Fusible links
fvalarm(at)rapidnet.net
PostPosted: Tue Dec 02, 2014 9:45 am    Post subject: Fusible links Reply with quote
I can't find the detail in the book. When making a fusible link, the inner
"fuse" wire is 22 AWG in this case. Is it necessary to strip the insulation
off?
Bevan
PostPosted: Tue Dec 02, 2014 11:42 am    Post subject: Fusible links Reply with quote
At 11:44 2014-12-02, you wrote:
--> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net>
off?
I presume you're asking about the insulation on the
22AWG wire? No, in fact, you ADD insulation over it
See http://tinyurl.com/msx5ofe
Where are you considering the use of a fusible link?
I crafted that comic-book waaayyy back when we were
wrestling with the notion of extending the BUS in a
fuse block up to a one-terminal-BUS at the input side
of the alternator field breaker. A breaker upstream
of a crow-bar ov protection module.
I think we also dabbled with the use of fusible links
on the meter-leads to a shunt. As a general rule, the
fusible link is attractive only when a fuse holder
is a little 'messy' . . . The TC fleet has used two
fuses in clips to protect ammeter wires for decades.
[img]cid:.0[/img]
The last time I was able to walk down the A36
production line (about 10 years ago) the clipped-in
fuses for various 'minor' tasks were quite visible.
The need to extend the bus to accommodate the only
circuit breaker in the airplane was a special case.
Like Figure Z-13/20, and to some extend Z-19, I've
regretted having published the ideas. While useful
and appropriate to the special cases, they've
morphed into other forms that may or may not
have been through PCQDR (preliminary, critical
and qualification design review).
Can or should we talk about it?
 Filesize:  143.71 KB
 Viewed:  5466 Time(s)
PostPosted: Tue Dec 02, 2014 1:55 pm    Post subject: Fusible links Reply with quote
Thanks Bob,
I had done it on mine a couple years back, but the other day I was helping a hangar neighbour make some improvements. He has a rear mounted battery on a BD4 (engine in front). He has one electronic ignition which was powered by an 18 awg wire connected on the firewall at the input power terminal at the starter solenoid. This fat wire was only powered when the master solenoid (located in back next to the battery) was active. Not ideal for electrically dependant ignition. There was a spare 18 awg wire already running all the way back to the battery and the owner wanted to use that. I suggested that we fuse it but that fuse would have to activate "slower" than the breaker on the panel. I therefore suggested a fusible link and that is where I crossed the line. Since it was such a good idea, and I had suggested it, it was suggested that I do it Smile Not a problem since I had materials left over. Just couldn't remember if the 22awg wire (now hidden under the silicone impregnated sleeve) on my RV7 had been stripped or not. My thinking initially was that it must have been stripped because we really don't want any combustible material "inside" the fuse if possible. It didn't strip well, so I re-did it without stripping as you have confirmed. Thank you.
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Tuesday, December 02, 2014 11:41 AM
Subject: Re: Fusible links
off?
[img]cid:776342221(at)02122014-0CF9[/img]
 Filesize:  143.71 KB
 Viewed:  5464 Time(s)
PostPosted: Wed Dec 03, 2014 8:27 am    Post subject: Fusible links Reply with quote
At 15:53 2014-12-02, you wrote:
Thanks Bob,
Okay, this is a situation similar
to the "bus extension" to panel mounted
breaker for a crowbar ov protection
system.
Keep in mind that circuit protection is
to keep the smoke in wires. Further, the
'rule of thumb' for always hot wires from
a battery bus is to protect at 5A or less
Given that fuses are MUCH faster than
breakers . . . 7A fuse is a comfortable
alternative to the 5A breaker.
This is a convention driven by concerns
for crash safety. Limit the energy available
on an always-hot wire for the purposes of
reducing risk of post crash fire. I don't
believe for a minute that anyone did any
tests combined with statistical analysis
to come up with that 5A number . . . but
intuitively, one finds comfort in protecting
an always-hot wire at the lowest practical
value.
I suspect that the electronic ignition runs
on MUCH less than 5A. What size is the panel
mounted breaker? If it were my airplane,
I'd drive the ignition supply wire from the
battery through a 7A fuse and eliminate the
panel mounted breaker.
If that breaker EVER trips, then there's
something seriously wrong with either
the ignition system or the power pathway
feeding it . . . the notion of resetting it
is does not stand on favorable probabilities
for recovery-by-reset. A 7A fuse, 5A breaker,
or fusible link in the tail does not alter
the probabilities . . .
ceengland7(at)gmail.com
PostPosted: Wed Dec 03, 2014 9:17 am    Post subject: Fusible links Reply with quote
On 12/3/2014 10:26 AM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
Thanks Bob,
system.
value.
Probably a safe assumption for 'traditional' a/c engines with stock fuel
delivery, but different for 'alternative' (automotive-based) engines and
increasingly, a/c engines, more current is required. Most
automotive-based engines use high pressure fuel injection which must be
included in current calculations. There's now a growing wave of
automotive style injection on a/c engines, as well. High pressure
gerotor or roller-vane fuel pumps typically draw 6-10 amps continuous.
Even the little turbine style pumps (which must be installed inside the
fuel tank; the input must be kept flooded) typically draw 3-4 amps. So
total current demand to keep an 'electronic' engine running usually
exceeds 10 amps; often as high as 15.
So what's the solution? Dedicated fuse bus at the battery to distribute
power to the various engine control components?
