Better than Seafoam?
Richard Pike
PostPosted: Mon Apr 06, 2015 2:20 pm    Post subject: Better than Seafoam? Reply with quote
Cleaning out the rings & ring lands on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it.
Scraped a bit, and then just for the heck of it, shot the head with some PB Blaster. WOW! That stuff dissolves soft carbon like crazy. Let it sit for a while, wiped it off with a paper towel. Went online and researched it, saw some posts where other people had good results, but one post said to keep it away from seals, it can make them swell.
Packed the base of the pistons with shop rags, drenched the rings and piston lands with the stuff, letting it sit overnight. Will post again tomorrow. But I did see dissolving carbon running down the sides of the pistons. That would seem to be a good sign.
But unlike Seafoam, I really don't see putting this stuff in the gas tank.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
rowedenny
PostPosted: Mon Apr 06, 2015 4:59 pm    Post subject: Better than Seafoam? Reply with quote
PB Blaster is the best liquid wrench I've ever used. Breaks loose unbelievably tough rusted bolts and even galled threads.
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
On Apr 6, 2015, at 6:20 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Cleaning out the rings on the 582, it's been a while, and the lower one was stuck on one side near the locator pin, both pistons. Scraped and scraped, looked pretty good, put the rings back in and was not real happy, Still sticking a little bit on that same side. Went to scrape some carbon off the underside of the head and think about it.
Richard Pike
Kingsport, TN 3TN0
There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.'
http://forums.matronics.com/viewtopic.php?p=440341#440341
George Alexander
PostPosted: Mon Apr 06, 2015 5:16 pm    Post subject: Re: Better than Seafoam? Reply with quote
Richard:
Maybe you can convince the mfg to add wordage to the label, right alongside the statement about fixing leaky toilets. 8>)
I agree with Dennis, it's good stuff.
Dennis "Skid" Rowe
On Apr 6, 2015, at 6:20 PM, Richard Pike <thegreybaron> wrote:
. . . S N I P . . .
. . . S N I P . . .
Richard Pike
Kingsport, TN 3TN0
Very Happy
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
zeprep251(at)aol.com
PostPosted: Tue Apr 07, 2015 1:25 pm    Post subject: Better than Seafoam? Reply with quote
Had a chance to experiment on some old lawnmower engine cylinder heads
Sea foam PB blaster carb cleaner. Not much gets after hard carbon
Dennis "Skid" Rowe
Mk3, Rotax 670,
Leechburg, PA
> Richard Pike
> Kingsport, TN 3TN0
Richard Pike
PostPosted: Wed Apr 08, 2015 5:29 am    Post subject: Re: Better than Seafoam? Reply with quote
Let it soak the rings & grooves overnight, helped a little. My conclusion: it works great on soft carbon, not as much on hard carbon, still better than nothing.
OTOH, Seafoam only has one purpose, and if it doesn't clean the carbon off your pistons and rings, it is pointless. PB Blaster works great on loosening rusted stuff even if it doesn't clean the carbon off the rings as good as I wish.
Richard Pike
Kingsport, TN 3TN0
GeoB
PostPosted: Thu Apr 09, 2015 2:32 am    Post subject: Re: Better than Seafoam? Reply with quote
Wonder if anyone uses oven cleaner?
GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors"
williamtsullivan(at)att.n
PostPosted: Thu Apr 09, 2015 2:49 am    Post subject: Better than Seafoam? Reply with quote
Oven cleaner? I think that is a great idea! Does anybody have an old piston, and the urge for an experiment? The stuff is definitely designed to remove baked on carbon.
Bill Sullivan
do not archive.
On Thu, 4/9/15, GeoB <gab16(at)sbcglobal.net> wrote:
Subject: Re: Better than Seafoam?
Date: Thursday, April 9, 2015, 6:32 AM
"GeoB" <gab16(at)sbcglobal.net>
little.
