jose_m_toro(at)yahoo.com Guest
Posted: Tue Jun 27, 2006 3:51 pm Post subject: Taiwan tyres |
Michel:
Try less pressure. With the right pressure, those
tires must work.
Jose
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | Hello Mark,
Here is the data about my new tyres:
Make: Duro
Origin: Taiwan
Size: 5.00 - 8
6 ply
Pressure 30 psi
Max load (at) 19 MPH: 570 pounds
Diameter: 18.1"
Width: 5.4"
Weight: 5 pounds
... and the resulting test, compared to the Cheng
Shin:
Pro: Much more control when taxiing. Turns much
sharper at the end of
the runway.
Con: Much more bumpy ride! Bit fat Cheng Shin at 10
psi is much softer
than 6 ply at 30 psi.
Conclusion: Will have to get another pillow under my
bottom!
Michel
smokey_bear_40220(at)yaho Guest
Posted: Tue Jun 27, 2006 4:32 pm Post subject: Taiwan tyres |
Michel,
It looks like the bead at the wheel is the widest part
of the tire now. Is that correct? If so, the
sidewall flex is limited and will make them ride
harder.
Do you need 30 psi?
I saw it was warmer by you than in London. How is the
engine cooling working out flying in the hot weather?
Kurt S.
| Quote: | --- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | > Con: Much more bumpy ride! Bit fat Cheng Shin at
10 psi is much softer than 6 ply at 30 psi.
my bottom!
> Cheers,
> Michel
Michel
Posted: Wed Jun 28, 2006 2:50 am Post subject: Taiwan tyres |
Hello Kurt and Jose,
Yes, I could inflate to less than 30 psi. What worries me, then, is that the tube might turn in the tyre and tear off the valves. ... or, am I over-reacting?
| Quote: | From: kurt schrader [smokey_bear_40220(at)yahoo.com]
Yes, it looks like it, Kurt.
| Quote: | If so, the sidewall flex is limited and will make them ride
harder.
Good thinking! ... do you know of any good pillow manufacturer?
| Quote: | How is the
I don't know how to say this but ... even the Scandinavian Jabiru dealer doesn't believe me when I say how cool my engine is. I think I've been very lucky in my cowling forming and that it really "suck the air out of that hot stuff."
Anyway, my CHT only goes over 110 C on the ground. Once in the air, even on the hottest day, it hardly reaching 100 C. With 180 C as max CHT, I am flying ... a cool engine at any time!
Michel
Posted: Wed Jun 28, 2006 3:17 am Post subject: Taiwan tyres |
Michel:
I don't think it will tear off the valve, but I'm just
guessing. I would try 20 pounds and do some taxing
and speed taxing. I use 8 pounds in my McCreary
tires.
Jose
| Quote: | Hello Kurt and Jose,
over-reacting?
Posted: Wed Jun 28, 2006 4:14 am Post subject: Taiwan tyres |
I agree with Jose. I like the 1% of gross weight rule
as a minimum. Your plane is light too. I think 20
would be just fine, but with the sidewalls tapered so,
it will still be stiff. The sidewalls bending is what
absorbes the bumps and tapered out to the wheel makes
them stiffer, I think.
Kurt S.
--- "Jose M. Toro" <jose_m_toro(at)yahoo.com> wrote:
| Quote: | Michel:
just
tires.
Jose
the
> over-reacting?
browse
Subscriptions page,
FAQ,
Admin.
morid(at)northland.lib.mi Guest
Posted: Wed Jun 28, 2006 5:58 am Post subject: Taiwan tyres |
Yes, Michel. It would probably have to get down around 5lbs or less to turn
it. I think you could easily use 15 lbs and have a better ride.
Deke
Posted: Wed Jun 28, 2006 8:13 am Post subject: Taiwan tyres |
Michel:
I mentioned 20 pounds just as a starting point for a
trial and error process. I would be looking for close
to 10 pounds.
Jose
--- kurt schrader <smokey_bear_40220(at)yahoo.com> wrote:
rule
so,
what
makes
Kurt S.
Michel
Posted: Wed Jun 28, 2006 8:26 am Post subject: Taiwan tyres |
Thanks Jose, Kurt and Deke.
.. Fox Control, Lima-lima-tango leaving three-zero psi for two-five!
Deke, you say 5 psi, but my old Cheng Shin had about 12 psi and on one
tyre, the tube had already turned a bit in such a way that the valve
was pointing at an odd angle. Sooo, I'll decrease the pressure but
slowly and carefully.
Michel
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Wed Jun 28, 2006 9:48 am Post subject: Re: Taiwan tyres |
Since tires / tyres don't spend that much time on the pavement (or grass) so probably don't heat up too much.... would a light coating of spray adhesive make sense to old the tube in place?
Just a thought.
Richard
Michel
Posted: Wed Jun 28, 2006 1:50 pm Post subject: Taiwan tyres |
On Jun 28, 2006, at 7:48 PM, Richard Rabbers wrote:
| Quote: | Since tires / tyres don't spend that much time on the pavement (or
I think it would but I am not sure it is the problem, Richard. I think
that, when you land, the tyres, if not very inflated, tend to rotate,
with the tube, in relation to the wheel and the hole where the valve
sticks out. If something should be glued, it must be the tyre to the
wheel.
