LarryRosen
Posted: Fri Mar 27, 2015 7:08 am Post subject: Relays |
I need some help from the experts. Digi-key has over 13,000 different
power relays over 2 amps, and selecting one, for a novice like me, is a
daunting task.
The relay is for the e-bus battery feed on a 14 volt system. The load
is currently 12 amps, but I have been challenged to better define my
electrical design objects and possibly reduce the load down to 8 amps.
I don't think that will change the relay selection if I were to use a
design of 5-20 amps.
I selected TE Connectivity 1432793-1 Automotive relay SPDT 30A 12V. Here
is the link
<http://www.digikey.com/product-detail/en/1432793-1/PB1773-ND/1236843>
It is non latching with a diode across the coil. Some of the specs,
however, have me confused.
The Coil voltage is 12VDC but the Switching voltage is 14 VDC - Nom. Is
this an issue?
Also the Turn On Voltage (Max) is 7.8 VDC and Turn Off Voltage (Min) 1.2
Volts. Does this mean that the coil requires 7.8 volts to latch and it
will un-latch if voltage drops below 1.2 volts?
I see that most of the automotive relays have high ohm resistors across
the coil, or nothing across the coil. When would you select a resistor,
diode or nothing?
I have another need for a relay in my airplane. My EFIS remote
annunciation mute requires a contact to be close via 2 terminals via a
momentary switch. The vendor does not specify a current requirement for
the switch, and when I contacted them they said any switch would work is
is a fraction of an amp. I would mute the EFIS with one of the buttons
on my control stick, however my control stick only has a common ground,
so all switches close to ground. This would not work for the remote mute.
Is there any reason why a relay wouldn't work?
Would the relay above work? It probably is not the best choice, but it
is only $4 and it would make for common spare parts, so if it would work
it could be my 'best' choice.
Larry
RV-10 Builder
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Fri Mar 27, 2015 8:45 am Post subject: Relays |
I have similar installed in my 6A. That relay will work for both applications. Be careful about the relay activation circuit-ground the correct side.
Sent from my Verizon Wireless 4G LTE smartphone
-------- Original message --------
Date:03/27/2015 09:06 (GMT-07:00)
Subject: AeroElectric-List: Relays
--> AeroElectric-List message posted by: Larry Rosen <n205en(at)gmail.com>
daunting task.
is the link
this an issue?
diode or nothing?
Larry
RV-10 Builder
_-============================================================
_-= - The AeroElectric-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?AeroElectric-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
tim2542(at)sbcglobal.net Guest
Posted: Fri Mar 27, 2015 9:15 am Post subject: Relays |
And you can pick up that relay or this one:
http://www.bandc.biz/spdtsealedrelay12v40a.aspx
at any NAPA store, they're pretty common.
But there must be a better way to control the EFIS, using a relay for that function doesn't seem very elegant. What control stick is it?
[quote] On Mar 27, 2015, at 9:44 AM, Ralph E. Capen <recapen(at)earthlink.net> wrote:
yellowduckduo(at)gmail.co Guest
Posted: Fri Mar 27, 2015 10:08 am Post subject: Relays |
Often when I see two wires like to make some electronic selection I can
trace them back and find out that one is actually a ground.
Ken
On 27/03/2015 1:14 PM, Tim Andres wrote:
| Quote: | And you can pick up that relay or this one:
> the correct side.
> From: Larry Rosen
> To: aeroelectric-list(at)matronics.com
> <mailto:aeroelectric-list(at)matronics.com>
> Subject: Relays
> <n205en(at)gmail.com <mailto:n205en(at)gmail.com>>
> daunting task.
> is the link
> this an issue?
> diode or nothing?
