monowheel brake caliper mounting position
rowlandcarson(at)gmail.co
PostPosted: Thu Dec 04, 2014 3:56 am    Post subject: monowheel brake caliper mounting position Reply with quote
I seem to recall a discussion some years back about the optimum position for mounting the monowheel brake caliper, because folk found in service that there was a problem with the standard position.
I’ve searched the Matronics archives for the Europa list but have not found a relevant message thread.
The manual illustration shows the brake caliper mounted in-line with the landing gear arm, but (without drilling any new holes) there are 2 other possibilities.
Can anyone tell me which one is the optimum in practice?
And is there any LAA Engineering issue with changing the brake mounting?
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
pete(at)lawless.info
PostPosted: Thu Dec 04, 2014 4:35 am    Post subject: monowheel brake caliper mounting position Reply with quote
Hi Roland
Just rotate it round by one hole so the caliper is pointing backwards
more or less horizontal. Mine needed a small bulge made in the side of
the wheel well to accommodate it. The idea is that if you get a flat
tyre it does not get ripped to pieces by rubbing on the caliper.
Pete
G-RMAC #109
in friendship
Rowland
Fred Klein
PostPosted: Thu Dec 04, 2014 9:22 pm    Post subject: monowheel brake caliper mounting position Reply with quote
Can anyone offer a photo of this revised brake location/configuration?…I’d be much obliged…Fred
On Dec 4, 2014, at 4:35 AM, Pete Lawless <pete(at)lawless.info> wrote:
Hi Roland
Just rotate it round by one hole so the caliper is pointing backwards more or less horizontal. Mine needed a small bulge made in the side of the wheel well to accommodate it. The idea is that if you get a flat tyre it does not get ripped to pieces by rubbing on the caliper.
Pete
G-RMAC #109
> in friendship
> Rowland
Remi Guerner
PostPosted: Fri Dec 05, 2014 12:38 am    Post subject: Re: monowheel brake caliper mounting position Reply with quote
Fred,
I changed the position of my caliper a few years ago. The attached picture shows how it is now. This position was choosen so that, when in the landing gear is in the retracted position, the caliper does not interfere with the starboard rudder cable as it did before and it does not protude in the slipsream.
Remi
 Filesize:  272.51 KB
 Viewed:  6868 Time(s)
Fred Klein
PostPosted: Fri Dec 05, 2014 6:29 am    Post subject: monowheel brake caliper mounting position Reply with quote
Thanks Remi…picture’s worth 1000 words…Fred
On Dec 5, 2014, at 12:38 AM, Remi Guerner <air.guerner(at)orange.fr (air.guerner(at)orange.fr)> wrote:
--> Europa-List message posted by: "Remi Guerner" <air.guerner(at)orange.fr (air.guerner(at)orange.fr)>Fred,I changed the position of my caliper a few years ago. The attached picture shows how it is now. This position was choosen so that, when in the landing gear is in the retracted position, the caliper does not interfere with the starboard rudder cable as it did before and it does not protude in the slipsream. RegardsRemiRead this topic online here:http://forums.matronics.com/viewtopic.php?p=435354#435354Attachments: http://forums.matronics.com//files/p2180004a_103.jpg
JonSmith
PostPosted: Fri Dec 05, 2014 10:42 pm    Post subject: Re: monowheel brake caliper mounting position Reply with quote
Hi Roland, the (revised) brake caliper position was covered in the factory tech talk issue 22 on page 13. Attached is a copy of the page. I bought a new mounting bracket from the factory some years ago to replace the original design on my classic. Five minute job (almost) to replace it and it saves carving holes in the wheel well sides! Cheers!
 Filesize:  676.16 KB
 Viewed:  6827 Time(s)
G-TERN
Classic Mono
PostPosted: Sat Dec 06, 2014 12:25 am    Post subject: monowheel brake caliper mounting position Reply with quote
Jon - thanks for the info. I hadn’t realised this discussion was soooo long ago! I do have a SX kit and so my brake caliper is already in the recommended position. I can relax now (about this issue, anyway).
in friendship
Rowland
