curts63
Joined: 04 Dec 2013 Posts: 30 Location: New Ringgold, PA
Posted: Sat Mar 07, 2015 1:22 pm Post subject: alternator voltage output |
My question is this, what is the normal output of the alternator in voltage? My volt meter is reading up to 14.7 volts when running around 3000rpm. Is this normal or should it max out around 13.7?
If this is high, I guess I need a new regulator? My problem is the Garmin system seems to fluctuate as the voltage gets up to 14.5 or more volts. When you pull back the throttle and let the voltage drop, things settle down.
Curt
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Sat Mar 07, 2015 2:42 pm Post subject: alternator voltage output |
At 15:22 2015-03-07, you wrote:
13.8 is the MINIMUM needed to fully
charge a lead-acid battery . . . but it
takes a LONG time to top off. Starting
batteries in vehicles are generally recharged
at 14.2 plus/minus 0.2 and 14.7 is not
too high.
| Quote: | If this is high, I guess I need a new regulator? My problem is the
Is this a piece of aircraft hardware?
The voltage level you cite should be
no problem. What system are we talking
about?
Bob Nuckolls
AeroElectric Connection
P.O. Box 130
Medicine Lodge, KS 67104-0130
Mobile: 316-209-7528
Web: http://aeroelectric.com
curts63
Posted: Sun Mar 08, 2015 3:31 am Post subject: Re: alternator voltage output |
My system is the Garmin G3X touch. The engine is the Jabiru 3300, using the Kubota regulator. Most times when I take off, the voltage is around 12.5, and shortly after at full power it will climb to the 14.7 range. It's at that time, the tachometer starts acting erratically.
If I pull the power back and the voltage drops a little, the tach will settle to a smoother reading.
BARRY CHECK 6
Posted: Sun Mar 08, 2015 8:06 pm Post subject: alternator voltage output |
Curt:
The required output of the alternator & ACU to charge a battery is: 13.8 to 14.2 VDC at Minimum of 4 Amps. If you are not seeing that voltage rand you are compromising your system and not charging the battery correctly of fully.
Barry
On Sun, Mar 8, 2015 at 7:31 AM, curts63 <curts63(at)verizon.net (curts63(at)verizon.net)> wrote:
[quote]--> JabiruEngine-List message posted by: "curts63" <curts63(at)verizon.net (curts63(at)verizon.net)>
http://forums.matronics.com/viewtopic.php?p=439146#439146
ne-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
">http://forums.matronics.com
le, List Admin.
BARRY CHECK 6
Posted: Sun Mar 08, 2015 8:14 pm Post subject: alternator voltage output |
Curt:
What do you mean by "fluctuating"?
Garmin equipment is designed to run up to 36 VDC,so your slightly high reading of 14.7 VDC is really not an issue for the equipment. It is slightly high for charging but still ... acceptable.... Your reading makes me question what you are using for a VOM? The accuracy!
Next... Back to the "fluctuating"... With the numbers you are posting I'm thinking the problem is more in-line with the wiring.
Barry
On Sat, Mar 7, 2015 at 4:22 PM, curts63 <curts63(at)verizon.net (curts63(at)verizon.net)> wrote:
Curt
http://forums.matronics.com/viewtopic.php?p=439131#439131
le, List Admin.
curts63
Posted: Mon Mar 09, 2015 3:33 am Post subject: Re: alternator voltage output |
the fluctuating of the tach is something like this. When I take off the tach is around 2650 rpm and fairly steady. After starting to climb out, the tach shows anywhere from 330 rpm to 3300 rpm, or the display will "red flag" the instrument. The rpm will vary in those ranges. Yesterday, it happened on the ground.
The wiring for the tach hookup is a single shielded wire from the alternator output to the Garmin GEA-24 box. In the setup for the system, you select "jabiru alternator" as the choice for input. I thought it seemed pretty simple, but has proven to be elusive.
I have no idea why this is occurring. So far, we can't recreate the issue consistently to pin point a common cause. My limited experience and knowledge has me looking on these sites for assistance. My "avionics" guy that did almost all of the wiring is at a loss.
nuckollsr
Posted: Mon Mar 09, 2015 3:47 am Post subject: alternator voltage output |
At 06:31 2015-03-08, you wrote:
Okay, this sounds more like a signal/noise issue than a
voltage issue. 14.7 is not all that much out
of whack . . . and certainly not high enough to
push any piece of avionics into the weeds.
