Toroid beads/VOR antenna design
berkut13(at)berkut13.com
PostPosted: Mon Oct 27, 2014 6:48 am    Post subject: Toroid beads/VOR antenna design Reply with quote
Thanks! Very helpful discussion. Yes, the ferrites are for future COM
antennas being imbedded in composite structure where size does matter.
The below brings up a different question I have about a retrofit VOR/GS
antenna I need to install as well: A traditional 'T' shaped (with a slight
angle in the two radials) VOR antenna can not be utilized given the physical
constraints of the area it must be installed. There are really no other
options for mounting given the aircraft's shape and construction materials.
The two radials for the antenna will be in-line, no angle, horizontal and
mounted in a newly formed conduit drilled into the leading edge foam of a
small airfoil skinned with fiberglass. The radials will likely be solid
conductor wire or copper foil attached to a small wooden dowel for rigidity
during installation and soldered to the coax. I plan to construct a balun
out of coax as described below. This part is all rather straightforward.
The issue is: There is insufficient depth (fore/aft) in the area to run the
feed line coax sway from the radials to form the bottom of the 'T' so the
feed line coax must run parallel to and in close proximity of the (shield
connected) "lower" radial at least it's full length before being able to
re-direct away. Imagine a fully built "antenna of a stick" set being
inserted into a horizontal 5/8"dia conduit hole, then capping off the hole
with only the feed coax sticking out, then running to the radio. The end of
the "lower" radial can be right at the end of the conduit hole, or it can be
installed deeper into the structure if different design parameters dictate.
So, antenna gurus, the questions become: Will this sub-optimal antenna
config perform acceptably as a receive only antenna? Is there something
else I can do to make it more efficient given the space constraints, or is
there even a different antenna design more applicable to this install?
You input is appreciated.
-James
PostPosted: Mon Oct 27, 2014 11:14 am    Post subject: Toroid beads/VOR antenna design Reply with quote
At 09:47 2014-10-27, you wrote:
--> AeroElectric-List message posted by: <berkut13(at)berkut13.com>
Thanks! Very helpful discussion. Yes, the ferrites are for future COM antennas being imbedded in composite structure where size does matter.
The below brings up a different question I have about a retrofit VOR/GS antenna I need to install as well: A traditional 'T' shaped (with a slight angle in the two radials) VOR antenna can not be utilized given the physical constraints of the area it must be installed. There are really no other options for mounting given the aircraft's shape and construction materials. The two radials for the antenna will be in-line, no angle, horizontal and mounted in a newly formed conduit drilled into the leading edge foam of a small airfoil skinned with fiberglass. The radials will likely be solid conductor wire or copper foil attached to a small wooden dowel for rigidity during installation and soldered to the coax. I plan to construct a balun out of coax as described below. This part is all rather straightforward.
Any 'morphing' of geometry from the center-fed
dipole driven with coax at right angles will
result in a degradation of performance in terms
of pattern and impedance matching. The closest
anyone has come to an elegant end-fed dipole in
the airplanes was the Miracle Antenna brand
"air-whip", end-feed dipole antenna with the
toroidal common mode choke we discussed earlier
this past week.
[img]cid:.0[/img]
[img]cid:.1[/img]
You could string this style antenna out under a
leading edge but you still have to deal with the common-
mode choke 'lump' . . .
I note that Miracle Antennas seems to have
closed the doors. Aircraft Spruce doesn't offer
the antennas any more and the website is black.
They were in business for a lot of years and ejoyed
some good reviews by their ham-radio clients.
It seems that their demise is based more on business
issues than product performance issues.
The big problem with development of the
lead edge vor antenna is the inconvenient
packaging process that involves cut-n-try
experiments on a device buried under
layers of Fiberglas.
It follows that what ever lies underneath that
layer of glass and epoxy should be a low-risk
configuration . . . it's damned hard to change
if you don't like it.
This seems like an ideal application for an active
antenna. This is a relatively short (on the order of
6 to 12 inches long attached to a very compact
amplifier right at the end of the coax feedline.
It takes a little fussing to get dc voltage out
to the amplifier on the coax but this could well
be a VERY compact solution to a receive-only antenna
for VOR that eliminates the geometry issues that
arise when you try to put a center fed dipole into
a leading edge.
 Filesize:  73.85 KB
 Viewed:  6678 Time(s)
 Filesize:  91.69 KB
jluckey(at)pacbell.net
PostPosted: Mon Oct 27, 2014 12:01 pm    Post subject: Toroid beads/VOR antenna design Reply with quote
You may already be aware but thought I would mention it - Have you read Bob Archer's stuff on antennas? I think is company is called Sportcraft Antennas. A quick google should find his website.
FYI,
-Jeff
On Monday, October 27, 2014 12:37 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
this past week.
[img]cid:1.659687060(at)web184906.mail.gq1.yahoo.com[/img]
[img]cid:2.659687060(at)web184906.mail.gq1.yahoo.com[/img]
a leading edge.