Actually, someone told me today that dragsters have wooden pegs through
the side of the wheel to keep the tyre (and ultimately, the tube) in
place when they "burn rubber."
Michel
asq1(at)adelphia.net Guest
Posted: Wed Jun 28, 2006 2:02 pm Post subject: Taiwan tyres |
Something that will make the problem worse is the common practice of using
Talcum or "baby" powder to make the tube settle in better. Avoid this if you
are concerned about slippage. Larry
Posted: Wed Jun 28, 2006 2:30 pm Post subject: Taiwan tyres |
Right. I should have said 20 psi to start. I use 20
psi on my heavy Fox and Michel`s is lighter by a
bunch. But his tire size is smaller too.
I'd say 10 is a minimum, for that tire and 12-15
better for no tire/tube slippage. It will still be
firm with those sidewalls flairing out, but the
sidewalls flaired might also makes the bead grip
weaker for the same psi.
Echoing the powder concern, if you are going to steal
the powder from your grandchild Michel, keep it
between the tube and tire, not tube and wheel. You
want the tube more firmly gripping the wheel and let
the tire spin.
Kurt S.
| Quote: | Michel:
close to 10 pounds.
Jose
Posted: Wed Jun 28, 2006 2:33 pm Post subject: Taiwan tyres |
Michel,
Try not to decrease it to failure, then increase.
Since you say 12 was too low, maybe 15 is the best you
can do. With another 15 in your seat cushion?
Kurt S.
| Quote: | Thanks Jose, Kurt and Deke.
... Fox Control, Lima-lima-tango leaving three-zero
psi for two-five!
12 psi and on one
way that the valve
the pressure but
Michel
Posted: Wed Jun 28, 2006 5:18 pm Post subject: Taiwan tyres |
I like the number. I vote for 15 pounds!!!
Michel,
you
Kurt S.
Michel
Posted: Thu Jun 29, 2006 1:08 am Post subject: Taiwan tyres |
but the sidewalls flaired might also makes the bead grip
Jose and Kurt, the bead grip was also my concern since the tyre is not as wide as the wheel. I called the guy who got and installed the tyres for me and he says that there is no problem going down from 30 to 20 psi but I should be careful to go under that.
| Quote: | Echoing the powder concern, if you are going to steal
Kurt and Larry, I don't use powder, I don't mount the tyres myself. Are you crazy? I would get my hands dirty! Seriously, this was done by the guy (a big tyres retailer in our town) who found and sold me the tyres. ... talcum, soap, that's not a man's work, is it?
Michel
dave(at)cfisher.com Guest
Posted: Thu Jun 29, 2006 2:34 am Post subject: Taiwan tyres |
I met Gary Walsh yesterday in an airport in Ontario. He had just installed
the MIPPI treadless tires. They look great and are about 21 " tall and 12
" wide. For any that have seen Super Cub Hardcore movies I am sure Gary
will be next to perform some stunts like those . Very impressive looking
and with 912S his take off made GA aircraft there look sick.
Looking forward to seeing some Hardcore Kitfox movies soon Gary .
Dave
lcfitt(at)sbcglobal.net Guest
Posted: Thu Jun 29, 2006 5:44 am Post subject: Taiwan tyres |
Michel,
I wonder about tire slip also, but in a different sense. I find it
extremely difficult to break the bead with any tire I have ever put on these
8" original Kitfox rims. I damaged the hub once trying to break the bead
using a tire demounting device.
For breaking the bead, I was advised to place the wheel and tire on the
ground in front of my car tire and then drive over the kitfox tire. I hope
this makes sense. It will break the bead without involving the rim in any
mechanical device. Past experience suggests to me that tire slippage would
be quite unlikely. However, I have heard of it happening to others.
Lowell
Posted: Thu Jun 29, 2006 7:54 am Post subject: Taiwan tyres |
Hi Lowell,
I havenīt tried this, but if you no longer want the
tire, try a vacuum pump on it. Would only apply to a
tubless tire though.
You definately want to press on the tire only and not
damage the rim. It doesnīt take much to damage alum
rims.
If you drive over the tire, put some cardboard or
carpet under it to save the rim from scrubbing on the
concrete.
Another try might be a LARGE C clamp placed right at
the bead.
I know of others who have their tires slip too. All I
know were due to underinflation.
Just some ideas. Of course you could try a tire place
or 2 and see if their machine would fit?
Kurt s.
Posted: Thu Jun 29, 2006 8:55 am Post subject: Taiwan tyres |
Thanks Kurt,
The vacuum pump idea is a good one. I happen to have an industrial strength
vacuum pump under my work bench. I will use it next tire change and report
the results.
I did use a piece of carpet to protect the rim - thanks for the warning to
others.
Lowell
Michel
Posted: Thu Jun 29, 2006 9:46 am Post subject: Taiwan tyres |
On Jun 29, 2006, at 3:43 PM, Lowell Fitt wrote:
| Quote: | I find it extremely difficult to break the bead with any tire I have
ever put on these 8" original Kitfox rims.
This is why I don't want to do it myself, Lowell. I take the wheels to
the workshop that does it professionally. They use a machine that turns
around the tyre making a "poof!" sound. Cool stuff!
Gary, the King Fox tyres are very good looking but, because of my wheel
penetration skis, I can't use them without major modifications to the
skis. Hence my choice for some slightly smaller tyres.
Michel
