Battery
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
ershire
PostPosted: Mon Dec 29, 2014 7:04 am    Post subject: Battery Reply with quote
My battery seems to have given up. It's a Concorde RG380E/44 installed in 1998. Looking to replace I see the Gill G6381E is about half the cost and I've read some are using the Gill G50E about half the cost again. The Concorde battery is expensive and large but has been reliable. It is located in the right nose where I think the IFF was. The weight is required for CG. I self-start, no APU. My battery tender says not for use with Gill batteries, what's the difference? Any recommendations or thoughts would be appreciated.
Jon
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Dawg
PostPosted: Mon Dec 29, 2014 8:26 am    Post subject: Battery Reply with quote
Batteries plus
2 big 1025 CCA 12 volt batteries
Or the odysse batteries. two of them fit in the battery box. (925s)
2 Sears die hard batteries fit on top as well without battery box.
couple hundred bucks total.
Jon
http://forums.matronics.com/viewtopic.php?p=436389#436389
Dawg
ershire
PostPosted: Mon Dec 29, 2014 8:31 am    Post subject: Battery Reply with quote
Thanks, the battery box was converted into a tool box. I also need the 80lbs. I have to go out to the airplane and look at it. On Dec 29, 2014 11:27 AM, "William Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote]--> L29-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
Batteries plus
Or the odysse batteries. two of them fit in the battery box. (925’s)
On Dec 29, 2014, at 8:04 AM, ershire <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
> --> L29-List message posted by: "ershire" <jonairway(at)gmail.com (jonairway(at)gmail.com)>
> Jon
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
List" target="_blank">http://www.matronics.com/Navigator?L29-List
bculberson(at)staraviatio
PostPosted: Mon Dec 29, 2014 9:02 am    Post subject: Battery Reply with quote
The Odysseys work great! I have just replaced my first two after 7 years of service and only replaced them because I was sure they would fail eventually. I still use them in non-aviation related uses. Six of them will start MiG-15/17 without much of a problem.
I am surprised at your W&B issue. I am assuming there are no balance plates in the tail fairing remaining?
Bill C
N39DE
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Jon S
Sent: Monday, December 29, 2014 10:31 AM
To: l29-list(at)matronics.com
Subject: Re: L29-List: Battery
Batteries plus
Jon
br> fts!)
_-============================================================_-=_-=       -- Please Support Your Lists This Month --_-=           (And Get Some AWESOME FREE Gifts!)_-=_-=   November is the Annual List Fund Raiser.  Click on_-=   the Contribution link below to find out more about_-=   this year's Terrific Free Incentive Gifts provided
5
6
7
8
9
_-=
_-=
_-=
_-=
_-=
_-=
5
_-=
6
_-=
7
_-=
8
_-=
9
ershire
PostPosted: Mon Dec 29, 2014 9:27 am    Post subject: Battery Reply with quote
Hi Bill.
Maybe I'm missing something. My battery weight 80lbs plus I have 65lbs of lead in the nose to keep CG. With 40lbs in the nose the nose wheel barely stayed on the ground. I see the bolts in the tail but no lead. Where else should I be looking? On Dec 29, 2014 12:04 PM, "Bill Culberson" <bculberson(at)staraviation.com (bculberson(at)staraviation.com)> wrote:
Bill C
N39DE
From: owner-l29-list-server(at)matronics.com (owner-l29-list-server(at)matronics.com) [mailto:owner-l29-list-server(at)matronics.com (owner-l29-list-server(at)matronics.com)] On Behalf Of Jon S
To: l29-list(at)matronics.com (l29-list(at)matronics.com)
Subject: Re: Battery
Batteries plus
Jon
br> fts!)
