Aircraft Engine Monitoring: How It Works
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
Pable Mackenzie
PostPosted: Fri Nov 28, 2014 3:24 am    Post subject: Aircraft Engine Monitoring: How It Works Reply with quote
Hi,Dear Friend,
I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts
With cost of aircraft acquisition and aviation fuel reaching unprecedented levels coupled with expensive engineering and maintenance cost of each aircraft, it is imperative that we obtain every ounce of performance out of an aircraft engine. Also, from a purely investment point of view, a better performing engine will give better return on investment.
Just as every corporate keeps accounts to track the performance of its business; so also an aircraft engine monitoring systems keeps track of the aircraft engine performance. Doing so helps detect anomalies and detects parts of the aircraft engine that might not be performing at their optimum levels.
Modern passenger jets not only have sophisticated Flight engine instruments systems, they go a step further and transmit accumulated data (via satellite feed ) at regular intervals to ground stations that have been setup and monitored by the engine manufacturers. This helps engine manufacturers make appropriate notations and pay special attention to under-performing engine parts during the next maintenance overhaul or, they may even recommend an early overhaul.
The Aircraft digital instruments in a modern jet also sends critical performance related information to the aircraft flight recorder (black box). In the unfortunate event of a crash, such information plays a big hand in helping determine the cause of the crash.
If you knew more about this or want to know about other related parts, please feel free to write me.
Best Regards
Pable Mackenzie
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