> Larry
> RV-10 Builder
> http://forums.matronics.==========================nbsp; - List
> Contribution
> Wenbsp; &nbf="http://www.matronics.com/contribution">http://www.matronics.com/contrib=======================================
> ky·èžÛ"Í휢Z+ÓM4ÓGÚqç(º¸ž®w°r‹«‰êÓ…à®%yËk‰Ââ²Ñ&j)E¢»¦RDž㶺'‰ËŠËEy«në
> jø jÚ+¶†ë£¶¦j|‹ŠËn¶)b¶'¬²ç!jÂâ²Õ'ý+›±Êâ¦Ø¨œ
> ܆+ÞIæ«rèÂyhiÞÃk k£
> †‹h²«y©Ýšç!šç!šŠÞjÞ~m§ÿðÃ
> š¶º'‰Ë¢oÍjø jÚ+êèWœ¶¸œ.+-†Ûiÿü0Âf®‰ârÇ(›óZ¾(¶ŠÀzº•ç-®'ŠËhÀDãH %„S‘PÄ’jg ær‰íz{Z–ʽ¨¥i¹^¾&…åžlZ+ºk†·Ÿ†Ûiÿ÷è®é¬™«k¢xœ±Ê&†Ûiÿ÷è®é¬™«k¢xœ±Ê&ý¢â²Ð¨žÚânëb¢užm(y8ZžL¨¹ú+Ê‹«éÞ®‹¬²êi¢»LjÛC©ex¸¬´fŠv¡çá¶Úÿ0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨žm§ÿðÃ
> š¶º'‰Ë¢oÜ¢{k‰»Š‰ÿköÿ~‰íþšÞýºËømš
edpav8r(at)yahoo.com Guest
Posted: Fri Mar 27, 2015 1:26 pm Post subject: Relays |
Larry,
Ken's comment about tracing the EFIS mute circuit is a good idea, but be careful. There are two ways this circuit could be designed: input pin internally pulled up or internally pulled down. One method (input pulled up) *should* allow you to use your grip switch directly (assuming the EFIS doesn't use an isolated power supply, which is unlikely), but the other method (input pulled down) requires a relay or switch that's isolated from ship's ground.
I would contact the EFIS manufacturer again and ask specifically if externally grounding one of the pins will work to activate the mute circuit. If so, problem solved -- wire the appropriate pin directly to your grip switch.
If not, and you do need a relay, I can offer this option:
I have a few of these relays...
http://bit.ly/1Nj9UEt
..that were excess from a past project. I'd be happy to put one on a piece of perforated prototype board with a diode and some Tefzel wire leads (labeled!) and mail it to you. If you want it, just email me your address off the forum and I'll get it out to you ASAP.
Eric
| Quote: | On Mar 27, 2015, at 8:06 AM, Larry Rosen <n205en(at)gmail.com> wrote:
I need some help from the experts. Digi-key has over 13,000 different power relays over 2 amps, and selecting one, for a novice like me, is a daunting task.
The relay is for the e-bus battery feed on a 14 volt system. The load is currently 12 amps, but I have been challenged to better define my electrical design objects and possibly reduce the load down to 8 amps. I don't think that will change the relay selection if I were to use a design of 5-20 amps.
I selected TE Connectivity 1432793-1 Automotive relay SPDT 30A 12V. Here is the link <http://www.digikey.com/product-detail/en/1432793-1/PB1773-ND/1236843>
It is non latching with a diode across the coil. Some of the specs, however, have me confused.
The Coil voltage is 12VDC but the Switching voltage is 14 VDC - Nom. Is this an issue?
Also the Turn On Voltage (Max) is 7.8 VDC and Turn Off Voltage (Min) 1.2 Volts. Does this mean that the coil requires 7.8 volts to latch and it will un-latch if voltage drops below 1.2 volts?
I see that most of the automotive relays have high ohm resistors across the coil, or nothing across the coil. When would you select a resistor, diode or nothing?
I have another need for a relay in my airplane. My EFIS remote annunciation mute requires a contact to be close via 2 terminals via a momentary switch. The vendor does not specify a current requirement for the switch, and when I contacted them they said any switch would work is is a fraction of an amp. I would mute the EFIS with one of the buttons on my control stick, however my control stick only has a common ground, so all switches close to ground. This would not work for the remote mute.
Would the relay above work? It probably is not the best choice, but it is only $4 and it would make for common spare parts, so if it would work it could be my 'best' choice.
Larry
RV-10 Builder
LarryRosen
Posted: Fri Mar 27, 2015 2:04 pm Post subject: Relays |
| Quote: | But there must be a better way to control the EFIS, using a relay for
I confirmed with the company and switching to ground is not what they want.
The control sticks are Tosten CS-8
<http://tostenmanufacturing.com/product/cs-8-aircraft-grip/> I really
like the way the feel and I bought them when I was more electrically
naive. My purchase decision may have been different if I knew then what
I know now. Thank you aeroelectric. I am not sure how I am going to
wire the PTT since the PS Engineering audio panel wants the Mic PTT and
Mic Lo switched. Not sure if there is an alternate method or if I need
yet another relay.
