Form blocks
frank goodnight
PostPosted: Wed Jan 14, 2015 6:56 am    Post subject: Form blocks Reply with quote
Making some form blocks and
have forgotten what angle to cut
the edges so the flanges will spring
back and end up at 90 degrees. Using
.025-- 6061T6. Would someone with
A better (younger) memory please
enlighten me. Thanks
Frank
frank goodnight
PostPosted: Wed Jan 14, 2015 7:27 am    Post subject: Form blocks Reply with quote
Frank
rickofudall
PostPosted: Sat Jan 17, 2015 7:42 am    Post subject: Form blocks Reply with quote
Frank, For the life of me I cannot find the little book on calculating spring back that I was given when I worked in the Cessna tooling machine shop years ago. My gut says that you need 4 degrees of compensation, but without my spring back and bend allowance book. I did find this:
http://www.custompartnet.com/calculator/bending-springback
Using their calculator it comes out to 2.3 degrees
Rick Girard
On Wed, Jan 14, 2015 at 8:52 AM, Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
--> Kolb-List message posted by: Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)>
Frank
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
Believe those who are seeking the truth, doubt those who find it.
-Andre Gide
Richard Pike
PostPosted: Sat Jan 17, 2015 4:35 pm    Post subject: Re: Form blocks Reply with quote
From Tony Bingelis' book "Sportplane Construction Techniques."
 Filesize:  158.58 KB
 Viewed:  7688 Time(s)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
frank goodnight
PostPosted: Wed Jan 21, 2015 8:25 am    Post subject: Form blocks Reply with quote
Thanks Richard,
I seem to remember seething about
7degrees.gues I will know soon as I cut one.
Frank
On Jan 17, 2015, at 9:41 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Frank, For the life of me I cannot find the little book on calculating spring back that I was given when I worked in the Cessna tooling machine shop years ago. My gut says that you need 4 degrees of compensation, but without my spring back and bend allowance book. I did find this:
Rick Girard
Frank
br> fts!)
-Andre Gide
ctric.com
uilthelp.com
otstore.com
matronics.com/contribution
cs.com