 Filesize:  73.85 KB
 Filesize:  91.69 KB
PostPosted: Mon Oct 27, 2014 1:22 pm    Post subject: Toroid beads/VOR antenna design Reply with quote
Based on what you have indicated, this type of “air whip” antenna would work very well in this area – small airfoil leading edge D-section (carbon spared, glass skinned canard in this case). I can feed the antenna portion of the assembly into the foam conduit and the choke can reside inside the fuselage area, either just outside the airfoil skin, or I can build a small access box for it. If an “active” box is required, electrical is readily available in this area too. All of this can be done without affecting the external airfoil surface and thus easy to implement and potentially to remove and service.
Can you point me to some more specific info on how to build this type of antenna and choke?
Thanks!
-James
From: Robert L. Nuckolls, III (nuckolls.bob(at)aeroelectric.com)
Sent: Monday, October 27, 2014 2:13 PM
Subject: Re: Re: Toroid beads/VOR antenna design
this past week.
[img]cid:FF9923CCB41F469AA35A22968198A6F6(at)DEFIANT2600[/img]
 Filesize:  73.85 KB
 Viewed:  6676 Time(s)
PostPosted: Tue Oct 28, 2014 7:15 am    Post subject: Toroid beads/VOR antenna design Reply with quote
At 16:20 2014-10-27, you wrote:
Not sure this is the best way to go. Assume you are
glassing a 'conduit' into the leading edge of the
surface under consideration. What is the inside diameter
of the proposed conduit? How long? Do I presume correctly
that the 'radio end' of the conduit is accessible after
assembly such that any antenna slipped into it could
be repaired/modified at a later time?
PostPosted: Tue Oct 28, 2014 7:55 am    Post subject: Toroid beads/VOR antenna design Reply with quote
This is actually a retrofit as the original structure was built by the owner
without any VOR or GS antenna(s). Horizontal, antenna space on this
aircraft is limited to this area only.
The hope is not to "glass" an antenna into/onto the structure, but to insert
one into a conduit that was bored into the internal foam (about 5/8"dia,
about 5ft long) of the leading edge D-section on one side of the canard.
The radio end would protrude from the structure into the nose of the
aircraft either as a coax connector, pig tail, or I can create an internal
box for a choke/circuitry/etc. The original idea was to put a dipole in
this area as I described earlier, but it sounds like there would too much
degradation in performance having the center feed coax+balun parallel and
very close to one of the elements. Removal would simply be a reverse of
the insert - pull it out/stick it in with a little glass cut/repair at the
feed end.
I'm trying to avoid the traditional retrofit which is to glass (permanently)
a copper foil dipole onto the center bottom surface of the canard. This too
is sub-optimal as the radials will extend onto the external airfoil surface,
the antenna is blocked/surrounded by rudder pedals/hydraulic
pump/relays/battery/etc and previous installations in this area have been
low performance. The canard is carbon spared, so the traditional V shape of
the antenna is extremely flat (almost straight) anyway being limited to the
3.5" in front of the spar. I have had good results with shallow V dipoles
in the hollow D-sections of molded canards with about 3" separation between
radials and coax run....but of course, that is not an option here.
Thoughts?
-James
PostPosted: Tue Oct 28, 2014 12:26 pm    Post subject: Toroid beads/VOR antenna design Reply with quote
(permanently) a copper foil dipole onto the center bottom surface of
the canard. This too is sub-optimal as the radials will extend onto
the external airfoil surface, the antenna is blocked/surrounded by
rudder pedals/hydraulic pump/relays/battery/etc and previous
installations in this area have been low performance. The canard is
carbon spared, so the traditional V shape of the antenna is extremely
flat (almost straight) anyway being limited to the 3.5" in front of
the spar. I have had good results with shallow V dipoles in the
The legacy "v" shape was more cosmetic than physically
or electrically beneficial. The straight dipole in your
leading edge would be just fine.
I'm thinking about an "active" antenna. An electrically
'short' antenna (less than 1/4 wave) can be an effective
receiving antenna . . . but it's not resonant . . . meaning
that the thing is a pretty hi impedance source of energy
not well suited to piping that energy into a 50-ohm
coax.
A work-around has roots that go WWwaaayyy back in radio
receiving history with earliest practical roots demonstrated
in car radios. Antennas on cars might be little more than
1 meter long yet expected to perform in the capture of
signals having wavelengths in the neighborhood of 200-400
meters.
In the instance before us, it's quite possible to get
a 'resonant' antenna capable of delivering energy into
a 50-ohm coax . . . the problem is physical layout
limits that we've discussed. But suppose we consider a
'short' antenna . . . say about 1/10th wavelength at
115 Mhz or 10" long.
A simple amplifier can be crafted to go on the antenna
end of the coax that will improve the short antenna's
ability to deliver energy into the coax. It takes about
8 components on a board about 1/2 x 3/4 inch. You not
only run your normal RG coax out to this board, you run
a 22AWG wire connected to 14V.
Now your overall antenna is less than a foot long and
doesn't need the "counter-poise" that turns a 1/4
wave monopole into a dipole of twice the length.
