In need of Yak52 spares (ideas and prices please!)
nigel(at)yakdisplay.com
PostPosted: Wed Feb 11, 2015 3:39 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
I am in need of some YAK-52 spare parts...
I would like a price for the following please, plus shipment costs to the UK.
<![if !supportLists]>· <![endif]>Can anyone supply all the internal parts to overhaul the main gear actuators including the seal carrier (attached image) seals, retainers, circlips etc.
<![if !supportLists]>· <![endif]>Set of tyres
Any ideas anyone????
Nigel Willson
Flying Instructor/Examiner and Display Pilot
_________________________________________________
email: nigel(at)yakdisplay.com (nigel(at)yakdisplay.com)
mobile: (+44) 7809 116676
web: http://yakdisplay.com
 Filesize:  137.09 KB
 Viewed:  22787 Time(s)
ssssskippy
PostPosted: Wed Feb 11, 2015 4:14 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
Hi Nigel
Did you try to contact Termikas or wlac. http://www.wlac.co.uk/wlacrussianeng/ ?
Olivier Vigneron
Le 11 févr. 2015 à 12:38, Nigel Willson <nigel(at)yakdisplay.com (nigel(at)yakdisplay.com)> a écrit :
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
· Can anyone supply all the internal parts to overhaul the main gear actuators including the seal carrier (attached image) seals, retainers, circlips etc.
· Set of tyres
Nigel Willson
<image001.png>
richard.goode(at)russiana
PostPosted: Wed Feb 11, 2015 4:56 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
It really is not a DIY job to overhaul the actuators. We can do it through our partner Aerometal in Hungary, as can Termikas in Lithuania.
Four tyres in the UK, I would go to Watts who sell a huge range of aviation tyres.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Nigel Willson
Sent: 11 February 2015 11:39
To: yak-list(at)matronics.com
Subject: In need of Yak52 spares (ideas and prices please!)
· Set of tyres
Nigel Willson
believed to be clean.
 Filesize:  137.09 KB
 Viewed:  22782 Time(s)
dsavarese0812(at)bellsout
PostPosted: Wed Feb 11, 2015 5:28 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
As Richard says, it is definitely not a DIY job unless you have someone providing guidance on how to reinstall the chevron seals without damaging them. Here in the US, the actuator seal kits are about $150 USD per. Damage one chevron seal when reassembling an actuator and you have just blown $150. Been there, got the T shirt.
Then you have to deal with the actuator end caps which are not always easy to remove. If you break the end cap with the tab on it while trying to remove it, you've got an even bigger problem.
Send them off an have an experienced group like Aerometal do them for you. You will not be sorry you did.
Dennis
From: Richard Goode <richard.goode(at)russianaeros.com>
Sent: Wednesday, February 11, 2015 6:55 AM
Subject: RE: In need of Yak52 spares (ideas and prices please!)
#yiv3450157057 #yiv3450157057 -- _filtered #yiv3450157057 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv3450157057 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv3450157057 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #yiv3450157057 {panose-1:2 5 6 4 5 5 5 2 2 4;} _filtered #yiv3450157057 {panose-1:2 11 6 4 2 2 2 2 2 4;} _filtered #yiv3450157057 {panose-1:3 1 1 1 1 1 1 1 1 1;} #yiv3450157057 #yiv3450157057 p.yiv3450157057MsoNormal, #yiv3450157057 li.yiv3450157057MsoNormal, #yiv3450157057 div.yiv3450157057MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;} #yiv3450157057 a:link, #yiv3450157057 span.yiv3450157057MsoHyperlink {color:#0563C1;text-decoration:underline;} #yiv3450157057 a:visited, #yiv3450157057 span.yiv3450157057MsoHyperlinkFollowed {color:#954F72;text-decoration:underline;} #yiv3450157057 p.yiv3450157057MsoPlainText, #yiv3450157057 li.yiv3450157057MsoPlainText, #yiv3450157057 div.yiv3450157057MsoPlainText {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;} #yiv3450157057 span.yiv3450157057PlainTextChar {} #yiv3450157057 span.yiv3450157057EmailStyle19 {color:windowtext;} #yiv3450157057 span.yiv3450157057EmailStyle20 {color:#1F497D;} #yiv3450157057 .yiv3450157057MsoChpDefault {font-size:10.0pt;} _filtered #yiv3450157057 {margin:72.0pt 72.0pt 72.0pt 72.0pt;} #yiv3450157057 div.yiv3450157057WordSection1 {} #yiv3450157057 It really is not a DIY job to overhaul the actuators. We can do it through our partner Aerometal in Hungary, as can Termikas in Lithuania.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Nigel WillsonSent: 11 February 2015 11:39To: yak-list(at)matronics.comSubject: In need of Yak52 spares (ideas and prices please!)