Larry
#40356
N205EN (reserved)
<http> |
Bob McC
Posted: Fri Mar 27, 2015 7:14 pm Post subject: Relays |
Larry;
Although you have received some anecdotal responses to your relay question
I'll try to directly answer each of your specific questions.
1: The 30 amp relay you have chosen will safely switch loads from a fraction
of an amp up to its 30 Amp rating, so you are correct in the assumption
that, within reason, your endurance buss load is immaterial to relay choice.
2: A 12V automotive relay is designed to function in the
automotive/vehicular world, therefore any voltage from 9-10 up to 15-16 will
be happily accommodated. Your 14V is not an issue, this is "standard"
vehicular voltage. If you look at the spec sheet for the relay you've chosen
the contacts are rated for 16 volts by the manufacturer.
3: Turn on voltage (max) 7.8 means that if you were to slowly increase the
voltage across the coil from zero that by the time it reached 7.8 the
contacts would have transferred to the on condition. (not latched as you
have stated, this is NOT a latching relay) They might transfer at some value
below 7.8, but will have transferred for sure by 7.8.
4: Turn off voltage (min) 1.2 means that if you were to slowly decrease the
voltage across the coil from the rated 12 volts down to zero, the contacts
would have transferred to the off state by the time the voltage reached 1.2
volts. They might switch off at some level above 1.2 but for sure they will
be off by the time you reach 1.2. (your interpretation of turn on/turn off
voltages is correct, but again this relay does not unlatch by 1.2 volts as
it is not a latching relay. The contacts simply transfer back to the "at
rest" position)
5: I don't see where you found relays with resistors across the coils. They
do exist, but the coil resistance numbers in the Digikey relay tables refer
to the resistance of the coil itself. It is only meaningful with respect to
the amount of current drawn by the coil when energized and if you are using
a 12 volt relay in a 12 volt system it's not something you generally need
worry about. Components added across relay coils such as resistors and
diodes are introduced in an effort to reduce the inductive effects of
turning off the coil. The action of turning off an inductive load (the relay
coil) imposes momentary high voltages (inductive spikes) across the switch
contacts which control the coil causing arcing and possibly reducing the
life of the switch contacts. A resistor provides an alternative path for the
inductive current to dissipate and a diode effectively "shorts" the
inductive current. There are many arguments for each of the methods of
reducing this effect with some advocating diodes as being the most cost
effective solution while others maintain that the slightly increased
switching time caused by the diode is detrimental. Others advocate MOVs,
resistors, or bi-directional zeners, while some suggest nothing is required.
The simple diode installed by some manufacturers, such as the one you've
chosen, seems to be the most widely accepted cost effective method of
mitigating this effect.
6: This relay would "probably" work for your EFIS issue BUT you might
possibly need gold contacts for that application if the current being
switched is low enough. For extremely low currents there is insufficient
arcing to keep silver/tin oxide contacts clean and the oxidation which forms
on them will insulate against very low currents, hence the need for gold
contacts in signal level circuits. ( and no you can't use the gold contacts
for high currents as the arcing will destroy the ultra thin gold plating.)
Hope this somewhat solidifies your understanding of the terminology you've
questioned.
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
LarryRosen
Posted: Fri Mar 27, 2015 8:31 pm Post subject: Relays |
Bob McC,
Thanks, very helpful. It did help solidify my understanding.
Would you help me identify a relay that would be a better choice, or
point me into the right direction. It doesen't look like the automotive
type relays have gold contacts they are designed for high (10A and
above) loads.
Larry
questioned.
Bob McC
#40356
N205EN (reserved)
<http> |
Posted: Sat Mar 28, 2015 12:12 pm Post subject: Relays |
OOPS! I didn't get all the downloads on the thread . . .
You've had some excellent feedback already . . .
The only thing I would add is to not obsess over
contact ratings. If you pull the engineering data
sheets on any of the Digikey offerings, you'll find
that each product's ratings are accompanied with
a service life figure in the tens of thousands of
cycles.
Given that you'll probably fly your airplane no
more than 100 hours/year . . . how many years or
hours of flight are required to impress say 5000
cycles on any of your switches/relays?
Bottom line is that I've replaced far more such devices
that suffered from environmental effects of age and
DISUSE than for failure to observe the manufacturer's
published ratings.
