bigginsking
Joined: 25 Sep 2012 Posts: 27 Location: San Diego, California
Posted: Wed Jan 21, 2015 8:14 am Post subject: Leakguard tubes belong in the trash |
Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
The tube just wore through and leaked. I've never seen this happen to any other brand of tube.
Of course it happened at a rather inconvenient time, I was landing at Brown Field, coming back from Mexico, when you are not supposed to get out the the aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun.
Fly Safe,
Bill Judge
N84WJ, RV-8, 1103 hrs
http://rv-8.blogspot.com/
_________________ Bill Judge
N84WJ, RV-8 |
kellemsm(at)yahoo.com Guest
Posted: Wed Jan 21, 2015 8:34 am Post subject: Leakguard tubes belong in the trash |
Did you put talc in when installing?
Tough times don't lastTough people do!!
Mike 931-993-7623
On Jan 21, 2015, at 10:12, Bill Judge <bjudge(at)gmail.com (bjudge(at)gmail.com)> wrote:
[quote]Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
Fly Safe,
Bill Judge
ot;">www.aeroelectric.com
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
st"">http://www.matronics.com/Navigator?RV-List
//forums.matronics.com
Posted: Wed Jan 21, 2015 8:49 am Post subject: Leakguard tubes belong in the trash |
I had a flat once on landing rollout - ended up being caused by a sticker inside the tire rubbing the tube. I first thought the tube was junk - until I saw the wear pattern and the respective sticker....
Might not be your case here - but I thought I would share my failure mode.....
Posted: Wed Jan 21, 2015 8:55 am Post subject: Leakguard tubes belong in the trash |
And I had used talc.....
steve282s(at)yahoo.com Guest
Posted: Wed Jan 21, 2015 11:11 am Post subject: Leakguard tubes belong in the trash |
All of the talc in the world will not prevent an inner tube leak if there is dirt/sand/stickers/grass/rocks/etc between the tube and tire. Even a small grain of sand will cause a leak. Imagine the pressure between the tube and tire and then add the punishment of high speed taxi/takoffs, braking and landings.
Steve
On Wednesday, January 21, 2015 11:07 AM, Ralph E. Capen <recapen(at)earthlink.net> wrote:
--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Posted: Wed Jan 21, 2015 12:49 pm Post subject: Leakguard tubes belong in the trash |
In my (limited) experience, a tube will only wear through if assembled without talc or was underinflated.
I talc everything .... tube, inside of tire and even the wheel hub. Extra talc on the tire bead will make tire removal much easier down the road ... er ... airway .
Linn
On 1/21/2015 11:12 AM, Bill Judge wrote:
[quote] Folks, I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
Fly Safe,
Bill Judge
Checked by AVG - www.avg.com
01/21/15 [b]
Pilots2(at)yahoo.com Guest
Posted: Wed Jan 21, 2015 1:53 pm Post subject: Leakguard tubes belong in the trash |
Had the exact same problem a few years ago with the Dresser No Leaks. 2 of them let go on landings (about a month apart). One split on a seam, the other had cracks like it was
old rubber and very poor quality. I don't buy Dresser tubes anymore. Mitchelin much better quality.
7A 7WT
Sent from my I doohickey
On Jan 21, 2015, at 12:48 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] In my (limited) experience, a tube will only wear through if assembled without talc or was underinflated.
Linn
| Quote: | Folks, I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
Fly Safe,
Bill Judge
01/21/15
HCRV6(at)comcast.net Guest
Posted: Wed Jan 21, 2015 4:32 pm Post subject: Leakguard tubes belong in the trash |
What Linn said, but more so. I have over 1200 hours on a set of leakguard tubes that have been through three sets of tires so far. Use copious amounts of talc, in my case plain ole' baby powder on all surfaces, always very slightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it around to make sure, then deflate just enough to mate the wheel halves, making certain that the tube doesn't get pinched between the wheel halves. With all the talc you should have spread on the tube and inside the tire casing the tube moves around easily. After the bolts are tight, partially inflate the tube again and bounce it on the floor a couple of times to again make sure the tube has no kinks or folds, then deflate once more and do it again for good measure before finally inflating to your desired pressure. Takes a few minutes longer but sure beats flat tires.
BTW, with my leakguards my tires lose one psi or less in six or eight weeks.
