Deems Davis
Posted: Tue Jun 27, 2006 4:34 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Garey Wittich wrote:
THIS IS NOT "SPAM", but comes from 600+ hours of
research I did while building my RV-8A.
If it walks like a duck and quacks like a duck it's a Duck!
Deems Davis # 406
Fuse
http://deemsrv10.com/
klwerner(at)comcast.net Guest
Posted: Tue Jun 27, 2006 4:43 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Who's up for a DUCK HUNT ! Bring yer shotgun & some beer!
johnwcox(at)pacificnw.com Guest
Posted: Tue Jun 27, 2006 5:16 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Maybe I should buy a copy of this duck, convert it to PDF and send it to
Tim for the RV University library. What say the masses? Has someone
already contributed to Garey's retirement fund in the Bahamas?
I am at over 4,000 hours of research and wouldn't consider charging for
personal opinion, even when backed by actual documentation and life
experience.
John - $00.02
GenGrumpy(at)aol.com Guest
Posted: Tue Jun 27, 2006 5:27 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
If it isn't copyrighted, then go for it!!
grumpy #40404
In a message dated 6/27/2006 8:17:45 PM Central Standard Time, johnwcox(at)pacificnw.com writes:
| Quote: | --> RV10-List message posted by: "John W. Cox" <johnwcox(at)pacificnw.com>
experience.
John - $00.02 |
rvbuilder(at)sausen.net Guest
Posted: Tue Jun 27, 2006 5:48 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
I know what you mean. I had some a$$ selling a "book" on eBay that
purported to give you all kinds of information on different types of,
and how to build your own, hanger door. His "book" ended up being a
bunch of links to some of the common door manufacturer's websites and an
ad for his design business. At least he honored his 100% satisfaction
guarantee. It was called something like Hanger Door $ecrets and was a
PDF. Ya get what you pay for.
However I can recommend the Paintucation video series. Fairly well
done for low budget.
Michael Sausen
-10 #352 Fuselage
mike(at)learningplanet.co Guest
Posted: Tue Jun 27, 2006 5:56 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Here's a painting tip and you can have it for free:
Finish the plane and then take it to a respected paint shop to have
it professionally painted. That's what I did on my RV-9A and it was
worth every penny.
Mike Schipper
RV-10 #576 - Empennage (www.rvten.com)
RV-9A - N63MS - Flying (www.my9a.com)
Posted: Tue Jun 27, 2006 6:21 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
That's a beautiful paint scheme on the 9A. What paint was used and are
you willing to state how much it cost?
John Cox - KUAO
Posted: Tue Jun 27, 2006 7:23 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
It's JetGlo. The total was around $6200. I think the -10 will be
somewhat higher.
are
John Cox - KUAO
pdwalter(at)bigpond.net.a Guest
Posted: Tue Jun 27, 2006 10:05 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Mike, do you have a photo for the group ?
Posted: Wed Jun 28, 2006 5:27 am Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Paul,
We'll see if this goes through.
Mike Schipper
On Jun 28, 2006, at 1:03 AM, Paul Walter wrote:
<pdwalter(at)bigpond.net.au>
492.63 KB |
252 Time(s) |
dennis_mangan(at)msn.com Guest
Posted: Wed Jun 28, 2006 8:23 am Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Mike
this picture looks like an airpark in TX. I am heading to TX after Oshkosh to find a good airpark to move onto.
Dennis
414.25 KB |
226 Time(s) |
Posted: Wed Jun 28, 2006 9:17 am Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Dennis,
The picture is at Northwest Regional (52F) in Ft. Worth. You could also check out Hillcrest Airport (7TX4) in Keller or AeroCountry (T31) in McKinney.
On Jun 28, 2006, at 11:17 AM, dennis mangan wrote:
[quote] Mike
Dennis