Use anything you can find that is in-expensive and
easy to replace. Suggest you install something like
this.
http://tinyurl.com/qagvybn
I've purchased similar devices for as little as
$2.00 each in hundreds. Given that this is the
ALTERNATE feed path relay, it will get cycled ONCE
per flight so maybe a couple hundred times per year.
Further, its functionality is PREFLIGHT tested thus
limiting its ability to become an undetected latent
failure.
I selected TE Connectivity 1432793-1 Automotive relay SPDT 30A 12V. Here is the link < http://www.digikey.com/product-detail/en/1432793-1/PB1773-ND/1236843 >
Pretty much.
Either resistor or diode is fine . . . I prefer
the diode but again . . . for a few hundred
cycles per YEAR . . . the precise suppression
method is exceedingly un-critical.
This is not a flight-critical functionality. If
I were spec'ing the relay into a TC aircraft,
I would pick something with established reliability
(just to keep the paper shufflers happy). For our
purposes, any "telecom" rated (low current contacts)
like this would do just fine.
http://www.digikey.com/product-detail/en/1461070-5/1461070-5-ND/1427501
The logistical problem with these relays is how
to bolt he little buggers to an airplane. Unlike
the one I cited above, these critters are designed
to solder to an etched circuit board and don't feature
mounting ears of any type.
Probably the easiest thing to do is solder 22AWG
lead wires to the proper 4 pins . . . perhaps install
a coil-suppression diode right on the pins. Pot the
assembly into a 'bolt-able' housing with long-set
epoxy with the wires hanging out. Alternatively,
mount to a perf-board and bring vibration supported
wires off the board. There's no graceful way to do
this. From a production perspective, I've often
considered offering a relay something like this
[img]cid:.0[/img]
http://www.digikey.com/product-detail/en/TQ2SL-12V/255-2853-ND/649407
mounted within one of our stock d-sub housings sorta
like this . . .
[img]cid:.1[/img]
This is one way to incorporate such relays in
a manner that looks more business-like for airplanes.
Also much less prone to failure by reason
of installation shortfall . . .
It IS a bit of a conundrum . . . but know that ratings for
these relays are the least of the issues.
9.95 KB |
22168 Time(s) |
67.23 KB |
22168 Time(s) |
Posted: Sun Mar 29, 2015 12:12 pm Post subject: Relays |
Here's some additional materials that go toward
understanding 'contact science' . . . whether
you're talking about switches or relays. Relays
are just remotely operated switches. The
CONTACTS share the same physics.
http://tinyurl.com/nda9su5
Here's a couple of documents produced by one of the
'granddaddies' of switch and relay business
http://tinyurl.com/ngnjglx
http://tinyurl.com/nenvxrx
Posted: Sun Mar 29, 2015 6:13 pm Post subject: Re: Relays |
Quote from the Tyco paper, | Quote: | | Some relay users connect a diode across the inductive load to prevent counter-voltage from reaching the contacts. . . . While this is an acceptable method of protecting the contacts, it does result in lengthened hold-up time of the inductive load. |
So Bob, this does not contradict the results of your lab experiments (If I remember your posts correctly.) that demonstrate that arc suppression diodes delay opening of relay contacts, but do not cause the contacts to open slower once they start opening. A hold-up delay of less than one second is of no consequence in most amateur built aircraft.
Joe
_________________ Joe Gores |
Posted: Sun Mar 29, 2015 7:06 pm Post subject: Relays |
At 21:13 2015-03-29, you wrote:
built aircraft.
Good eye!!!! There was a lengthy discussion here
on the list some years ago. About that same time,
I was deeply immersed in some failure studies of
relays on the roll trim system on the Beechjet.
Even the folks who supplied the relays couldn't
figure out what was going on . . . and it took
me several years of sifting the reports and doing
the science to identify and demonstrate
the root cause.
Here's 'the meat' of a report I crafted for RAC.
http://tinyurl.com/pstsggm
Turns out that primary stresser for causing very
lightly loaded contacts to stick was an effect not
discussed or warned against in any relay applications
document I could find.
