millner(at)me.com Guest
Posted: Thu Apr 02, 2015 1:25 pm Post subject: Dimmers driving displays |
At 10:57 2015-04-02, you wrote:
>> What's the lowest parts count solution to this design goal
A switch on the back of the dimmer pot... when you go full dim, it switches
bus voltage to the electronic displays.
Can't take credit; Cessna thought of it first!
Ahhh . . . that recalls the switch on the
back of the dimmer pot in some Pipers
that automatically turned on position lights
when the panel lights were brought up.
Nice take. The switchs at the CCW end of
pots tend to go open at max travel, so
you still have to add some electro-beans
to invert the sense.
fly4grins(at)gmail.com Guest
Posted: Fri Apr 03, 2015 5:45 am Post subject: Dimmers driving displays |
How are others solving this problem? I am trying to avoid having 17 dimmer controls.
Thoughts?
Andy
See: http://www.periheliondesign.com/egpavr.htm
IIRC, the incorporated switch is SPDT, so the OFF function can be made an ON function.
Check with Eric; I'm surprised he's not chimed in yet...
yellowduckduo(at)gmail.co Guest
Posted: Fri Apr 03, 2015 7:13 am Post subject: Dimmers driving displays |
Trutrak did this automatically as my ADI goes full bright when the
pre-existing dimmer circuit is off which seems to be what you want in
order to keep the post lights off during the day.
There are ways to trigger a 12 volt relay when the dimmer voltage is
minimum. I'd probably look at using an even cheaper Mosfet transistor
instead of the relay but a relay is simple. You could feed the coil
with a comparator circuit that turns on at any dimmer voltage you wish.
An ic comparator (or any op amp) could do that with a couple of
resistors added. Or a transistor and zener diode setup somewhat similar
to what triggers the OVM module would also do it. A couple of dollars
plus a relay and shipping if you don't have parts on hand but packaging
it is more awkward than just adding another switch. Stick it in a
plastic pill box and tie it to existing wires or something would work.
I actually like lots of dimmer controls to allow precise harmonizing
various intensities. Some commercial aircraft do indeed have 17 dimmer
controls. Switches are dead simple to troubleshoot and maintain.
Ken
On 03/04/2015 9:42 AM, GLEN MATEJCEK wrote:
17 dimmer controls.
Thoughts?
Andy
an ON function.
