Posted: Tue Jun 27, 2006 7:27 am Post subject: Warp drive hub. |
Michel,
I thought you were the smart one.... Now what???
Well, theoritically the longer prop should be better
unless the tip speed gets too high. But then you have
the engine torque curve to consider too, not just the
prop. The best engine/prop efficiency combined is the
actual answer and testing often proves theory a bit
off. I'd go with test results over theory every time.
We need to borrow a large wind tunnel for a 100 hrs or
so to really out fox the Fox. Some blowing smoke
would clear things up. ????
I think low aspect ratio props are better, except at
low speed, as test results prove. ie, the thicker
cord prop good at lower speeds and thinner prop at
higher speeds, but again ya' gotta test them all.
I sure would like to do some prop testing on my own,
but that would cost a lot, unless I had a source for
each candidate and could return them. I don't think I
have the right prop, or maybe gear ratio for mine.
Too much loss.
Kurt S.
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | > From: Clem Nichols [cnichols(at)scrtc.com]
> Kirk and Michel, you're our physicists and
theoreticians. Any thoughts on explaining
> Randy's observation?
... what? What have you been smoking, Clem, I want
some! My only knowledge about propellers is
nearly 30 years old and only with yachts. I haven't
a clue why shortening a 72" prop to 70 would make
both climb-out and cruise performance better.
But thanks for the compliment, you really made my
day!
PS: My Jabiru prop is only 60" diameter, which at
WOT (3,050 prop RPM) gives me a tip moving at 285
m/s, well under the speed of the sound of 340 m/s
Cheers,
Michel
Clem Nichols
Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
Posted: Tue Jun 27, 2006 10:28 am Post subject: Warp drive hub. |
Kurt, Cliff, and others:
Thanks for your response.
Clem Nichols
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jun 27, 2006 11:18 am Post subject: Warp drive hub. |
I think you are right about cord vs. speed. There were a number of
ultralights and powered parachutes at the West Desert Fly-in, all powered by
Rotax 4 strole engines and the cord of the props on them was definitely
broader.
Also the two guys that went to the PowerFin prop here shortened theirs by
one inch and both got better performance on both climb and cruise, but with
the PowerFin, climb was clearly the winner. Sorry to report that both have
since gone to other props most recently with similar climb and better
cruise. One to the IVO and the other to the taper tip Warp.
Lowell
janderson412(at)hotmail.c Guest
Posted: Tue Jun 27, 2006 1:09 pm Post subject: Warp drive hub. |
When I ordered my prop from Warp, I gave them my power combination and they were most adamant with their recommendation. 72" taper tip and from my experience, they were spot on. Good climb and cruise, I'm more than happy.
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Subject: RE: Warp drive hub.
Date: Tue, 27 Jun 2006 08:26:20 -0700 (PDT)
--> Kitfox-List message posted by: kurt schrader <smokey_bear_40220(at)yahoo.com>
Michel,
Too much loss.
Kurt S.
[quote] > From: Clem Nichols [cnichols(at)scrtc.com]
> Randy's
Posted: Tue Jun 27, 2006 5:03 pm Post subject: Warp drive hub. |
Those are the blades I have John.
Trying to get my mind on topic again to think this in
debth. Not always easy these days.
Wider blades grip air, like all WX tires grip the
pavement. Narrow blades more like dragster tires.
You get a better bite with the wider blades from the
start = more static thrust and less slippage. But the
narrow blades come into their own as you speed up and
allow the engine to spool up better from the start.
The wider ones should run more draggy at higher speeds
and, as was said, for descent and landing.
If your tires grip and not slip, you need a lower
gear. If your prop grips from the start, you use less
pitch to keep RPM's up. Less pitch means the wide
cord blades will run out of pitch sooner in cruise.
Fixed pitch would theoritically like the narrow
blades. But if you have a cockpit adjustable prop,
the wider blades might be better?
Less diameter should mean some more slip too. Less
efficiency on the same pitch and rpm, but maybe allows
more HP from the motor..... You'd need to add a
little pitch for the reduced diameter, so it should be
less static thrust and maybe a slight plus in cruise.
I just can´t see enough gain from reduced diameter to
equate to that big a gain in performance from diameter
alone. Unless there is more to the story, I'd think
the blade cord change was the bigger factor.
Again I have to yield to testing.
I need to static thrust test my plane some day too.
Lance claimed over 700 lbs of thrust? Don't think I
am getting that....
Kurt S.
than happy.
rjdaugh(at)rapidnet.com Guest
Posted: Tue Jun 27, 2006 8:19 pm Post subject: Warp drive hub. |
Aw, come on. You guys are making this too complicated.
Like Kurt says wide blades grip the air. The Powerfin is a wide blade. It
definitely grips the air! It doesn't slip much - especially in the longer
blade version. So if you put in lots of pitch for fast cruise speed, you
can't get any RPM on the ground. No RPM == no horse power. (Horse power =
torque X RPM) So more accurately: low RPM = low horsepower = long take off
roll and low climb rate.
Or low pitch means you can get RPM's up on the take off and climb, but
limited top speed.
So you cut the blades shorter, the prop doesn’t grip the air as good - so
with more pitch you get faster cruise and with more slippage on take off and
climb, you get more RPM (= more horsepower!) and so shorter take off and
climb.
I am glad that Lowell confirmed that at least two others have had the same
result with the shorter prop. I guess you lose more disc area with the
shorter prop than the 1" shorter blade would indicate.
Randy - also looking for a different prop...... Think I am going to try a
Kiev.
