rvdave
Posted: Wed Feb 18, 2015 4:00 pm Post subject: Elevator counterweight |
I am installing the elevators, this is a kit I bought from someone who already had the lead weights bolted on and the fiberglass tips riveted on. When I went to install the elevator with the trim tab attached I expected to let go of the elevator and see it fall to full up position but instead it fell to full down elevator. It doesn't look like the weight had been cut, drilled or shaved in any way. Is this normal? Does the elevator need to balance to stay level by itself during initial install? With the pushrods hooked up there is enough resistance with the pitch servo to hold it where I put it.
_________________ Dave Ford
Cadillac, MI |
Posted: Wed Feb 18, 2015 4:20 pm Post subject: Elevator counterweight |
I don't remember the number, but there is a procedure for checking the balance (I think in the little notebook the is the beginning of the building plans).
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
| Quote: | On Feb 18, 2015, at 7:00 PM, rvdave <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=438486#438486
rvdave
Posted: Wed Feb 18, 2015 4:48 pm Post subject: Re: Elevator counterweight |
I think I do have that booklet at the hangar, I will look into that.
Cadillac, MI |
Kellym
Posted: Wed Feb 18, 2015 4:55 pm Post subject: Elevator counterweight |
I don't think you get the sheets on checking rigging and balance of the
control surfaces until the finish kit.
It would be a lot better if the info were on the plans at the end of the
build of each control surface.
I'm not all that inclined to remove the control surfaces yet again to
check balance, when it will have to be done again when the plane is painted.
On 2/18/2015 5:16 PM, Jesse Saint wrote:
Jesse Saint
352-427-0285
Sent from my iPad
> Dave Ford
> RV6 for sale
> RV10 building
> Cadillac, MI
KCHD |
rvdave
Posted: Wed Feb 18, 2015 7:31 pm Post subject: Re: Elevator counterweight |
Interesting.... I found this in the archives:
Vans does have a spec for elevator balance. It can be found in their Final Inspection and Flight Test Document on Page 2. For the -10 it is 37.5 in/lbs Trailing Edge Heavy. The factory can tell you how to rig the appropriate test equipment...
John Hasbrouck
#40264
Actually the equipment needed for checking the counterbalances is quite
simple. For the elevators you need a rod attached to the elevators
extending forward to a point 37.5 inches from the hinge centerline with a 1
lb weight attached at that point. ( 37.5 in/lb ). This is with both
elevators attached, the trim in place and the tips on. If your choose to
pop rivet the tips on you should probably wait until the final balance is
done. ( Didn't tell us that in the plans did they? I used #4 screws and
nutplates for mine. ) Adjust counterweights so the elevators rest trailing
edge low. Any other builders who want to correct or expand on the above
procedure please do so. I'd appreciate constructive advise particularly
from previous RVers. BTW. The old -6 plans called for the builder to melt
lead ingots into a mould to form the counterweights. Boy are we spoiled!!
John Hasbrouck
Cadillac, MI |
Kellym
Posted: Wed Feb 18, 2015 7:53 pm Post subject: Elevator counterweight |
That assumes that the rod could be attached exactly at the hinge point.
Or you can measure the distance from the hinge point to the trailing
edge. With the hinge bolts on a knife edge, place a scale under the
trailing edge to measure the weight there times the distance.
I'm curious as to how many of the flying RV-10s were checked for flight
control balance before first flight, and if so, how much weight
adjustment was needed, if any.
John Hasbrouck
#40264
| Quote: | [b]
John Hasbrouck
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=438490#438490
KCHD |
Posted: Wed Feb 18, 2015 8:01 pm Post subject: Elevator counterweight |
You could also do double the weight at half the distance, etc. figuring the amount of weight to put on top of both counterbalance arms would be my preference.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
John Hasbrouck
#40264
| Quote: | [b]
John Hasbrouck
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
rvdave
Posted: Thu Feb 19, 2015 9:50 am Post subject: Re: Elevator counterweight |
Spoke with Ken at Vans this morning, his view is-- that is normal that the stock Vans lead counterweight is enough for a standard build standard operated 10 and that the elevator would float down to full down elevator at install with the trim tab attached. His only concern was flutter from either too much bondo or similar product aft of hinge line, or extreme altitude or speed beyond Vans engineered ideals. He left it with the thought that I already had the solution but was looking for a problem.
Not sure what to think regarding any adjustment or balancing now.
Cadillac, MI |
speckter(at)comcast.net Guest
Posted: Thu Feb 19, 2015 10:01 am Post subject: Elevator counterweight |
Build on
| Quote: | On Feb 19, 2015, at 9:50 AM, rvdave <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=438506#438506
rv10flyer
Posted: Sun Mar 01, 2015 6:34 am Post subject: Re: Elevator counterweight |
Mine is factory original with no problems so far. Like above, build on.
_________________ Wayne G. |