  <==================[u]www.homebuilthelp.com[/url][b]www.mypilotstore.com[b]http://www.matronics.com/contribution[/url]</                      -Matt Dralle, List Admi         - The L29-List Email Forumve Search & Download, 7-Day Browse, Chat, FAQ,[/b]
<="http://www.matronics.com/Navigator?L29-List" target="_blank">http://www.matronics.com/Navigator?L29-List
http://forums.matronics.com==== [/quote]
PostPosted: Mon Dec 29, 2014 10:07 am    Post subject: Battery Reply with quote
It may be a manufacturer configuration difference based on the air force it was originally flying in. Mine is a Czech Air Force “C” model, has no plates in the tail cone (just bolts like yours) and can be picked up by the nose when under 200 L very easily. I would have to defer to the list on this one, (Bill Geipels) I would not have thought they would be that different in W&B.
You could put in multiple sets of batteries. if you have lead installed it might as well be a working battery rather than just dead weight. My MiG-15 UTI had the same problem, I put in 8 in the gun bay just to get rid of the dead batteries the last group had installed as ballast. The start is better/faster and the less voltage drop you have, the longer the starter motor will last.
251 716 8119
Sent: Monday, December 29, 2014 11:28 AM
Subject: RE: L29-List: Battery
Hi Bill.
On Dec 29, 2014 12:04 PM, "Bill Culberson" <bculberson(at)staraviation.com<mailto:bculberson(at)staraviation.com>> wrote:
Bill C
N39DE
From: owner-l29-list-server(at)matronics.com<mailto:owner-l29-list-server(at)matronics.com> [mailto:owner-l29-list-server(at)matronics.com<mailto:owner-l29-list-server(at)matronics.com>] On Behalf Of Jon S
To: l29-list(at)matronics.com<mailto:l29-list(at)matronics.com>
On Dec 29, 2014 11:27 AM, "William Geipel" <l129bs(at)gmail.com<mailto:l129bs(at)gmail.com>> wrote:
Batteries plus
On Dec 29, 2014, at 8:04 AM, ershire <jonairway(at)gmail.com<mailto:jonairway(at)gmail.com>> wrote:
Jon
br> fts!)
r> > com" target="_blank">www.aeroelectric.com<http://www.aeroelectric.com>
w.buildersbooks.com<http://w.buildersbooks.com>" target="_blank">www.buildersbooks.com<http://www.buildersbooks.com>
p.com<http://p.com>" target="_blank">www.homebuilthelp.com<http://www.homebuilthelp.com>
e.com<http://e.com>" target="_blank">www.mypilotstore.com<http://www.mypilotstore.com>
" target="_blank">www.mrrace.com<http://www.mrrace.com>
<==================<-= * AeroElectric www.aeroelectric.com<http://www.aeroelectric.com>kstore ww * HomebuiltHELP <http://www.buildersbooks.com> www.homebuilthelp.com<http://www.homebuilthelp.com>w--> <http://www.mrrace.com> http://www.matronics.com/contribution
delfin29(at)me.com
PostPosted: Wed Dec 31, 2014 4:38 am    Post subject: Battery Reply with quote
Hi,How is set your trim for take-off ?
Jean de Roubin
Le 29 déc. 2014 à 17:27, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> a écrit :
Hi Bill.
