civengpe
Posted: Thu Apr 09, 2015 4:51 am Post subject: ACS Door Locks |
I tried to install my new, custom ordered door lock yesterday in the baggage door and found that the included cam was too short. When I attempted to use the one I had, I realized that these door locks are "clocked" 45 degrees off of what they would need to be for the cam to be level in the closed position.
The included cam has an 8 point mounting hole that allows it to be clocked to the desired position, but the one I have is square. I called the manufacturer and they do not make a longer cam. Does anyone have a source for longer cams that have an 8 point mounting hole? If not, what has everyone else been doing?
Shannon
rvdave
Posted: Thu Apr 09, 2015 5:08 am Post subject: Re: ACS Door Locks |
I took the square holed cam, cut and welded it to the octagonal cam and bent it to make it work.
_________________ Dave Ford
Cadillac, MI |
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Thu Apr 09, 2015 5:08 am Post subject: ACS Door Locks |
I believe my kit from Vans came with a long cam for this purpose.
On Thu, Apr 9, 2015 at 8:48 AM, Shannon Hicks <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote:
[quote]I tried to install my new, custom ordered door lock yesterday in the baggage door and found that the included cam was too short. When I attempted to use the one I had, I realized that these door locks are "clocked" 45 degrees off of what they would need to be for the cam to be level in the closed position.
Shannon
tp://forums.matronics.com
| [b]
bruce.hoppe(at)yahoo.com Guest
Posted: Thu Apr 09, 2015 6:17 am Post subject: ACS Door Locks |
civengpe
Posted: Thu Apr 09, 2015 7:25 am Post subject: ACS Door Locks |
Because the cutout is square in the Vans supplied cam, It will not rotate properly. When the lock is installed in the door, it is off by 45 degrees. The only way I can see making it work is to modify the square opening to an 8 point opening. Attached is a crude drawing of what is happening.
Shannon
On Thu, Apr 9, 2015 at 8:08 AM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=440489#440489
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
79.76 KB |
10448 Time(s) |
Jim Berry
Posted: Thu Apr 09, 2015 9:13 am Post subject: Re: ACS Door Locks |
A locksmith or HD can fix you up with the correct latch.
bhoppe2
Joined: 09 Apr 2015 Posts: 15 Location: Nolensville, TN
Posted: Thu Apr 09, 2015 4:41 pm Post subject: Re: ACS Door Locks |
I agree with William. Vans included a longer cam that replaces the one that comes with the lock. I ended up making one so that I could embed a disk magnet in it and then installed a reed switch in the door jamb. That switch is hooked in series with the passenger door switches. All 5 switches are hooked in series, 2 per passenger and one on the luggage door. Therefore, if any door is not latched, I get an indicator on my panel telling me, just not which one. i bought both the magnet and switch from Amazon.
Bruce Hoppe
266.81 KB |
10408 Time(s) |
_________________ Bruce Hoppe |