I've got some other antenna work to do in the next few
weeks and I thought I would fiddle with an active
antenna amplifier for VOR/LOC/GS. Could you bore a hole
in your canard leading edge foam to accept a 1" piece
of thinwall pvc pipe about 15" long? If so, we may
well be able to craft an antenna that would slip into
the pipe and just lay there.
PostPosted: Tue Oct 28, 2014 3:07 pm    Post subject: Toroid beads/VOR antenna design Reply with quote
A small, active antenna is just fine as I would have room for a circuit
board on the end of the whip (inboard end) and have power available a few
inches away.
I don’t think I can get 1"dia in there. The D section is quite small in
aspect, and there are wooden dowels running fore/aft in the middle of the
foam from the construction process - I had to bore in front of those. The
foam conduit already exists now, I bored it from the tip inboard. I will
plug/repair the outboard conduit hole in the tip, and although it could be
used for initial installation, I would not consider it to be an access or
service point in the future as it would affect the external surfacing/paint.
In this case, and ideally, the antenna portion would be flexible enough to
bend 90degrees (not sharply) to be fed down and into the foam conduit
(inboard to outboard) - it is not a direct shot into the conduit from the
inboard end. There is a plunge cut box in the bottom inboard skin/foam for
access to the LE foam conduit. This area will also will be the exit point
for the antenna pigtail/connection. The antenna would just lay in the foam
conduit, and the circuit board can be supported or secured in the access box
area.
If you anticipate working on an antenna design as you describe, I will table
this issue for a few weeks and move forward with other items. I am working
to get this particular aircraft in the air in the Dec'14/Jan'15 timeframe
and am on track to do so. Obviously, it can’t fly until the holes in the
canard are repaired (preferably with antenna installed). Wink
So you know, the antenna will be connected to a Garmin 650 radio that has a
VOR/GS splitter internally and has only the one coax connection.
Thanks for all your help!
-James
PostPosted: Wed Oct 29, 2014 7:30 am    Post subject: Toroid beads/VOR antenna design Reply with quote
A small, active antenna is just fine as I would have room for a circuit board on the end of the whip (inboard end) and have power available a few inches away.
I don’t think I can get 1"dia in there. The D section is quite small in aspect, and there are wooden dowels running fore/aft in the middle of the foam from the construction process.
I'm not sure I have a clear mental image of your configuration.
Q: If the antenna portion of the proposed installation were
a 15-25" long, say stiff rod with the 'amplifier' stuck to
the inboard end, would you be able to install such a device?
It occurs to me that while many builders have described the
boring of a hole through the foam under a composite structure,
it might be possible to simply push the antenna portion of
the device into the foam. The resulting hole would be no
larger than what the antenna itself produced.
In this case, and ideally, the antenna portion would be flexible enough to bend 90degrees (not sharply) to be fed down and into the foam conduit (inboard to outboard) - it is not a direct shot into the conduit from the inboard end.
This is the unclear part. The 'antenna' portion the
system need not be straight, rigid or any particular
shape. It ultimately DOES want to have some geometric
length in the horizontal plane (this is the e-field probe
portion of its physics) but something of a curve or zig-zag
isn't especially detrimental.
So the goal is to get SOME conductor in a mostly horizontal
orientation. The 'active' portion of the installation is
an etched circuit board with a handful of surface mount
components on it. I'm thinking something on the order of
3/4" square. It would be fitted with a length of RG coax
and a 14v power supply wire soldered on. The antenna connection
could be a short pigtail that attached to the end of
the conductor of choice installed in the foam.
[img]cid:.0[/img]
So you know, the antenna will be connected to a Garmin 650 radio that has a VOR/GS splitter internally and has only the one coax connection.
This is a 'broadband' design which should perform
well at both VOR/LOC and GS frequencies. Parts
not already on hand have been ordered. I'm going
to set up a little 'antenna range' experiment in
the back yard in the next few weeks. I can massage
this active antenna project at the same time.
 Filesize:  36.76 KB
 Viewed:  6651 Time(s)
PostPosted: Wed Oct 29, 2014 10:42 am    Post subject: Toroid beads/VOR antenna design Reply with quote
Again, thank you for your help here.
I have private emailed you with some photos of the project’s canard to help better describe the mounting challenges. For everyone else – just imagine a surf board laying on the floor (perpendicular) in front of you, mark off a 2’ wide section in the center, and you need to install a horizontal antenna into the long side edge of board left or right of the center section; you can only access that center section you just marked off, and you can’t violate the external surfaces other than the center section. Fun, eh?
Had I to do it over with this new antenna style in mind...yes, a ridged rod could be inserted into the foam (at a slight angle from horizontal) but it would need to have a spade point on the end, and be able to be chucked into a drill while inserting for the length you are describing. The standard blue foam is easy to penetrate an inch or two, but beyond that the friction builds rapidly. This would be quite difficult if the amp was attached to the element. It would be much easier to just use a slightly larger dia rod with a spade tip to bore a path through the skin and into the foam for the antenna to be inserted into later – again, at a slight angle from horizontal.
-James
Sent: Wednesday, October 29, 2014 10:29 AM
