Posted: Thu Feb 12, 2015 7:15 pm Post subject: Question about monitoring output in two alternator configu |
At 16:05 2015-02-12, you wrote:
Hi everyone.
I have an electrical system with dual alternators (primary and
backup) and have a question with regards to monitoring their output
current. My EFIS has the capability of monitoring each output
separately, but considering that the alternators are wired such that
only one can be on at a time, I'm not a big fan of this, since I
don't want to get used to the view of an alternator output always
reading zero during normal operation - it desensitizes a person in
noticing if there ever is a real problem. (I used to fly a Mooney
that had a red gear warning light always on when the gear were up, by
terrible design. You get really used to seeing a red light always
on, and then completely ignore it).
But 'zero' in a standby alternator is significant. What
is the likelihood of loosing a standby alternator AND
the main alternator between two pre-flight tests?
Instead, I'd rather have the EFIS just provide a display showing a
single output of either alternator - whichever is producing
current. What seems to me to be a simple way of achieving this would
be to just tie the output of each alternator to the same side of the
shunt (the terminal opposite that going to the contactor). Then, it
would seem to me as though the shunt would just measure the combined
output of both alternators, which in effect would be just the output
of the alternator that's currently active. But when I asked the EFIS
manufacturer about this, they implied that this wouldn't be the
"right way" to do it - instead, I should use a hall sensor and pass
both wires through it.
But I can't understand why using the shunt in this manner wouldn't
work (other than the shunt becoming a single point of failure if it
should blow like a fuse).
It would . . . but perhaps hooking neither alternator
to the EFIS is a better plan. Your alternator's output
is a KNOWN quantity that is, by design, loaded no
heavier than original design goals. As long as
your low voltage light is not flashing, all is
right with the universe . . . irrespective of
any reading you might observe for the alternator.
Similarly, should main alternator fail then the
standby alternator should be loaded no greater
than its capability to keep the bus at 12.5 to 13.0
volts. Again, the voltmeter for one bus is your
primary statement of electrical system health
for flight ops.
Attaching both alternators to a single shunt
forces both output paths to share circuitry.
If you'd like to have these paths be totally
independent of each other, be circuit protected
with a device appropriate to alternator size,
-OR- (as in Z-12/ have the two alternators
drive different parts of the system, then
the two wires through a hall sensor is the
preferred architecture.
Posted: Thu Feb 12, 2015 7:21 pm Post subject: Question about monitoring output in two alternator configu |
Hilarious. They ship the EFIS a with a shunt, then tell their
customers that using the shunt isn't the right way to set it
up. Customer support by Laurel & Hardy.
One shunt per alternator is how it was
done for the last century or so . . . still
works good. Tying two alternators to the
same shunt raises questions about the
loss of independence/redundancy of the
two systems.
