Icom a210 display problems
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
Rebel56
PostPosted: Thu Dec 11, 2014 12:36 pm    Post subject: Icom a210 display problems Reply with quote
Less than 30 hours on unit, but out of warranty. Radio works well for a while, then without warning display will dim then disappear. Dial lights are still on and can transmit and receive but nothing showing on display. Have already replaced the ribbon cable.. No problem for 10 hours of flying, then problem started again. Power off and on works sometimes, but most times display does not light up. Even tried turning dimmer function off.
Any ideas?
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
tim2542(at)sbcglobal.net
PostPosted: Thu Dec 11, 2014 1:38 pm    Post subject: Icom a210 display problems Reply with quote
Ship it to Icom with a letter explaining the issue. They are a whole lot better to deal with than Garmin. I had a squelch issue on mine out of warranty they fixed for a reasonable amount. IIRC shipping and repairs including a software update was less than $100
Any ideas?
http://forums.matronics.com/viewtopic.php?p=435602#435602
jdubner
PostPosted: Thu Dec 11, 2014 3:40 pm    Post subject: Icom a210 display problems Reply with quote
The A210 has an EL display and I would start by looking at the voltages supplied
to it. The service manual shows IC75, a BD9001F IC supplying 16V and IC2, an
NJM2307001 IC supplying 3V.
Email me if you'd like me to email you the service manual (a 10MB file).
Joe
RV-8A
Independence, OR
Rebel56 wrote, On 12/11/2014 12:36:
Any ideas?
 Filesize:  38.07 KB
 Viewed:  13292 Time(s)
Independence, OR
Rebel56
PostPosted: Thu Dec 11, 2014 5:11 pm    Post subject: Re: Icom a210 display problems Reply with quote
Thanks Joe, but I am not that tech savvy. Best I can do is clean the basic contacts and remove the ribbon cable, but beyond that I would be dangerous. Shocked
yellowduckduo(at)gmail.co
PostPosted: Thu Dec 11, 2014 6:08 pm    Post subject: Icom a210 display problems Reply with quote
Any chance they made the squelch more effective for you?
thanks
Ken
> Any ideas?
PostPosted: Thu Dec 11, 2014 6:35 pm    Post subject: Icom a210 display problems Reply with quote
Yes, the issue I had was continuous open squelch, they said it was in spec but tightened it up for me. I bought it from a shop in Canada, then when I needed service shipped it to Icom America. That was a mistake evidently, somehow they are two separate entities and could not/would not warrant it. Wasn't too happy about, but still least the charge was reasonable. Seems like it was $35, then shipping both ways.
On Dec 11, 2014, at 6:08 PM, C&K <yellowduckduo(at)gmail.com> wrote:
thanks
Ken
> Tim
>> Any ideas?
PostPosted: Thu Dec 11, 2014 7:13 pm    Post subject: Icom a210 display problems Reply with quote
Thanks Tim
That's funny because I purchased in USA but am in Canada. I rather
suspected that mine would have to go back to the US.
A dsub capacitor filter on the leads to my glass ADI helped a bit but
even with the radio on a separate battery I have to use the max squelch
setting.
It is a lot more sensitive than the older A200. Good to know they can
apparently adjust it and I'll talk to them again.
Ken
> Tim
> thanks
> Ken
>> Tim
>>> Any ideas?
>>> Read this topic online here:
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
