How to lift the nose wheel without an engine hoist
Goto page Previous  1, 2
Bob Turner
PostPosted: Sat Mar 14, 2015 11:48 am    Post subject: Re: How to lift the nose wheel without an engine hoist Reply with quote
I'd say you're both right, in some circumstances.(!)
If you're talking about the structure (tailcone, spars, etc) then the ideal physics analysis is very good. At 45 degrees, 71% (actually one over the square root of two) of the force is vertical, and an equal amount is horizontal.
But if you're talking about pulling out the threads, it is more complicated. The horizontal force will cause the bolt to pivot slightly, "locking" the bottom and top of the bolt deeper into the threads, where they are thicker, and thus have a lot more strength in tension. To visualize this, imagine that the tail had been tapped oversize, so the threads of the bolt just barely grabbed.
Bob Turner
RV-10 QB
Rocketman1988
PostPosted: Sat Mar 14, 2015 2:53 pm    Post subject: Re: How to lift the nose wheel without an engine hoist Reply with quote
Agreed. It is all just academic anyway because that tie down is threaded for a 3/8" bolt and unless you really messed up tapping the hole, 250 lbs is never going to pull those threads out...
40555
PostPosted: Sun Mar 15, 2015 6:25 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
Hi All'I plan on reducing the load on the tie down by adding about 80 lbs in the baggage compartment. I also was thinking of 40 lbs on either side of the vertical stabilizer.
Thoughts?
I'm getting closer to the finish line!
Craig Rufi
On Sat, Mar 14, 2015 at 12:48 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=439382#439382
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
woxofswa
PostPosted: Sun Mar 15, 2015 6:41 am    Post subject: Re: How to lift the nose wheel without an engine hoist Reply with quote
>>Hi All'I plan on reducing the load on the tie down by adding about 80 lbs in the baggage compartment. I also was thinking of 40 lbs on either side of the vertical stabilizer.<<
In my opinion it is a lot of extra effort when it is quick, easy, and convenient to jack it up from just behind the firewall. You can maneuver the assembly, and control the lift action seated upon the same stool in the same position.
Unless your donuts have compressed EXACTLY the same amount as the thickness of the doubler you are going to have to make minute adjustments to get the bolt to slide in easily. In my case I had to ease the wheel back down to the floor to get just a few pounds of pressure and viola, the bolt slid right in. I was able to have one hand on the jack release and the other inserting the bolt. You can't do that from the back.
Myron Nelson
Mesa, AZ
Flew May 10 2014
Dave Saylor
PostPosted: Sun Mar 15, 2015 7:00 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
I use bags of water softener salt to weight the tail and other things.  The plastic 40# bags are tough, and convenient.  Find the brand with built in handles.  Use some care to make sure they don't slide off when the angle changes, and of course make sure they pick up the structure of the stab.  You'll be fine.
They belt in to the seats pretty well too when you do gross weight testing.  We would duct tape several together to make them body-size.  Then, make REALLY sure it's well secured so that Sal doesn't slump forward on the controls...
--Dave
On Sun, Mar 15, 2015 at 7:23 AM, Craig Rufi <craigr60(at)gmail.com (craigr60(at)gmail.com)> wrote:
[quote]Hi All'I plan on reducing the load on the tie down by adding about 80 lbs in the baggage compartment. I also was thinking of 40 lbs on either side of the vertical stabilizer.
Thoughts?
Craig Rufi
Bob Turner
RV-10 QB
--Dave
KWVI
Dave Saylor
PostPosted: Sun Mar 15, 2015 7:03 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
--Dave
Thoughts?
Craig Rufi
Bob Turner
RV-10 QB
--Dave
KWVI
Tim Olson
PostPosted: Sun Mar 15, 2015 7:45 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
I would skip it on the stabilizer.  Too much chance of bending thin skins and it would be easier for it to fall off and lose that weight. Just throw it in the baggage area and you'll be fine.
On Mar 15, 2015, at 9:23 AM, Craig Rufi <craigr60(at)gmail.com (craigr60(at)gmail.com)> wrote:
Thoughts?
Craig Rufi
Bob Turner
RV-10 QB
List"">http://www.matronics.com/Navigator?RV10-List
40555
PostPosted: Sun Mar 15, 2015 10:13 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
Thanks Dave,When you say,"pick up the structure of the stabilizer" I'm taking that to mean close to the vertical stabilizer, and balanced on both sides. There the ribs are closer together and a stronger surface for the bags to rest on.
My pool also needs a little more salt too:-))
On Sun, Mar 15, 2015 at 7:57 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
[quote]I use bags of water softener salt to weight the tail and other things.  The plastic 40# bags are tough, and convenient.  Find the brand with built in handles.  Use some care to make sure they don't slide off when the angle changes, and of course make sure they pick up the structure of the stab.  You'll be fine.
--Dave
Thoughts?
