Posted: Wed Apr 01, 2015 10:31 am Post subject: Single fuse for two fuel guages only |
I have been doing some rearranging of the wiring and circuit protection in my 6A.
I found my two fuel guages ( Vans IE-VFL-15) wired directly to the starter power input on the key switch (I must have been lazy that day). The documentation calls for 18AWG wiring for this circuit - but does not specify circuit protection sizing. I am thinking a 3 amp fuse should allow sufficient current and provide protection for the wiring.
Thoughts please!
Ralph Capen
gilles.thesee(at)free.fr Guest
Posted: Thu Apr 02, 2015 1:40 am Post subject: Single fuse for two fuel guages only |
Le 01/04/2015 20:30, Ralph E. Capen a écrit :
Ralph,
I'm not sure which wire is 18 AWG in your circuit (starter input ? fuel
pump wire ?), but this table maybe of some use :
http://contrails.free.fr/elec_fil_section.php
It shows current ratings against wire gauge.
FWIW,
Best regards,
Gilles
Posted: Thu Apr 02, 2015 7:29 am Post subject: Single fuse for two fuel guages only |
At 13:30 2015-04-01, you wrote:
<recapen(at)earthlink.net>
Your perception is not in error. But why change it?
It's only a venial sin to power multiple appliances
from a single protected tap on the bus. The rule of
thumb calls for evaluating risks to the aircraft or
occupants should ALL appliances un the group become
unavailable due to single fault.
You need to make your own assessment but I suggest
that your time-of-flight is the back-up predictor
of fuel quantity. Given the exceedingly rare event
that ANY protective device will be called upon to
operate over the lifetime of your airplane, it's
an exceedingly low-risk condition to leave it wired
as-is.
Posted: Thu Apr 02, 2015 7:51 am Post subject: Single fuse for two fuel guages only |
Bob,
As always, the common-sense of your insight returns me to reality!
Yes, time-of-flight and a fuel-flow meter are also available....
in the event of an in-flight failure.
Additionally, if the circuit had failed 'post-previous-flight',
I would not be able to start the engine for an upcoming flight.
Ralph
