west1m
Joined: 19 Apr 2014 Posts: 155 Location: Hastings, MN
Posted: Wed Mar 11, 2015 7:52 pm Post subject: Things are warming up in Minnesota |
After taking up space for a year or so I finally got to fly my Firefly today.
A short trip around the block but was much fun for my first flight since purchasing it a year ago. Actually in Wisconsin...KRNH
131.1 KB |
17110 Time(s) |
_________________ West1m
Hastings, MN |
Posted: Wed Mar 11, 2015 8:21 pm Post subject: Things are warming up in Minnesota |
Proud of you.
Looks cold up there.
_________________ John Hauck
Titus, Alabama |
Posted: Thu Mar 12, 2015 1:18 am Post subject: Things are warming up in Minnesota |
That is a beautiful photo!
Bill Sullivan
Windsor Locks, Ct., and still a foot of snow here.
On Wed, 3/11/15, west1m <west1m(at)hotmail.com> wrote:
Subject: Things are warming up in Minnesota
Date: Wednesday, March 11, 2015, 11:52 PM
"west1m" <west1m(at)hotmail.com>
my Firefly today.
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=439270#439270
http://forums.matronics.com//files/kolbkrnh_905.jpg
Forum -
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
west1m
Posted: Thu Mar 12, 2015 4:42 am Post subject: Re: Things are warming up in Minnesota |
Weedhoppers and weight shift Eipers don't carry temp gauges. When I got my Firefly running i added the EIS system. While on this little hop I couldn't help but notice the exhaust temps up into the 1200 range. (Rotax447) Unfortunately I did not scroll through the monitor to see both cylinders just the highest was showing. What is a normal looking cruise temp, say 5500-5800 RPM?
Hastings, MN |
t41pilot
Joined: 05 Sep 2011 Posts: 38 Location: Howard City, Michigan
Posted: Thu Mar 12, 2015 5:51 am Post subject: Re: Things are warming up in Minnesota |
I've added the page from the 447 operating manual that contains the nominal operating temps for the 447. 1200 Deg EGT is max. I've set my Grand Rapids unit to reflect that as Red Line. I normally see EGT temps around 1120 and CHT around 350 during cruise depending on weather. The chart says normal EGT is 860 to 1000. I see the 1000 range during climb out and at wide open throttle but not during cruise. Nose down and unloading the prop causes the EGT temp to rise quickly. Don't be surprised if you see the EGT rise quickly in the 4000 RPM range. That is the leanest area of the mixture curve for the Carb. I try to stay out of that area as much as possible. If you experience high EGT all the time, then you may have to visit your prop pitch setting and dial in a little more pitch. I probably could dial in a tad more on mine but my Firefly is performing very well where it's at so I haven't messed with it. I live in Michigan and still have some snow. I hope to be flying by the beginning of April somewhere. Kudos on your Firefly. Nice Pic
72.75 KB |
17000 Time(s) |
_________________ Gregg Kaat
2011 Firefly |
Herbgh(at)nctc.com Guest
Posted: Thu Mar 12, 2015 5:56 am Post subject: Things are warming up in Minnesota |
Envious...mine is in a trailer in a U store it lot in Conn....2000 mile
round trip!!
Hope to have it home by the end of the month... Herb
On 03/11/2015 11:21 PM, John Hauck wrote:
Proud of you.
Posted: Thu Mar 12, 2015 6:40 am Post subject: Things are warming up in Minnesota |
Herb- Where in Ct., and what do you have there? I am in Windsor Locks, one mile off the Bradley runway (BDL).
Bill Sullivan
On Thu, 3/12/15, Herb <Herbgh(at)nctc.com> wrote:
Subject: Re: Things are warming up in Minnesota
Date: Thursday, March 12, 2015, 9:56 AM
Conn....2000 mile
round trip!!
month... Herb
byoungplumbing(at)gmail.c Guest
Posted: Thu Mar 12, 2015 6:59 am Post subject: Things are warming up in Minnesota |
High egt temps could be either or a combination of prop pitch, or possibly running a bit lean. If it has sat for a year you may want to pull the jets and make sure they are clean.  if they have a film on them that could restrict fuel and lean things some. Or maybe a larger jet.  Good luck
Boyd [quote][b]
Posted: Thu Mar 12, 2015 7:05 am Post subject: Things are warming up in Minnesota |
I bought a Firefly a couple of months ago...Near Hartford... 1000 mile
trip that I am dreading.. Super tandem wheeled enclosed trailer...
Herb
On 03/12/2015 09:40 AM, william sullivan wrote:
Bill Sullivan
Conn....2000 mile
round trip!!
month... Herb
70.22 KB |
16969 Time(s) |
41.49 KB |
16969 Time(s) |
Posted: Thu Mar 12, 2015 7:09 am Post subject: Things are warming up in Minnesota |
I thought you got it already. I seem to remember it was in Ellington.
Date: Thursday, March 12, 2015, 11:05 AM
trailer...
Herb
<williamtsullivan(at)att.net>
runway (BDL).
> do not archive
Sullivan
> To: kolb-list(at)matronics.com
AM
store it lot in
> Conn....2000 mile
> round trip!!
the
> month... Herb
west1m
Posted: Thu Mar 12, 2015 7:11 am Post subject: Re: Things are warming up in Minnesota |
Thanks everyone for the quick response. I will have look into this much closer after looking at the chart and the responses . I have a three blade Warp drive prop in the corner of the garage I may try out some day but until then I will check and clean the jets, maybe bump up a notch on the needle if I can or change the jet. I also need to check if both cylinders are the same, I worry about seal leaks on two strokes.
Hastings, MN |
west1m
Posted: Thu Mar 12, 2015 8:04 am Post subject: Re: Things are warming up in Minnesota |
Great looking Firefly. I know the drive you are looking forward to.
I bought my Firefly and most of a Firestar from a guy in New York. (I am in Minnesota) It took two trucks towing two trailers (one came with the Firefly), A small fortune in toll both fees and a hotel night or two.
Not sure why I did it , but what the heck, Everyone loves a road trip.
Hastings, MN |
olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Thu Mar 12, 2015 10:20 am Post subject: Re: Things are warming up in Minnesota |
If I remember correctly the cold air throws off the EGT reading. So if it's 30degrees colder than 75F (egt manufacturer calibration temp) your gauge will show 30degrees higher.
Also the cold air will cause you to run leaner. I raise my needle a notch in the winter and return it in the spring.
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
dcharter
Posted: Thu Mar 26, 2015 2:37 pm Post subject: Re: Things are warming up in Minnesota |
You gotta go by what your sparkplugs read. Use your gauges for set points. In my limited experience, that spike is a false reading from the way the pipe is tuned. I'm not in any way telling you to stay at that throttle setting. I miss my original firestar when it warms up in MN.
Dan
