rnjcurtis(at)charter.net Guest
Posted: Thu Apr 02, 2015 12:13 pm Post subject: AeroElectric-List: Re: Dimmers driving displays... |
| Quote: | --> AeroElectric-List message posted by: "andymeyer" <ameyer(at)mil-amax.com>
No switched side of that dimmer knob... It's simply a pot - it may go open when all of the way dim - not sure... I'd rather not change out the pot - something simple and inline to the two instruments would be ideal. I thought about a low pull-in voltage relay, but pull-in would have to be at a couple of volts and very low current and rated for continuous duty at 14 volts, and still very low current.
| Quote: | Do the lights not go to full brightness when the pot is turned clockwise to the stop? If they, indeed, do go full brightness then I would suggest that if you do need the lights on during daytime ops, then crank it full CW.
Roger