·   Set of tyres
Nigel Willson
_________________________________________________ email: nigel(at)yakdisplay.com (nigel(at)yakdisplay.com) mobile: (+44) 7809 116676 web: http://yakdisplay.com[img]cid:1.1839989125(at)web184805.mail.gq1.yahoo.com[/img]
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
 Filesize:  137.09 KB
 Viewed:  22780 Time(s)
PostPosted: Wed Feb 11, 2015 7:36 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
Wlac no joy, termikas have emailed in parallel…
Nigel Willson
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Ssssskippy
Sent: 11 February 2015 12:14
Subject: Re: Yak-List: In need of Yak52 spares (ideas and prices please!)
Hi Nigel
Olivier Vigneron
Nigel Willson
<image001.png>
  _-============================================================_-=          - The Yak-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,_-= Photoshare, and much much more:_-=_-=   --> http://www.matronics.com/Navigator?Yak-List
 Filesize:  137.09 KB
 Viewed:  22775 Time(s)
PostPosted: Wed Feb 11, 2015 7:39 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
Thanks Richard. Not DIY, but via a mtce org is how it will be done.
Have also contacted Termikas….
Nigel Willson
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
Sent: 11 February 2015 12:56
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Nigel Willson
·   Set of tyres
Nigel Willson
 Filesize:  137.09 KB
Harv
PostPosted: Thu Feb 12, 2015 8:37 am    Post subject: Re: In need of Yak52 spares (ideas and prices please!) Reply with quote
Try Jill in the USA
http://www.m-14p.com/
They might have them on the shelf (plus a core charge) and then send your old ones back at your leisure.
Be ready to be bent over on the import taxes though....
Viperdoc
PostPosted: Thu Feb 12, 2015 9:37 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
Be prepared to be bent over on the rebuilt strut charge along with the core charge too.
Doc
On Feb 12, 2015, at 10:37 AM, Harv <martin.harvey(at)kbr.com> wrote:
Try Jill in the USA
http://forums.matronics.com/viewtopic.php?p=438260#438260
Viperdoc
jill(at)m-14p.com
PostPosted: Fri Feb 13, 2015 9:28 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
Group,
I am not so shocked to see another personal attack on me by this individual,
but I will not sit back and allow it. I do hope one day to meet you in
person, Roger.
________________________________ Message 2
Time: 09:37:47 AM PST US
Subject: Re: Re: In need of Yak52 spares (ideas and prices
please!)
charge too.
Doc
For those of you who may not be privy to the whole story, this "dead" issue
dates back to December 2013 and I am providing the background facts below:
Subject: Facts surrounding the personal attack
Date: Dec 05, 2013
Group,
I will respond to Roger Kemp's personal attack on me with the facts. I
leave it up to you to form your own opinion.
Roger purchased a set of freshly overhauled actuators from me and was
charged a $2,400 core charge for 2 main and 1 nose landing gear actuator for
a Yak 52. (That is an $800 core charge on each actuator. This is nowhere
near replacement value from the factory today.) He did not want to wait for
us to overhaul his actuators. His actuators arrived missing parts (bolts,
washers, bushings and a set screw) and partially disassembled. He had one
bad piston in the nose landing gear actuator - it was heavily corroded. He
also sent a shuttle valve whose mount holes would not align with any of the
actuators sent. He was charged for a replacement shuttle valve. I also
offered to send that defective valve back to him and the old piston. Here
is the complete text of my correspondence with Roger:
Dear Doc,
Good afternoon!
Please see the attached credit memo on your actuators. I will refund you
for the return of the bolts and skinny washers. As you can see by the
price, they are worthwhile returning.
The other deductions are for the corroded piston in the nose actuator. The
shuttle valves were not on the actuators when we got them and one of them
will not align with the holes in any of the actuators. If you want, I will
return this to you.
Hope you had a wonderful Thanksgiving!
Best regards,
Jill
In reference to Roger's statement, "She just screwed me out of $800 on my
actuator cores", he cannot calculate. I refunded him $1,973.97 of the core
charge. $2,400 - $1973.97 = $426.03, not $800. Of that $426.03, if
Roger had sent me the missing parts I would have happily refunded him an
additional $87.77. Then, he would have been assessed a $338.26 core for
the rejected parts. I believe I was fair in my business practices.