How does the Garmin get RPM information from
the engine?
Bob Nuckolls
P.O. Box 130
BARRY CHECK 6
Posted: Mon Mar 09, 2015 5:44 am Post subject: alternator voltage output |
Curt:
If what you are saying is correct? You just answered your own question.
1 -
On Mon, Mar 9, 2015 at 7:33 AM, curts63 <curts63(at)verizon.net (curts63(at)verizon.net)> wrote:
http://forums.matronics.com/viewtopic.php?p=439189#439189
le, List Admin.
BARRY CHECK 6
Posted: Mon Mar 09, 2015 5:59 am Post subject: alternator voltage output |
Curt:
IF what you are saying is correct? You just answered your own question.
1 - You do NOT run any instruments directly off the alternator! Got that???
2 - From the alternator you go to the ACU (Alternator Control Unit) - (Voltage Regulator).
3 - From the alternator you go to the BATTERY. <-- This is the heavy wire used to charge the battery. The battery has to be charged and the battery also acts as a stabilizing device. It smooths out the high and low outputs from the alternator. The ACU is what stabilizes the voltage to the Buss.<-- Simple explanation.
4 - From the BATTERY you go to the plane's BUSS.
5 - >From the plane's BUSS you go to a Circuit Breaker (CB) and then to your instruments.
6 - IF you are seeing all sorts of fluctuations I'm betting it is because you have the instrument connected directly to the Alternator as you stated.
Once you verify your answer or correct your plane's wiring to the above. THEN we can look at things like:
Wire Size
Wire Type - Shielded?
How you Grounded the shielded and where?
How you ran the wire.
NOW! The question I have to ask about the RPM:
You saw the fluctuations of the RPM on the tack. BUT! Did you hear and feel the fluctuations? Is this an electrical issue you are chasing, or is it mechanical?
Barry
On Mon, Mar 9, 2015 at 7:46 AM, Robert L Nuckolls III <bob.nuckolls(at)aeroelectric.com (bob.nuckolls(at)aeroelectric.com)> wrote:
[quote]--> JabiruEngine-List message posted by: Robert L Nuckolls III <bob.nuckolls(at)aeroelectric.com (bob.nuckolls(at)aeroelectric.com)>
| Quote: | --> JabiruEngine-List message posted by: "curts63" <curts63(at)verizon.net (curts63(at)verizon.net)>
the engine?
Bob Nuckolls
P.O. Box 130
Mobile: [url=tel:316-209-7528]316-209-7528[/url]
le, List Admin.
nuckollsr
Posted: Mon Mar 09, 2015 6:55 am Post subject: alternator voltage output |
It's a fairly common practice to deduce engine RPMs
by sampling the frequency of the AC voltage produced
by the permanent magnet alternator. If there were
nothing else attached to the alternator's stator winding,
the output would be a clean sine wave signal. Pretty
easy to 'decode' for its information about frequency.
As soon as you hook a rectifier/regulator to the alternator,
there's a host of noises that get impressed on these
wires that make the voltage anything BUT a clean
sine wave. There's a certain amount of signal conditioning
needed to reject the trash leaving the tachometer
circuits with clean data.
I'm betting that your particular configuration
presents a noise signature at the ragged edge of
Garmin's design considerations. At the higher
RPMs there are artifacts of rectifier/regulator
switching noises that are confusing the tachometer.
According to my copy of a g3x installation manual,
the Jabiru signal is known to be 6 pulses per rev
off the alternator winding. So 2400 RPM x 6 is
14,400 pulses per minute or 240Hz. A relatively
easy experiment to conduct is to fabricate a
filter like this . . .
[img]cid:.0[/img]
This filter has a frequency roll-off in the neighborhood
of 240Hz and would be a strong attenuator of
artifacts of higher frequency.
You can solder all the parts together and
cover with a piece of heat-shrink. You would
have three leads coming out, AC Input, Signal
Output and Ground. This network would go a long
way toward limiting the high frequency noises
that I think are confusing the G3x.
