russk50(at)gmail.com Guest
Posted: Thu Jan 15, 2015 11:32 am Post subject: pulleys |
Chris Davis — last time I knew, climbing ropes were all 9/16” diameter, so climber’s pulleys would be sized for that
Good luck,
Russ K
byoungplumbing(at)gmail.c Guest
Posted: Thu Jan 15, 2015 4:11 pm Post subject: pulleys |
Try marine cable pulleys
Boyd [quote][b]
capedavis(at)yahoo.com Guest
Posted: Thu Jan 15, 2015 5:03 pm Post subject: pulleys |
The marine cable pulleys that i posted the ad to show John were light weight stainless steel and I have used them as Inwas a commercial "off shore fisherman for 31 years they looked good to me and I need 5 the ones that aircraft spruce etc sells are $20 to35 each I got to say i cant afford them check theses out is this what you are sugestingMarine Hardware - Pulley Block With Removable Pin - WebRiggingSupply.com
Chris DavisKXP 503 492 hrsGlider PilotDisabled from crash building Firefly
On Thursday, January 15, 2015 7:15 PM, B Young <byoungplumbing(at)gmail.com> wrote:
Try marine cable pulleys Boyd
k" href="http://www.aeroelectric.com/">www.aeroelectric.com
et="_blank" href="http://www.buildersbooks.com/">www.buildersbooks.com
nk" href="http://www.homebuilthelp.com/">www.homebuilthelp.com
ank" href="http://www.mypilotstore.com/">www.mypilotstore.com
lank" href="http://www.mrrace.com/">www.mrrace.com
"http://www.matronics.com/contribution">http://www.matronics.com/contribution
"http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
"http://forums.matronics.com/">http://forums.matronics.com
Marine Hardware - Pulley Block With Removable Pin - ...Stainless Steel Marine Hardware > Pulley Block With Removable Pin Pulley Block With Removable Pin S.S. T304 with Nylon Sheave Part No. A B C D WT. EACH LBS. ...
View on www.webriggingsuppl...
Preview by Yahoo
Herbgh(at)nctc.com Guest
Posted: Thu Jan 15, 2015 5:09 pm Post subject: pulleys |
Chris
I think I have quite a few of the An pulleys...? Which numbers..? And I will check.. Herb
On 01/15/2015 07:00 PM, chris davis wrote:
[quote] The marine cable pulleys that i posted the ad to show John were light weight stainless steel and I have used them as Inwas a commercial "off shore fisherman for 31 years they looked good to me and I need 5 the ones that aircraft spruce etc sells are $20 to35 each I got to say i cant afford them check theses out is this what you are sugestingMarine Hardware - Pulley Block With Removable Pin - WebRiggingSupply.com
Chris Davis KXP 503 492 hrs Glider Pilot Disabled from crash building Firefly
On Thursday, January 15, 2015 7:15 PM, B Young <byoungplumbing(at)gmail.com> (byoungplumbing(at)gmail.com) wrote:
Marine Hardware - Pulley Block With Removable Pin - ... Stainless Steel Marine Hardware > Pulley Block With Removable Pin Pulley Block With Removable Pin S.S. T304 with Nylon Sheave Part No. A B C D WT. EACH LBS. ...
Preview by Yahoo
Posted: Thu Jan 15, 2015 9:46 pm Post subject: pulleys |
The pulley you linked to has a 1 inch diameter roller, the cables last longer with a larger diameter roller. I know sometimes you are limited by space limitations.
Boyd [quote][b]