Harry Crosby
RV-6, coming up on 1300 hours
To: "RV-List" <rv-list(at)matronics.com>
Sent: Wednesday, January 21, 2015 12:48:26 PM
Subject: Re: Leakguard tubes belong in the trash
Linn
| Quote: | Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
Fly Safe,
Bill Judge
01/21/15
_blank" data-mce-href="http://www.aeroelectric.com">www.aeroelectric.com
" target="_blank" data-mce-href="http://www.buildersbooks.com">www.buildersbooks.com
="_blank" data-mce-href="http://www.homebuilthelp.com">www.homebuilthelp.com
="_blank" data-mce-href="http://www.mypilotstore.com">www.mypilotstore.com
ank" data-mce-href="http://www.mrrace.com">www.mrrace.com
_blank" data-mce-href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
t="_blank" data-mce-href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
ta-mce-href="http://forums.matronics.com">http://forums.matronics.com
Posted: Wed Jan 21, 2015 4:53 pm Post subject: Leakguard tubes belong in the trash |
Just to expand .... pun intended .... when the valve core is removed I inflate/deflate the tube often using my air gun to prevent folds that Harry talks about. One other problem I've seen are the wrong size tube installed .... both too small and too big. Happens a lot when the plane uses 5.00-5 on the nose and 6.00-6 on the mains. Not all that hard to switch tubes.
Linn
On 1/21/2015 7:29 PM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote:
[quote] What Linn said, but more so. I have over 1200 hours on a set of leakguard tubes that have been through three sets of tires so far.  Use copious amounts of talc, in my case plain ole' baby powder on all surfaces, always very slightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it around to make sure, then deflate just enough to mate the wheel halves, making certain that the tube doesn't get pinched between the wheel halves. With all the talc you should have spread on the tube and inside the tire casing the tube moves around easily. After the bolts are tight, partially inflate the tube again and bounce it on the floor a couple of times to again make sure the tube has no kinks or folds, then deflate once more and do it again for good measure before finally inflating to your desired pressure. Takes a few minutes longer but sure beats flat tires.
Harry Crosby
From: "Linn Walters" <flying-nut(at)cfl.rr.com> (flying-nut(at)cfl.rr.com)
To: "RV-List" <rv-list(at)matronics.com> (rv-list(at)matronics.com)
Linn
Fly Safe,
Bill Judge
Gary.A.Sobek
Posted: Wed Jan 21, 2015 8:13 pm Post subject: Leakguard tubes belong in the trash |
Been running Michelim Air Stop tubes since May 2005. Almost 1,300 flight hours on the tubes according to log and not sure how many tires without going through the log more. Also using plain old baby talc with procedures and service like Harry Crosby. Looks like I had 1,671 hours on the tubes that Van provided. They needed air once a month.
Gary A. Sobek
2,954+ Flying Hours Pennsylvania, USA
Date: Wed, 21 Jan 2015 19:52:22 -0500
To: rv-list(at)matronics.com
Subject: Re: RV-List: Leakguard tubes belong in the trash
Linn
Harry Crosby
Linn
Fly Safe,
Bill Judge
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
get="_blank">http://www.matronics.com/Navigator?RV-List
Ollie Washburn
Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
Posted: Thu Jan 22, 2015 6:02 am Post subject: Leakguard tubes belong in the trash |
I'm with you Harry, I've had the same results. I do carry a spare nose tire tube.
Ollie
On Jan 21, 2015, at 7:29 PM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote:
[quote]What Linn said, but more so. I have over 1200 hours on a set of leakguard tubes that have been through three sets of tires so far. Use copious amounts of talc, in my case plain ole' baby powder on all surfaces, always very slightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it around to make sure, then deflate just enough to mate the wheel halves, making certain that the tube doesn't get pinched between the wheel halves. With all the talc you should have spread on the tube and inside the tire casing the tube moves around easily. After the bolts are tight, partially inflate the tube again and bounce it on the floor a couple of times to again make sure the tube has no kinks or folds, then deflate once more and do it again for good measure before finally inflating to your desired pressure. Takes a few minutes longer but sure beats flat tires.
Harry Crosby
From: "Linn Walters" <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
To: "RV-List" <rv-list(at)matronics.com (rv-list(at)matronics.com)>
Linn
">www.mrrace.com
_________________ Ollie RV6-A & Rans S7S
Central FL |