Some years earlier, I was able to explore and confirm
that the form of coil suppression on a relay had
very little effect on the contact spreading velocity
once the relay started to open. Diodes have
a PROFOUND effect on drop out delay . . . but that
forcing function has almost no effect on spreading
velocity . . . hence tendency to arc. Once the armature
comes off the electro-magnet pole-piece, the AIR GAP
produced therein weakens the magnetic force far
more rapidly than the diode can retard it's decay.
http://tinyurl.com/qgkgo88
It's tar-bucket stepped into by many
authors in the 'relay arts'. A document
from Tyco was often cited here on the list where
one ASSUMED that because the diode retards
drop-out response . . . if just logically followed
that the contacts must spread more slowly as well.
http://tinyurl.com/ndc6cvl
Now, if we were using relays in systems wire TIMING
was critical . . . the extended drop-out delay
might cause other problems . . . but not reduced
contact life due to aggravated arcing.
LarryRosen
Posted: Mon Mar 30, 2015 4:39 am Post subject: Relays |
#40356
N205EN (reserved)
<http> |
Posted: Mon Mar 30, 2015 5:38 am Post subject: Re: Relays |
Relays can also stick for mechanical reasons unrelated to contact current or to coil current. Many relays are made with a thin film of non-magnetic material between the coil core and the armature to prevent them from sticking together due to residual magnetism. If that thin film is missing or damaged, the relay can stick closed.
At work a machine operator complained that the equipment started up all by itself. The equipment was a large mixing tank powered by a 5 HP three phase motor. The operator pushed the stop button and the run-light went out. Later the operator noticed that the mixer was running again. He called an electrician who confirmed that the motor started running all by itself. (Even reliable witnesses make mistakes.) I got involved and found that the start-stop buttons send signals to a PLC (Programmable Logic Controller). And the PLC controls the run indicator light and an AC contactor. The PLC worked fine. When the stop button was pushed, the run indicator light went out and the PLC opened the contactor coil circuit. But the contactor did not open. So it turns out that the motor did not start up all by itself. It never stopped running when the stop button was pushed. I replaced the contactor and that fixed the problem. I examined the bad contractor on the workbench but could not find any mechanical problem with it. My conclusion was that the contactor was sticking closed due to either residual magnetism or due to atmospheric pressure (like when two oily flat surfaces can be hard to separate). The contactor did have two large mating surfaces that fit perfectly together. The moral of the story is, expect the unexpected and verify what others tell you.
LarryRosen
Posted: Mon Mar 30, 2015 2:25 pm Post subject: Relays |
#40356
N205EN (reserved)
<http> |
LarryRosen
Posted: Mon Mar 30, 2015 7:28 pm Post subject: Re: Relays |
I will try one more time. Not sure why my message got through without any text.
Putting the signal relay into a backshell seems like an interesting project I would like to try.
Are there any d-sub backshells that are better suited to stuffing the relay into?
I have looked some electrical catalogs for a mounting bracket like you describe. I take it it is a roll your own.
And finally would you solder wire to the relay and use pins into the d-sub?
I will post pictures when I get it done.
Larry
#40356
N205EN (reserved)
<http> |
raymondj(at)frontiernet.n Guest
Posted: Tue Mar 31, 2015 4:56 am Post subject: Relays |
Larry,
FWIW, I have had the same problem in the past, and found it was
associated with sending or replying to emails with images
embedded/attached to them. Didn't spend the time to find a solution
other than to avoid images, so I can't offer any real solution to the
problem.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 03/30/2015 10:28 PM, LarryRosen wrote:
Larry
Larry Rosen
#40356
N205EN (reserved)
<http>
http://forums.matronics.com/viewtopic.php?p=440053#440053
Posted: Tue Mar 31, 2015 11:40 am Post subject: Relays |
At 22:28 2015-03-30, you wrote:
--> AeroElectric-List message posted by: "LarryRosen" <N205EN(at)gmail.com>
I take it it is a roll your own. And finally would you solder wire to the relay
Good for you . . .
The legacy DSub shells have internal dimensions
that closely mimic connectors themselves. The D15
backshells I use have internal 'thickness' heights
on the order of 0.45"
The relay you choose must have at least one dimension
equal to or less than the internal height of the shell.
If you like, I can mail you a shell and bracket. The
connectors and hardware are prolific.
Relays too. . . there's probalby 100 parts
in the Digikey catalog suited you task. First
crack at a search
[img]cid:.0[/img]
http://tinyurl.com/p3f3cbh
A surface mount version is good . . . you might
have to cut pins off anyhow. Neat doesn't count
Use solder cup connector and 24 or 26 awg wire.
Solid wire is okay . . . after you've check it
for functionality, you'll pot it with hot-glue.
Let me know if you want the parts.
21.14 KB |
22058 Time(s) |
