jskiba(at)icosa.net Guest
Posted: Wed Feb 18, 2015 11:35 am Post subject: Best way to connect to marker beacons Rg400 coax |
Hi All,
What is the ‘best’ way to connect to a marker beacon antenna’s Rg400 coax cable, Meaning I need to tie it to regular wire coming out of the audio pnl with the receiver.
Should I just solder and heat shrink to the rg400 ?
or wire the regular wire to a bnc connector ?
or some other type of connector set up to do this ?
Jeff
stein(at)steinair.com Guest
Posted: Wed Feb 18, 2015 12:09 pm Post subject: Best way to connect to marker beacons Rg400 coax |
Solder a wire to the center conductor, then put heatshrink over it. For the outer shield, use a simple Solder Sleeve with a lead on it. Put heatshrink over the entire thing, no you have a nice termination from Coax to two small AWG22 wires that will work in the audio connector, but put the pigtail a few inches back (where it’s easy to work with).
Cheers,
Stein
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeffrey W. Skiba
Sent: Wednesday, February 18, 2015 1:33 PM
To: 'aeroelectric-list(at)matronics.com'
Subject: Best way to connect to marker beacons Rg400 coax
Hi All,
Jeff
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567
henry(at)pericynthion.org Guest
Posted: Wed Feb 18, 2015 2:35 pm Post subject: Best way to connect to marker beacons Rg400 coax |
For the marker beacon, you could use a wet noodle and it would still work.
Henry
On Wed, Feb 18, 2015 at 12:06 PM, Stein Bruch <stein(at)steinair.com> wrote:
| Quote: | Solder a wire to the center conductor, then put heatshrink over it. For the
Cheers,
Stein
W. Skiba
Hi All,
with the receiver.
Jeff
http://forums.matronics.com