GeoB
&quot;Members of Congress should be compelled to wear
corporate sponsors&quot;
http://forums.matronics.com/viewtopic.php?p=440483#440483
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
ceengland7(at)gmail.com
PostPosted: Thu Apr 09, 2015 9:56 am    Post subject: Better than Seafoam? Reply with quote
On April 9, 2015 6:43:52 AM EDT, william sullivan <williamtsullivan(at)att.net> wrote:[quote] [quote]--> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net> Oven cleaner? I think that is a great idea! Does anybody have an old piston, and the urge for an experiment? The stuff is definitely designed to remove baked on carbon. Bill Sullivando not archive.On Thu, 4/9/15, GeoB <gab16(at)sbcglobal.net> wrote: Subject: Re: Better than Seafoam? To: kolb-list(at)matronics.com Date: Thursday, April 9, 2015, 6:32 AM --> Kolb-List message posted by: "GeoB" <gab16(at)sbcglobal.net> Richard Pike wrote:
little. Wonder if anyone uses oven cleaner?[b]
For rust, a 50-50 mix of acetone & ATF is pretty impressive (and inexpensive).
Sent from my Android device with K-9 Mail. Please excuse my brevity. [quote][b]
PostPosted: Thu Apr 09, 2015 11:45 am    Post subject: Better than Seafoam? Reply with quote
Just the opposite of Charlie E's less expensive "stuff" is Kroil by KANO Labs in Nashville, TN.  This stuff is expensive, but works better than anything I have tried over the years for loosening stuck stuff.
They have an air tight guarantee to give you back your money if you, at any time, are dissatisfied with their product.
Don't let the prices scare you.  It works well.
http://www.kanolabs.com/penLub.html
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Thursday, April 09, 2015 12:56 PM
Subject: Re: Re: Better than Seafoam?
On April 9, 2015 6:43:52 AM EDT, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
--> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)>  Oven cleaner?  I think that is a great idea!  Does anybody have an old piston, and the urge for an experiment?  The stuff is definitely designed to remove baked on carbon.                                                  Bill Sullivando not archive.On Thu, 4/9/15, GeoB <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)> wrote: Subject: Re: Better than Seafoam? To: kolb-list(at)matronics.com (kolb-list(at)matronics.com) Date: Thursday, April 9, 2015, 6:32 AM  --> Kolb-List message posted by: "GeoB" <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>   Richard Pike wrote: Let it soak the rings & grooves overnight, helped a little.   Wonder if anyone uses oven cleaner?<![if !supportLineBreakNewLine]><![endif]>For rust, a 50-50 mix of acetone & ATF is pretty impressive (and inexpensive).<![if !supportLineBreakNewLine]><![endif]><![if !supportLineBreakNewLine]><![endif]>Charlie<![if !supportLineBreakNewLine]><![endif]>-- <![if !supportLineBreakNewLine]><![endif]>
5
6
7
8
9
5
crad238(at)suddenlink.net
PostPosted: Thu Apr 09, 2015 2:51 pm    Post subject: Better than Seafoam? Reply with quote
I think oven cleaner contains caustic soda ( lye). It dissolves
aluminum. Very important to test first. Could test on any piece of
aluminum
Carl Radcliffe
Jim Baker
PostPosted: Thu Apr 09, 2015 3:55 pm    Post subject: Better than Seafoam? Reply with quote
For what it's worth. Machinists often have to deal with some nasty situations. At
least this article has some numbers, not just preferences or claims. Saw this
some time ago -
____________________________________________
I read a post on another website that said that an April/May 2007 edition of
Machinist's Workshop did a study on penetrating oils to see which was the best
at freeing rusted hardware. The results are indicated below:
Penetrating oil . Average breakaway load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
According to this, a 50/50 mixture of Acetone and ATF was the best. Also,
someone mentioned that "CRC Freeze-Off Super Penetrant" was pretty good
with stuck bolts as the freezing effect tends to crack rusted surfaces.
_________________________________________________
Secondary source -
http://www.saturnfans.com/forums/showthread.php?t=168033
To: <kolb-list(at)matronics.com>
Subject: RE: Re: Better than Seafoam?
Date sent: Thu, 9 Apr 2015 14:44:43 -0500
Send reply to: kolb-list(at)matronics.com
Oven cleaner?
Bill Sullivan
do not archive.
little.
- The Kolb-List Email Forum -
--> http://www.matronics.com/Navigator?Kolb-List
--> http://forums.matronics.com
Thank you for your generous support!
--> http://www.matronics.com/contribution
Jim Baker
Sayre, PA
405.426.5377 cell
