morid(at)northland.lib.mi Guest
Posted: Fri Jun 30, 2006 12:43 pm Post subject: speed and drag reduction |
Kurt, assuming your airspeed is accurate, something is definitely wrong.
The Kitfox5 should be easily capable of 105kt cruise with the power you
have. Something appears to be holding you back. My S5 with 100hp normally
aspirated NSI cruises about 94kts at 4gph, 22" MP, and 3900 rpm which isn't
really working very hard. Maybe just more drag reduction is what you need?
Those flaperons can add a bunch of drag if they're set too low. Do you have
wheel pants? They're good for a couple knots. Lots of little cleanup
things help too like the fuel caps, jury struts, stab struts, etc.
My personal opinion is that weight and drag reduction are the things to put
the most work into if you want an efficient airplane.
Deke
| Quote: | The first 85 knots is easy for me, but the next 15 to
25 is a struggle. I have to check, but I think I top
out around 109 kts now at more than twice the fuel
flow of 85 kts.
I am wondering if my flapperons might be adjusted a
little too low and could use a few degrees up? Other
list members said they make a big difference. I sure
know the first notch makes 70 kts (max flap speed)
almost as draggy as 85 kts clean.
Or it may be my prop, like I said.
Kurt S.
--- John Anderson <janderson412(at)hotmail.com> wrote:
> Yep, I did this too, added a profiled leading edge
> to start of the vert stab
> to split the flow. Guess it all helps for as I've
> said, up to 100kts is
> relatively easy. Hopefully after increasing the prop
> pitch and get the boost
> up a bit at lower RPM I might get a wee bit
> more..John
Posted: Sun Jul 02, 2006 12:54 pm Post subject: speed and drag reduction |
That is what I think to Deke.
I checked my ASI and it was within 2 knots. That
might have changed a little with the scoop added
because it disturbes the airflow differently behind it
compared to the raw radiator.
I would sure like to see 105 knots at around 4 GPH. I
burn 5 GPH to get 85 now. But I purposely started
with no siginificant drag reductions on the plane. I
wanted to see what each would do as I add them and
report that. Still have a lot to go.
Library is closing. Got to go.
Kurt S.
--- Fox5flyer <morid(at)northland.lib.mi.us> wrote:
| Quote: | Kurt, assuming your airspeed is accurate, something
is definitely wrong......
janderson412(at)hotmail.c Guest
Posted: Sun Jul 02, 2006 8:55 pm Post subject: speed and drag reduction |
Could be quite a lot of drag created at the back end of the radiator. I'm
sure the air behind mine isn't happy as at higher speeds there is quite a
buffeting vibration, I had an exit cowl but it cracked so raw in that area
at the moment but intend to build another. John
<smokey_bear_40220(at)yahoo.com>
Kurt S.