Bill C
N39DE
From: owner-l29-list-server(at)matronics.com (owner-l29-list-server(at)matronics.com) [mailto:owner-l29-list-server(at)matronics.com (owner-l29-list-server(at)matronics.com)] On Behalf Of Jon SSent: Monday, December 29, 2014 10:31 AMTo: l29-list(at)matronics.com (l29-list(at)matronics.com)Subject: Re: Battery
--> L29-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>Batteries plus2 big 1025 CCA 12 volt batteriesOr the odysse batteries. two of them fit in the battery box. (925’s)2 Sears die hard batteries fit on top as well without battery box.couple hundred bucks total.On Dec 29, 2014, at 8:04 AM, ershire <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:> --> L29-List message posted by: "ershire" <jonairway(at)gmail.com (jonairway(at)gmail.com)>>> My battery seems to have given up. It's a Concorde RG380E/44 installed in 1998. Looking to replace I see the Gill G6381E is about half the cost and I've read some are using the Gill G50E about half the cost again. The Concorde battery is expensive and large but has been reliable. It is located in the right nose where I think the IFF was. The weight is required for CG. I self-start, no APU. My battery tender says not for use with Gill batteries, what's the difference? Any recommendations or thoughts would be appreciated.>> Jon>>>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.php?p=436389#436389>>>>>>>>>>===========br> fts!)r> > com" target="_blank">www.aeroelectric.comw.buildersbooks.com" target="_blank">www.buildersbooks.comp.com" target="_blank">www.homebuilthelp.come.com" target="_blank">www.mypilotstore.com" target="_blank">www.mrrace.comtarget="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin.===========List" target="_blank">http://www.matronics.com/Navigator?L29-List===========FORUMS -_blank">http://forums.matronics.com=========== <==================[u][/u][u]<-= * AeroElectric www.aeroelectric.comkstore ww * HomebuiltHELP www.homebuilthelp.com[u][b]www.mypilotstore.comw--> http://www.matronics.com/contribution[/b][/u][/u]
<="http://www.matronics.com/Navigator?L29-List" target="_blank">http://www.matronics.com/Navigator?L29-List[u]
[/u]
class="">www.aeroelectric.com
href="http://www.buildersbooks.com/" class="">www.buildersbooks.com
class="">www.homebuilthelp.com
class="">www.mypilotstore.com
class="">www.mrrace.com
class="">http://www.matronics.com/contribution
class="">http://www.matronics.com/Navigator?L29-List
class="">http://forums.matronics.com
ershire
PostPosted: Wed Dec 31, 2014 6:00 am    Post subject: Re: Battery Reply with quote
Hi Jean,
My trim is 2 deg aft for take offs and landings and 2.5 deg forward in cruise. Here is my W&B and a spreadsheet I created with formulas to do the math for you. Please let me know if anyone finds errors.
L-29 W&B Calculator.xlsx
W&B Calculator
 Filename:  L-29 W&B Calculator.xlsx
 Filesize:  16.75 KB
 Downloaded:  752 Time(s)
L-29 inch.docx
W&B inches
 Filename:  L-29 inch.docx
 Filesize:  112.72 KB
 Downloaded:  710 Time(s)
Dawg
PostPosted: Wed Dec 31, 2014 6:04 am    Post subject: Battery Reply with quote
What else have you removed? I removed everything, 425 pounds. I have 103 lbs in the nose area.If you use the 2 big auto batteries, they weigh enough that it wont matter. If you go with odysseys it wouldnt be a big enough change to really notice assuming everything else is in order.
My takeoff trim is approximately 0. At high speed I use a lot of nose down. I did use the Gill for years until it died. Now I spend $200 instead of $2,000.
bill
On Dec 31, 2014, at 5:38 AM, delfin29(at)me.com (delfin29(at)me.com) wrote:
[quote]Hi,How is set your trim for take-off ?
Jean de Roubin
Le 29 dc. 2014 17:27, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> a crit :
Hi Bill.
