gburdett1(at)frontier.com Guest
Posted: Mon Jan 19, 2015 1:36 pm Post subject: Alternator/regulator |
I have a JD/yanmar PM alternator and regulator with crowbar circuit. Voltage was starting to run over 15 volts at cruise rpms. Replaced battery and regulator, now hits 15.5 volts at anything over 2400 rpms on first test with a fully charged battery..????
Sent from my iPad
Posted: Tue Jan 20, 2015 6:11 am Post subject: Alternator/regulator |
Regulator is not properly adjusted for maintaining
a lead-acid battery. Unfortunately, most of the
off-the-shelf regulators for pm alternators do not
offer user adjustments.
Finding a drop-in replacement with friendlier
performance is about your only option. Your
problem is not uncommon and the folks who design,
manufacture and market these products seem oblivious
to the disservice they impose on their customers.
Posted: Tue Jan 20, 2015 7:08 am Post subject: Alternator/regulator |
Thanks Bob,
I have an odyssey 680 cell and the first regulator ran ok for about 75 hours and two years. I checked B&C and they do not recommend using their regulator with an 18-20 amp pm alternator.
Oddly enough, about 10 hours ago, I switched to a rear alt setup on a Corvair which meant the alt would spin a lot slower than the belt setup so it doesn't start getting up to voltage until about 15-1800 rpms. If there is nothing else to check,I will look for a higher quality regulator,maybe ,motorcycle . If you know of good ones.....
Sent from my iPad
Quote: | On Jan 20, 2015, at 8:08 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Tue Jan 20, 2015 7:40 am Post subject: Re: Alternator/regulator |
Measure the voltage between the regulator case and regulator voltage-sense-input terminal. If that voltage is at the desired set-point, then the regulator is doing its job and is not defective. And if that measured voltage is at the desired set-point, but aircraft system voltage is much higher, then there is a bad connection someplace between the alternator output and the regulator input. Possible trouble spots are wire terminals and alternator switch contacts.
Joe
_________________ Joe Gores |
Posted: Tue Jan 20, 2015 9:51 am Post subject: Alternator/regulator |
Thanks Joe,
The input to,the regulator comes directly from the aircraft bus through a switch and breaker and the alternator feeds directly to the bus through the regulator and breaker. . The input is reading what the bus is reading minus 2/10 volt due to resistance in circuit . This regulator has no adjustable set point. It is for a PM alternator.
Sent from my iPad
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=437306#437306
Posted: Tue Jan 20, 2015 11:06 am Post subject: Alternator/regulator |
Follow up on pm alt regulator, adding about 5 amps of load brings the voltage down to 14.2 at WOT .My plane does not use a lot of electricity and normal running with radios and some low draw instruments pulls only a few amps. Maybe it's a heat dissipation issue although the regulator is on the firewall under the panel with good air flow around it and it's cool today. So , when weather breaks,a will try a flight with everything on. Since I don't need cabin lights all the time, maybe a 50 watt switched resistor across the bus may be a good addition.
Sent from my iPad
Quote: | On Jan 20, 2015, at 11:50 AM, Gary Burdett <gburdett1(at)frontier.com> wrote:
Thanks Joe,
Sent from my iPad
> Joe
> Joe Gores
kjashton(at)vnet.net Guest
Posted: Tue Jan 20, 2015 12:14 pm Post subject: Alternator/regulator |
I see a lot of discussion on tractor and boat forums about the Yanmar alternator and its regulators, for example
http://ymowners.com/phpbb/viewtopic.php?f=1&t=1924
Try this search for a good bit of discussion:
https://www.google.com/search?q=yanmar+PM+alternator+voltage+regulator&biw=1531&bih=894&source=lnms&sa=X&ei=HrO-VN7ZCqOxsATijILgDg&ved=0CAUQ_AUoAA&dpr=1
Here is one disassembled
http://www.mytractorforum.com/showthread.php?t=258762
-Kent
Quote: | On Jan 20, 2015, at 10:07 AM, Gary Burdett <gburdett1(at)frontier.com> wrote:
Thanks Bob,
Sent from my iPad
> Bob . . .
yellowduckduo(at)gmail.co Guest
Posted: Tue Jan 20, 2015 1:44 pm Post subject: Alternator/regulator |
That seems strange to me. Perhaps you meant +2/10 volts.
My PM J.Deere controls the voltage at the regulator output. ie the
highest voltage in the system is at the regulator output lug. There is
no separate voltage sense wire on my regulator. Perhaps the Yanmar does
have one in which case you can trouble shoot much like for a
conventional wound field regulator.
A 0.2 volt difference anywhere while charging lightly seems high to me
but possible if the regulator is in fact not regulating and feeding many
amps into the battery. I assume you've verified the voltage with a
handheld digital voltmeter to rule out a bad indication.
I would give the same advice that Joe did. FWIW the easiest way I've
found to kill a J.Deere regulator is to start the engine without a
battery connected (actually I had a completely dead AGM battery
connected but it might as well have been disconnected) and yes the
failure mode was maximum output with no regulation. I encourage you to
get this fixed properly and not mess with adding load to manually lower
the voltage. These batteries do not like to be overcharged.
Ken
On 20/01/2015 12:50 PM, Gary Burdett wrote:
Quote: |
Thanks Joe,
Sent from my iPad
> Joe
> Joe Gores
user9253
Posted: Tue Jan 20, 2015 3:27 pm Post subject: Re: Alternator/regulator |
I agree with Ken that 2/10 volt drop seems high for a sense circuit that conducts very little current. Try measuring the voltage drop across the switch and then across the breaker to determine exactly where the 2/10 volt is being dropped. Also measure the voltage drop from the regulator case to ground, assuming the regulator is grounded through the case.
A jumper wire could be temporarily connected from the bus to the regulator input to see if the regulation improves.
Joe
Posted: Tue Jan 20, 2015 4:04 pm Post subject: Alternator/regulator |
Joe etal,
The 2/10 was just the voltage difference between different points in the circuit with the master turned on, no alternator charging. Just to illustrate an insignificant difference around the circuit and that the power input to the reg, sensing, was the same as the bus. The system is working, as Bob said earlier, the lawn tractor regulators are not always crafted to the highest quality as they are made meet lawn tractor standards, not aviation ones. Nevertheless , I will keep a watch on the voltage carefully until I find a replacement, giving it a dummy load does work, just not a permanent fix. Thanks for the help.
Sent from my iPad
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=437365#437365
Posted: Tue Jan 20, 2015 5:07 pm Post subject: Alternator/regulator |
Posted: Wed Jan 21, 2015 5:13 am Post subject: Alternator/regulator |
Bob,
Thanks for the clarification . I think I jumped to confusion.
Sent from my iPad
