Tire Pressures
Tunahawk
PostPosted: Mon Dec 22, 2014 6:55 pm    Post subject: Tire Pressures Reply with quote
To All Hi,
Found a few conlicts in the our AA5A POH dated Feb 77 wrt tire pressures,
Limitations Chapter has 35/25 Main/Nose respectively, as does our placard in the aircraft and stickers on the Wheel fairings.
Chapter 8, Servicing has 24/21
Maintenance Publication in Servicing has 24/21 in two separate places
My uninformed opinion is that we should use 24/21 for our 1977 AA5A.
Cheers,
Bill Chambers
RonMillmanCPA(at)msn.com
PostPosted: Mon Dec 22, 2014 7:08 pm    Post subject: Tire Pressures Reply with quote
I know when the tire pressure on my AA5B is low:
It's hard to pull.
Ron Millman, AA5B (at) KWHP, Los Angeles.​
On Mon, Dec 22, 2014 at 6:54 PM, Bill Chambers <metuna(at)earthlink.net (metuna(at)earthlink.net)> wrote:
[quote] To All Hi,
Cheers,
Bill Chambers
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
st" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
tp://forums.matronics.com
teamgrumman(at)yahoo.com
PostPosted: Mon Dec 22, 2014 7:23 pm    Post subject: Tire Pressures Reply with quote
I use 32 main and 30 nose. Anything less makes it too hard to maneuver the plane by hand.
Gary
Sent from my iPad
On Dec 22, 2014, at 6:54 PM, Bill Chambers <metuna(at)earthlink.net (metuna(at)earthlink.net)> wrote:
[quote] To All Hi,
Cheers,
Bill Chambers