Bill C
N39DE
--> L29-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>Batteries plus2 big 1025 CCA 12 volt batteriesOr the odysse batteries. two of them fit in the battery box. (925s)2 Sears die hard batteries fit on top as well without battery box.couple hundred bucks total.On Dec 29, 2014, at 8:04 AM, ershire <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:> --> L29-List message posted by: "ershire" <jonairway(at)gmail.com (jonairway(at)gmail.com)>>> My battery seems to have given up. It's a Concorde RG380E/44 installed in 1998. Looking to replace I see the Gill G6381E is about half the cost and I've read some are using the Gill G50E about half the cost again. The Concorde battery is expensive and large but has been reliable. It is located in the right nose where I think the IFF was. The weight is required for CG. I self-start, no APU. My battery tender says not for use with Gill batteries, what's the difference? Any recommendations or thoughts would be appreciated.>> Jon>>>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.php?p=436389#436389>>>>>>>>>>===========br> fts!)r> > com" target="_blank">www.aeroelectric.comw.buildersbooks.com" target="_blank">www.buildersbooks.comp.com" target="_blank">www.homebuilthelp.come.com" target="_blank">www.mypilotstore.com" target="_blank">www.mrrace.comtarget="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin.===========List" target="_blank">http://www.matronics.com/Navigator?L29-List===========FORUMS -_blank">http://forums.matronics.com=========== <==================[u][/u][u]<-= * AeroElectric www.aeroelectric.comkstore ww * HomebuiltHELP www.homebuilthelp.com[u][b]www.mypilotstore.comw--> http://www.matronics.com/contribution[/b][/u][/u]
[/u]
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
href="http://www.mypilotstore.com/">www.mypilotstore.com
href="http://www.mrrace.com/">www.mrrace.com
href="http://www.matronics.com/Navigator?L29-List">http://www.matronics.com/Navigator?L29-List
Dawg
Dawg
PostPosted: Wed Dec 31, 2014 6:10 am    Post subject: Battery Reply with quote
my empty weight is 4905. The Viper weighs the same as the stock engine but sits 18 aft of the stock engine.
So W&B was a big change.
bill
On Dec 31, 2014, at 7:00 AM, ershire <jonairway(at)gmail.com> wrote:
Hi Jean,
http://forums.matronics.com/viewtopic.php?p=436440#436440
http://forums.matronics.com//files/l_29_wandb_calculator_463.xlsx
http://forums.matronics.com//files/l_29_inch_989.docx
Dawg
ershire
PostPosted: Wed Dec 31, 2014 6:35 am    Post subject: Re: Battery Reply with quote
Bill,
This is interesting, I originally had 103lbs of lead in the nose plus the heavy Concorde batter that just died see (xls sheet 1) and everything that could be removed I think was removed. In this configuration the nose gear was almost collapsed as it sat on the ramp. I played with the W&B and with 65lbs removed the plane would sit very tail low and cruise was 3+ degrees forward, with 38lbs removed as it is today (xls sheet 4) my trim is 2-2.5 deg forward in cruise and the plane sits level. My empty weight is 5155lbs. xls sheet 3 is my current W&B in mm for those who don't use inches.
colyergreg(at)aol.com
PostPosted: Wed Dec 31, 2014 6:59 am    Post subject: Battery Reply with quote
Odyssey PC925's.. I used 2 in stock battery box. Awesome.. I use the same in my T-33's... But 4 or 6 of them. Best bang for the dollar for sure
Gregory Colyer
www.AceMakerAirshows.com
415-531-0970
Join us on Facebook
www.facebook.com/AceMakerAirshows
Twitter (at)AceMaker33
On Dec 31, 2014, at 6:03 AM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
[quote]What else have you removed? I removed everything, 425 pounds. I have 103 lbs in the nose area.If you use the 2 big auto batteries, they weigh enough that it won’t matter. If you go with odysseys it wouldn’t be a big enough change to really notice assuming everything else is in order.
bill
Jean de Roubin
Hi Bill.
Bill C
N39DE
[/u]
ot;">www.aeroelectric.com
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
ist"">http://www.matronics.com/Navigator?L29-List
ershire
PostPosted: Tue Nov 17, 2015 5:36 am    Post subject: Re: Battery Reply with quote
If running batteries in series, what wire gauge for the interconnect, pos/neg leads? If your starting a viper how many amps are you seeing? The 701 is about <400.
jetblast1(at)me.com
PostPosted: Tue Nov 17, 2015 6:11 am    Post subject: Battery Reply with quote
I have mine connected by automotive battery connectors that are very thick. Don't know the gauge. Can be obtained at any auto supply shop. I don't have a viper.
John F. Cabrera
http://forums.matronics.com/viewtopic.php?p=449607#449607
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