Bob Nuckolls
P.O. Box 130
45.34 KB |
24806 Time(s) |
nuckollsr
Posted: Mon Mar 09, 2015 9:23 am Post subject: alternator voltage output |
OOPS!!!! Got my tongue wrapped around my eyeteeth and
couldn't see what I was drawing . . . There was an
error in the first drawing that would have resulted in
a really poor performing filter. Drawing corrected
below . . .
[img]cid:7.1.0.9.0.20150309122111.01c08da8(at)aeroelectric.com.1[/img]
Bob Nuckolls
P.O. Box 130
111.21 KB |
24802 Time(s) |
nuckollsr
Posted: Mon Mar 09, 2015 11:13 am Post subject: alternator voltage output |
At 13:04 2015-03-09, you wrote:
| Quote: | The Jabiru alternator coil floats with respect to the electric
ground. The signal relies on parasitic capacitance and whatever
leaks inside the regulator. You'll get a much steadier signal if you
also tie a 10K 1/2W resistor between ground and the alternator wire
that you didn't use for the G3x input.
I had poor indication on a UMA tach, solved it using the resistor
above but found it interfered with the 'low charge' output from the
regulator. The final fix for me was to use an audio transformer as a balun.
Rob
That's another good approach. Yes, the AC power
coil is 'floating' but when connected to the
rectifier/regulator, either side of the ac winding
is either a volt or so above ground (- half cycle)
to many volts above ground (+ half cycle) . . . and
the wave form is really ratty . . .
Going across the AC winding with the isolation
transformer gets around the wave form distortion
generated by the R/R.
Bob Nuckolls
P.O. Box 130
curts63
Posted: Mon Mar 09, 2015 11:17 am Post subject: Re: alternator voltage output |
Thank you for the information and sketch. I'll give this to my avionics guy tonight and see if we can get the parts. I'll let you know if this works.
Thanks again,
Curt
nuckollsr
Posted: Mon Mar 09, 2015 6:46 pm Post subject: alternator voltage output |
At 14:18 2015-03-09, you wrote:
know if this works.
Thanks again,
Curt
| Quote: | Got bins full of parts. Can drop a suite
of parts in an envelope if you need them.
Also, that transformer coupled approach
has a high order probability of success
as well.
I would modify it a bit to utilize readily
available transformers . . . but if plan-A
doesn't get it, plan-B is a good bet.
Bottom line is that I've never met a noise
problem that couldn't be whipped.
Bob Nuckolls
P.O. Box 130
curts63
Posted: Sun Mar 29, 2015 4:55 am Post subject: Re: alternator voltage output |
First, thank you for the input and problem solving. I wanted to let you know that the "filter" that you suggested did a rock solid job from 0-3000 rpm. When I'm at full throttle, I still get a fluctuating tach, but at least now it doesn't flag.
Curt
nuckollsr
Posted: Sun Mar 29, 2015 10:47 am Post subject: alternator voltage output |
At 07:55 2015-03-29, you wrote:
| Quote: | --> JabiruEngine-List message posted by: "curts63" <curts63(at)verizon.net>
First, thank you for the input and problem solving. I wanted to let you know that the "filter" that you suggested did a rock solid job from 0-3000 rpm. When I'm at full throttle, I still get a fluctuating tach, but at least now it doesn't flag. |
Oh man . . . I think I was supposed to send
you some parts for that . . . I think I dropped
the ball.
Okay, my next best guess is that the signal is
still too big. Try removing one of the series
zeners . . . trimming it down to this:
[img]cid:7.1.0.9.0.20150329133937.010c0048(at)aeroelectric.com.0[/img]
If that's still short of rock solid stable, try
adding more 0.1 uF caps in parallel across the
signal line.
Sorry 'bout that kit.
Bob Nuckolls
P.O. Box 130
37.65 KB |
24714 Time(s) |
curts63
Posted: Mon Mar 30, 2015 3:24 am Post subject: Re: alternator voltage output |
No problem. I'd rather have your expertise than the parts. I'll have him make another filter without the extra diode and see what happens. Thank you again.
curt