Finally, I thank those of you who enjoy doing business with us for your
continued support.
Best regards,
Jill
M-14P, Inc.
I honestly don't know how any of you could read those facts and say that I
was unreasonable in charging for parts that were unusable. Certainly, the
next customer would not want me to rebuild their actuator with corroded and
leaking parts. I am in business and cannot operate at a loss, providing
parts free of charge. I do not apologize for that.
I can also say that we have been in this business since 1992. Take a look
around. How many of the other players in this business are still standing?
We are still here because we are absolutely dedicated and we provide a
service and product that our customers appreciate. I could get on a
Business 101 Soapbox, but the fact of the matter is that those of you who
understand what it takes to run a successful business are my good customers.
The others that think I am a "ripoff bitch" can take your business
elsewhere. That is your choice and I respect that choice. I also choose
not to have you as a customer.
Our landing gear actuator seal kits are $145 USD and include the shuttle
valve rebuild kit. Our flap actuator seal kit is $175 and now includes
stainless steel snap rings and the 2 shuttle valve seal kits. We also
overhaul and pressure test these components.
Jill
M-14P, Inc.
gill.g(at)gpimail.com
PostPosted: Fri Feb 13, 2015 1:25 pm    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
My experience with Jill has been excellent. She has always been helpful and
honest. I have never found her prices to be out of line with the rest of
the world. And I have always found her knowledgeable and willing to help.
And typically she has the parts we need. Jill, like Doug Sapp, George Coy
and Dennis Savarese, is an asset for the YAK and CJ community and helps keep
us flying.
Gill
hess737(at)aol.com
PostPosted: Fri Feb 13, 2015 2:06 pm    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
Doc,
You know me. This is not the right way to handle this. If you have an issue take it direct to the source. Sorry if I'm sympathetic to Jill but I know how hard it is to run a Mx shop. You work hard to keep things moving so you can pay your bills and you try not to surprise customers with unexpected expenses. You expend a lot of energy solving or sourcing difficult foreign items and try to make a profit in a community where everyone is trying to minimize discretionary expenses. It'll put gray hair on your head!
Jill, I hope you have an opportunity to speak to Roger direct and work out your differences. Good communication usually solves most problems. Regardless, this community appreciates all your efforts through the years.
Cheers and hope everyone has a great weekend...
Richard Hess
President
International Jets, Inc.
Gadsden, AL
O 256-442-8099
C 404-964-4885
www.InternationalJets.com
[quote] On Feb 13, 2015, at 4:24 PM, Gill Gutierrez <gill.g(at)gpimail.com> wrote:
us flying.
Gill
JasperWheeler
PostPosted: Thu May 16, 2024 1:39 am    Post subject: Re: In need of Yak52 spares (ideas and prices please!) Reply with quote
For those in need of Yak52 spares, finding the right parts at reasonable prices can be a crucial task to keep these classic aircraft in top flying condition. Whether you're seeking engine components, airframe parts, or avionics, gathering a range of ideas and comparing prices is essential. Engaging with fellow enthusiasts and experts in online forums or aviation groups can yield valuable recommendations and sources for affordable spares. Interestingly, just like coming up with creative "team name ideas" for an escape room challenge, brainstorming and networking in the aviation community can uncover unexpected solutions and suppliers. By pooling resources and knowledge, you can ensure your Yak52 remains airworthy and ready for the skies without breaking the bank.
richard(at)rgaeros.com
PostPosted: Thu May 16, 2024 2:10 am    Post subject: In need of Yak52 spares (ideas and prices please!) Reply with quote
I hope that a limited amount of advertising is allowed on the "Yak list", but with my partner, Aerometal in Hungary, we can supply absolutely any part for the M 14 engine from a membrane to a total overhaul!
PLEASE NOTE NEW EMAIL ADDRESS.
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel:  +44 (0)1544 340120
e-mail: richard(at)rgaeros.com (richard(at)rgaeros.com)
www.rgaeros.com
WORLD LEADERS IN EAST EUROPEAN & CHINESE RADIAL AIRCRAFT ENGINES
In partnership with Aerometal Kft, Hungary.
 Filesize:  5.62 KB
 Viewed:  16391 Time(s)
 Filesize:  5.26 KB
