genie(at)swissmail.org Guest
Posted: Sat Nov 15, 2014 11:27 pm Post subject: Andair Fuel Selector Connections |
Due to an odour of fuel in the cockpit I suspect that the tubes or pipes
to the fuel selector are not sufficiently tight. I have unscrewed them
and cleaned them and reattached. This has not fully solved the problem.
Is there any way I can clean the tubes or pipes thoroughly and then seal
them tight to avoid a leak? could the problem be with the fuel selector?
I cannot see any other source of fuel leak.
If I am not mistaken I have an FS20 Type 3 valve.
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Smcm75(at)aol.com Guest
Posted: Sun Nov 16, 2014 3:47 am Post subject: Andair Fuel Selector Connections |
Try checking your wing tanks for weaping leaks around the inspection plates or near the aft lower tank skin and rib intersection. the fuel will puddle on the bottom of the wing root fairing and the smell will get into the cockpit.
Scott Morrow
RV-6A N548SM
Myrtle Beach, SC
In a message dated 11/16/2014 2:28:07 A.M. Eastern Standard Time, genie(at)swissmail.org writes:
| Quote: | --> RV6-List message posted by: George Nielsen <genie(at)swissmail.org>
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the ========================= nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP k you for p; -Matt Dralle, List ======================== e ties Day ================================================ - MATRONICS WEB FORUMS ==================================================