Graeme Toft
Posted: Tue Jun 27, 2006 9:53 pm Post subject: Warp drive hub. |
One of my mates has a light wing with a Kiev and gets 5 knots better
performance than the other lightwings in the area that are using other prop
types. Climb is also much better but beware of the Kievs construction. They
are dead light in comparison to a Warp as testified by the results of him
flying into one of his cows that wandered into his take off run. The prop
literally disintegrated where as my Warp would have survived a 50 knot
impact had the plane not rolled onto her back in the water.
Graeme
Ph: 07 49397011
Mob: 0411476527
Michel
Posted: Wed Jun 28, 2006 2:37 am Post subject: Warp drive hub. |
| Quote: | Michel,
Well Kurt, when Mathilde, my 10 1/2 months old grand-daughter, listens while staring at me with her big round eyes, wondering how much wisdom can come out of my lips - she usually concludes by saying: "Geeee, yeeeahhh, gaga! ... ga?"
.. it says it all, doesn't it?
Cheers,
Michel
Posted: Wed Jun 28, 2006 2:46 pm Post subject: Warp drive hub. |
Definately words of wisdom.... from her.
Kurt s.
| Quote: | From: kurt schrader smokey_bear_40220(at)yahoo.com
> Michel,
... it says it all, doesn't it?
Cheers,
Michel
Posted: Wed Jun 28, 2006 8:35 pm Post subject: Warp drive hub. |
Yes, that makes good sense to me Kurt..well explained. I do find that it takes quite a punch of power to get the wheels rolling to taxi and on t/o the acceleration is gentle for a start but really begins to bite once she's up and away so that ties in. I'll take more notice tomorrow when I fly again. Took my boy yest (test engineer), first passenger and sure made a differance. John
Date: Tue, 27 Jun 2006 18:02:47 -0700 (PDT)
equate
Posted: Wed Jun 28, 2006 8:37 pm Post subject: Warp drive hub. |
Forgot to mention the deacceleration, very little when you close the throttle thus requiring a bit of f/ward planning on approach and boy do I hate it when the tower askes for a tight approach. I've had to resort to side slipping a couple of times, seems to work ok? Any comments on this?
equate
Posted: Wed Jun 28, 2006 8:44 pm Post subject: Warp drive hub. |
Surely one would only go for a shorter prop if g/clearance or high RPM is a factor. Smaller prop, less thrust area but more pitch and more induced drag to get the same thrust? John A.
From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Date: Tue, 27 Jun 2006 22:15:38 -0600
--> Kitfox-List message posted by: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
limited top speed.
climb.
Kiev.
Posted: Thu Jun 29, 2006 9:23 am Post subject: Warp drive hub. |
Somewhat the same with me John. On grass it takes a
bit to move. If I use my normal takeoff power, I
probably use 500 feet or 8 seconds to lift off of
grass. (Timed from movie camera footage of my
takeoffs from the cockpit.)
If I use full power, which I can get with the cockpit
adjustable prop, that last 300 RPM really peaks the
turbo and you can feel the change. About equal to
going from 2 people to solo. It is on the top end of
speed where I seem to run out with this prop. More HP
isn´t going to more speed.
On landing I am still trying to find a reliable way to
set pitch for less float and yet have go-around power
available. I can either float, or make a bunch of
noise as I land when I wanted to go. So far, I try to
set 2000 rpm at closed throttle and accept that, but I
do float. Slips are very useful.
Kurt S.
differance. John
Posted: Thu Jun 29, 2006 12:46 pm Post subject: Warp drive hub. |
Kurt, With an inflight adustable, do you not set full fine (or t/off
setting) on final for go around?
On t/o with the prop setting I have now, the diff between 4300 and 4700 is
like day and night but as you say, it's the turbo boost at the latter
setting that make the diff. I still need to coursen up a bit as full noise
is still over 5000. If only I could get time to play...John
Kurt S.
differance. John
Discover fun and games at (at) http://xtramsn.co.nz/kids
Posted: Fri Jun 30, 2006 12:21 pm Post subject: Warp drive hub. |
John,
Roger the "play time".
Without a prop pitch gauge, I have no defined
reference to set to in flight other than Max pitch or
Min in flight pitch. The minimum pitch in flight
gives me some static thrust before max RPM is reached,
but seems way too low for go-around in flight.
The takeoff setting is too much thrust, or too little
idle rpm. Either a great floater, or a dead stick
landing.
What I am setting is just a slight amount of positive
thrust with nearly closed throttle.
In any case, so far I need to power up on go-around
and keep advancing the pitch with power in coordinated
steps. Not exactly an obstical clearing proceedure
until I master it.
Remember, the CAP prop is reversable. There is no
"full fine" but a minimum pitch above about 2000 rpm.
Below that rpm you can go into reverse. Makes for a
steep pattern and short landing!
Kurt S.
| Quote: | Kurt, With an inflight adustable, do you not set
full fine (or t/off setting) on final for go around?
boost at the latter
play...John
morid(at)northland.lib.mi Guest
Posted: Fri Jun 30, 2006 1:18 pm Post subject: Warp drive hub. |
Kurt, that CAP can go into reverse, but not in flight. It has sprung
counterweights built into it and won't go into beta so long as the prop is
spinning above a certain rpm. Even though your engine rpm may read 1400 or
so, the prop rpm is usually much higher on final because of the free
wheeling. Not sure what rpm the weights are set for, but it's well below
what the rpm would be on final. I can't get mine to go beta until it's
going pretty slow on the ground. This may vary somewhat depending on the
weights. That would be pretty scary to have that go into beta on final.
Deke
Kurt S.
> boost at the latter
> play...John