PostPosted: Wed Dec 03, 2014 11:20 am    Post subject: Fusible links Reply with quote
fuel delivery, but different for 'alternative' (automotive-based)
engines and increasingly, a/c engines, more current is required. Most
be included in current calculations. There's now a growing wave of
continuous. Even the little turbine style pumps (which must be
installed inside the fuel tank; the input must be kept flooded)
typically draw 3-4 amps. So total current demand to keep an
'electronic' engine running usually exceeds 10 amps; often as high as 15.
distribute power to the various engine control components?
He was talking about an ignition system. Energy
to light the fires is quite nominal. Not aware of
any ignition that requires more than 3A. Lightspeed's
flame throwing CD ignition runs 2.6A at 2700 rpm on
a 6 cyl engine.
Fuel delivery is another matter and, as you've noted,
can be all over the map. TBI systems run on a few amps
while some 40+ psi rail fed injector systems can be
MUCH higher.
I'd treat this like the heavy duty e-bus feeder
illustrated in Z-32 . . . except the e-bus alt feed
switch becomes a fuel system control switch. The
relay could be a solid state device or one of the
sealed electro-mechanical critters.
This comports nicely with the TC aircraft philosophy
for achieving a Max-Cold state of all wires when
crew operated switches are placed to OFF.
PostPosted: Wed Dec 03, 2014 2:15 pm    Post subject: Fusible links Reply with quote
At 14:08 2014-12-03, you wrote:
Not aware of
a 6 cyl engine.
If you are using a PSRU (propeller speed reduction unit) on a 6
cylinder engine you will have a higher engine RPM, perhaps in the
range of 4 - 5 k rpm. This higher speed will translate to a higher
current flow to the electronic CD ignition. An MSD 6A automotive CD
ignition module is specified at 1A / 1K RPM, which translates to
perhaps 5A worst case.
Hmmmm . . . that's too bad. There's no good reason
for ignition systems to draw that much current.
I've talked with the guys at EmagAir about this
several times. A take-away from those conversations
says that it's most important to get an adequate spark
delivered right on time. Magnetos have proven their
ability to deliver adequate sparks while running . . .
and they're certainly not flame throwers. Certainly
hard to fiddle with the timing . . . and you need
some kind of monkey motion like impulse couplers or
shower-of-sparks to effect nice starts . . . but
there's hundreds of thousands flying with few
critical issues.
Being able to advance the spark at low manifold
pressures gets you some benefit . . .but the spark
doesn't need to be any hotter . . . in fact, worst
case sparking requirements are at max cylinder pressure
which probably means a boosted engine at max retard
timing.
The legacy Kettering coil, condenser, points system
delivers about 30-40 mJ per spark. For a 6-cyl engine
running 2400 rpm, 40 rev/sec, 3 sparks per rev, energy
at the plugs comes to about 120 mJ per rev or 4800
mJ per second. Assume a really lousy system efficiency
of say 50% and we need to draw 9.6 watts from the
ship's bus or about 700 mA.
Now, deliver that energy even while cold and with
a soggy battery . . . and be able to advance the
timing at low manifold pressures, and you've got
a perfectly adequate ignition system.
So be curious and skeptical when someone says
their 'flame throwing ignition system' is going
to do great things for your airplane. If you're
flying a racer, maybe. If you've got a nice
point-a to point-b transportation machine that
carries battery energy to implement Plan-B, perhaps
all that flame at the spark plugs suggests a
need to re-think the planning.
Elegant solutions benefit from good stewardship
of energy. It starts with the airfoils and
extends down to batteries and fuel aboard.
PostPosted: Wed Dec 03, 2014 2:56 pm    Post subject: Fusible links Reply with quote
Thanks Bob,
The literature that came with the LightSpeed says the breaker should be 7.5
amp. (IO-540) You still recommend a 5 amp breaker (since he really wants
some form of disconnect on the panel) and a (??? Value fuse, fusible link,
breaker)at the rear for the feed from the battery.
Perhaps I should suggest a 5 or 7.5 amp slow blo fuse at the battery, and a
simple switch on the panel in place of the breaker if he must have a
disconnect.
Bevan
lyleapgmc
PostPosted: Wed Dec 03, 2014 7:10 pm    Post subject: Fusible links Reply with quote
Hi,
I've been involved in electronics for some 30 years. I know what a
fusible link is in an automobile. They do come in a variety of designs,
some very much like a fuse as we know them.
I have always questioned the value of a fusible link such as is used in
automobiles. They are a length of wire, usually 4 wire gauges smaller
than the wire they are protecting. They are most often a hassle to
replace. Why would not a common fuse perform the same function and be
much more easily replaced?
Inquiring minds want to know,
Lyle
> Not aware of
> a 6 cyl engine.
Lyle
Sent from my Gateway E4610D desktop
PostPosted: Wed Dec 03, 2014 8:53 pm    Post subject: Fusible links Reply with quote
The advantages of the fusible link in this case is:
Must be slower acting than the breaker. I blew quite a few fuses until I
found that I needed a fuse of about double the value to ensure the breaker
trips first. This would suggest a 15 amp fuse which is larger than desired.
Robust (although a fuse in an inline holder is equally suitable in this
regard.)
There's no place to mount a breaker near the battery where it is easily
accessible and yet not in the way for battery access through the small panel
where it is located.
Cost and availability. We're trying to get this airplane back in the air so
it can go home. They can make more permanent changes there.
Bevan
PostPosted: Thu Dec 04, 2014 9:15 pm    Post subject: Fusible links Reply with quote
Bob ,
Was that photo of the fuses/wiring in the engine compartment?
Bevan
off?
[img]cid:307341305(at)05122014-0D5B[/img]
 Filesize:  143.71 KB
 Viewed:  5438 Time(s)