Craig Rufi
Bob Turner
RV-10 QB
Dave Saylor
PostPosted: Sun Mar 15, 2015 10:24 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
Kind of.  I mean make sure you have contact with the spars and as many ribs as possible.  And yes, as close to the root as you can. --D
On Sun, Mar 15, 2015 at 11:11 AM, Craig Rufi <craigr60(at)gmail.com (craigr60(at)gmail.com)> wrote:
[quote]Thanks Dave,When you say,"pick up the structure of the stabilizer" I'm taking that to mean close to the vertical stabilizer, and balanced on both sides. There the ribs are closer together and a stronger surface for the bags to rest on.
--Dave
Thoughts?
Craig Rufi
Bob Turner
RV-10 QB
--Dave
KWVI
40555
PostPosted: Sun Mar 15, 2015 10:33 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
We are on the same page!Thanks,
Craig Rufi
On Sun, Mar 15, 2015 at 11:21 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
[quote]Kind of.  I mean make sure you have contact with the spars and as many ribs as possible.  And yes, as close to the root as you can. --D
--Dave
Thoughts?
Craig Rufi
Bob Turner
RV-10 QB
Kellym
PostPosted: Sun Mar 15, 2015 11:05 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
Be very careful with bags of salt. They are typically abused in their
delivery to retail store shelves, and frequently have small tears that
let salt out. Extremely corrosive to your aircraft. It doesn't take but
a bit of powder out of one of those bags. And they are heavy enough it
doesn't take much abrasion to put a small, barely noticeable hole in a
bag. I've seen corrosion in car trunks and pickup beds from that.
I agree with Tim, either put it all in baggage compartment, or put some
plywood or similar on stabilizer to spread load and prevent damage there.
Sand bags or collapsible water jugs are preferable.
Craig Rufi
<mailto:craigr60(at)gmail.com>> wrote:
Thanks Dave,
--Dave
<craigr60(at)gmail.com <mailto:craigr60(at)gmail.com>> wrote:
Hi All'
stabilizer.
Thoughts?
Craig Rufi
grabbed.
Bob Turner
RV-10 QB
-List"
tp://forums.matronics.com <http://forums.matronics.com>
Kelly McMullen
KCHD
Bob Turner
PostPosted: Sun Mar 15, 2015 11:35 am    Post subject: Re: How to lift the nose wheel without an engine hoist Reply with quote
My thinking is that the donuts will compress some with time, so I want a substantial pre-load on them now, not just a few pounds.
I un-jacked the plane, then put my shoulder under the tail and picked it up (maybe 80 lbs there?) and slid a stand under the tail, then added one more (2 total) washer and I could just get the bolt in.
Was this overkill? Or too much pre-load?
Bob Turner
RV-10 QB
woxofswa
PostPosted: Sun Mar 15, 2015 3:23 pm    Post subject: Re: How to lift the nose wheel without an engine hoist Reply with quote
That is a good question and I don't know the answer. I know that the goal is "no slop" and that you are limited to a maximum of three washers. It seems possible that the more pre-load, the more the donuts compress over time, but I'm not sure. I would bet that compression memory is a combination of both time and pressure with a little pressure over a long time having the same effect as high pressure for short bursts. It also seems to me that the act of compression itself is what absorbs energy and therefore a higher pre-compression could mean less potential energy absorption capability in the system. I would rather dissipate energy through the donuts than through the engine mount and/or firewall.
I have heard that they are expensive to replace.
Myron Nelson
Mesa, AZ
Flew May 10 2014
rv10rob(at)gmail.com
PostPosted: Mon Mar 16, 2015 7:41 am    Post subject: How to lift the nose wheel without an engine hoist Reply with quote
Tim has it right--there's no need to mess around with putting stuff on the HS.  Put a bunch of heavy stuff in the baggage compartment, and the tail gets really light.
On Sun, Mar 15, 2015 at 12:02 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Be very careful with bags of salt. They are typically abused in their delivery to retail store shelves, and frequently have small tears that let salt out. Extremely corrosive to your aircraft. It doesn't take but a bit of powder out of one of those bags. And they are heavy enough it doesn't take much abrasion to put a small, barely noticeable hole in a bag. I've seen corrosion in car trunks and pickup beds from that.
I agree with Tim, either put it all in baggage compartment, or put some plywood or similar on stabilizer to spread load and prevent damage there.
Craig Rufi
On Sun, Mar 15, 2015 at 11:21 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com) <mailto:saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)>> wrote:
    <mailto:craigr60(at)gmail.com (craigr60(at)gmail.com)>> wrote:
        Thanks Dave,
            --Dave
            <craigr60(at)gmail.com (craigr60(at)gmail.com) <mailto:craigr60(at)gmail.com (craigr60(at)gmail.com)>> wrote:
                Hi All'
                stabilizer.
                Thoughts?
                Craig Rufi
                    grabbed.
                    Bob Turner
                    RV-10 QB
                    -List"
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Page 2 of 2
