr 09, 2015 7:57 am    Post subject: Control stick bending Reply with quote
I did mine freehand with a rubber mallet. I wouldn’t bother doing it again,
there is no way you should ever need to push the stick so far forward that
you'll hit the panel. Vans demo plane uses the stick as sent, as a
reference. I would consider bending the stick a slight side bend to
accommodate the angle you hold the stick.
flysrv10(at)gmail.com
PostPosted: Thu Apr 09, 2015 8:56 am    Post subject: Control stick bending Reply with quote
I shortened my stick to compensate for the hight of the grip and it works good.
Do not archive.
[quote] On Apr 9, 2015, at 11:53 AM, Pascal <rv10flyer(at)live.com> wrote:
I did mine freehand with a rubber mallet. I wouldn’t bother doing it again, there is no way you should ever need to push the stick so far forward that you'll hit the panel. Vans demo plane uses the stick as sent, as a reference. I would consider bending the stick a slight side bend to accommodate the angle you hold the stick.
tomhanaway
PostPosted: Thu Apr 09, 2015 10:24 am    Post subject: Control stick bending Reply with quote
When I did my 10, I got a pipe bender from harbor freight. Packed the tube with sand to prevent any kinks.
Worked fine
Tom h
[quote] On Apr 9, 2015, at 12:53 PM, Rob Kermanj <flysrv10(at)gmail.com> wrote:
Do not archive.
RV-10. Built and sold
RV-8a. Building
Kellym
PostPosted: Thu Apr 09, 2015 11:46 am    Post subject: Control stick bending Reply with quote
Thank you. That makes the most sense to me. As I said, I already
shortened as much as possible. HF has on sale right now.
I want the clearance as much to protect the switches and knobs(and my
knuckles as to meet the nose down travel spec.
Worked fine
Tom h
> Do not archive.
Kelly McMullen
KCHD
Lenny Iszak
PostPosted: Thu Apr 09, 2015 5:24 pm    Post subject: Re: Control stick bending Reply with quote
Or you can use shorter grips. I got them from a guy in New Zealand, and they clear the panel just fine without any bending of the stick. They look a bit similar to the Infinity grips, just less buttons. They are ambidextrous.
http://www.compositesinternational.co.nz/gallery/
You are probably far down the path to bending the stick Smile but just for future reference...
Lenny
 Filesize:  98.26 KB
 Viewed:  10573 Time(s)
rv10free2fly(at)yahoo.com
PostPosted: Thu Apr 09, 2015 11:12 pm    Post subject: Control stick bending Reply with quote
Guys as an ex-plumber, the sand idea gives the perfect support to prevent kinking. Use dry send and pack well
Warm regards
Patrick
[quote] On 10 Apr 2015, at 03:50, Tomhanaway <tomhanaway1(at)gmail.com> wrote:
Worked fine
Tom h
> Do not archive.
flying-nut(at)cfl.rr.com
PostPosted: Fri Apr 10, 2015 4:14 am    Post subject: Control stick bending Reply with quote
Sugar works better for me in most instances. Much easier to clean out
with some water and if there is any residue left it isn't as abrasive as
sand.
Linn
Warm regards
Patrick
> Worked fine
> Tom h
> Sent from my iPad
>> Do not archive.
bill.peyton
PostPosted: Fri Apr 10, 2015 5:02 am    Post subject: Re: Control stick bending Reply with quote
I have the Aerosport Panel and did not have to bend the stick. What I did was to cut the lower end as short as possible to leave enough straight left to slide into and fully engage into the lower attachment joint. I trimmed the top as short as possible so the holding when the grip my arm would be able to relax on my leg.
 Filesize:  126.97 KB
 Viewed:  10550 Time(s)
WA0SYV
Aviation Partners, LLC
