Fred Klein
Posted: Sat Oct 04, 2014 1:13 pm Post subject: OAT probe location |
All,
I offer half my kingdom to anyone who will give me a proven location for an OAT thermocouple which is part of my “aftermarket” EMS.
with appreciation,
Fred
Posted: Sat Oct 04, 2014 1:41 pm Post subject: OAT probe location |
Fred, It works nicely just in front of the starboardflap
activator slot, hidden by wing root from sun, but in full
contact with outside air between flap end & fuselage.
Starboard to avoid exhaust fumes. Regards, David Joyce,
GXSDJ
PS Before I accept, how big is the kingdom and how surly
are the natives?
On Sat, 4 Oct 2014 14:13:12 -0700
Fred Klein <fklein(at)orcasonline.com> wrote:
All,
with appreciation,
Fred
Un/Subscription,
Forums!
Admin.
Fred Klein
Posted: Sat Oct 04, 2014 2:18 pm Post subject: OAT probe location |
On Oct 4, 2014, at 2:40 PM, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
| Quote: | | Fred, It works nicely just in front of the starboardflap activator slot, hidden by wing root from sun, but in full contact with outside air between flap end & fuselage. Starboard to avoid exhaust fumes. |
David…your suggestion much appreciated…however, you will note in attached photos that on my ship, the slot gets buried within my enhanced wing root fairings. I fear that the probe will reach interior cockpit / aft fuselage temps. Care to comment on whether my fears are justified?…
Any suggestion (anyone!) for an alternate location…?...
| Quote: | | PS Before I accept, how big is the kingdom and how surly are the natives? |
My kingdom is a very small part of a small rock in the Salish Sea just south of Vancouver, B. C., and the natives can be very surly, especially when they’re restless.
Fred
| Quote: | On Sat, 4 Oct 2014 14:13:12 -0700Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote: | Quote: | --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
All,
I offer half my kingdom to anyone who will give me a proven location for an OAT thermocouple which is part of my “aftermarket” EMS. |
[img]cid:0AA92666-9978-4205-B472-55DF89E134B9[/img]
[img]cid:2D2DDB7F-D56E-4B31-B4CD-7F71FCDB5436[/img]
[img]cid:045EDC19-11DC-40B6-BA84-75BCCF81CC1C[/img]
26.88 KB |
12571 Time(s) |
45.2 KB |
12571 Time(s) |
26.23 KB |
12571 Time(s) |
Fred Klein
Posted: Sat Oct 04, 2014 2:51 pm Post subject: OAT probe location |
Has anyone place an OAT probe at the front of the cowl, recessed within an opening to keep it out of the sun, and where it would not be subject to engine heat?…say somewhere in the slot opening above my port circular inlet for port radiator?…(we’re looking at a liquid cooled engine installation).
Fred.
[img]cid:0E1C545B-73F5-43CB-8B64-361F99D3F996[/img]
19.13 KB |
12568 Time(s) |
Posted: Sat Oct 04, 2014 9:16 pm Post subject: OAT probe location |
Fred, had not appreciated that you have fancy fairings!
However I guess a nearby position through the lower
surface of the fuselage or the fairing on the starboard
side would serve.
Regards, David
On Sat, 4 Oct 2014 15:17:30 -0700
justified?…
>are the natives?
restless.
Fred
>> All,
Posted: Sat Oct 04, 2014 9:21 pm Post subject: OAT probe location |
Fred, There is the issue of ram air compression raising
the temp. I have an airbox temp sensor as well as the wing
root sensor and although they say the same thing before
engine start, the air box one rises appreciably, possibly
10C in flight. Regards, David, GXSDJ
On Sat, 4 Oct 2014 15:50:54 -0700
| Quote: | Has anyone place an OAT probe at the front of the cowl,
Fred.
Fred Klein
Posted: Sat Oct 04, 2014 9:41 pm Post subject: OAT probe location |
On Oct 4, 2014, at 10:16 PM, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
| Quote: | | a nearby position through the lower surface of the fuselage or the fairing on the starboard side would serve. |
Thank you David.
Best,
Fred
Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Posted: Sun Oct 05, 2014 12:00 am Post subject: Re: OAT probe location |
How about the stbd fuel tank outlet access panel? If it didn't work out you could reposition it, without having to patch a hole in the fuse...
Paul M
383 XS Mono 912s
Remi Guerner
Posted: Sun Oct 05, 2014 12:44 am Post subject: Re: OAT probe location |
Fred,
My OAT probe is installed inside the air intake of the Rotax cylinder cooling baffle. Pic attached. It works fine in flight, the measured error being less than one degree C.
However, during ground operation, the indicated temperature is useless as it is greatly influenced by the engine heat.
This works for me.
Remi
F-PGKL
79.81 KB |
12546 Time(s) |
alanb(at)dpy01.co.uk Guest
Posted: Sun Oct 05, 2014 1:13 am Post subject: OAT probe location |
Mines installed in the air intake for the radiators and works for me. I certainly don’t see the ram air effect raising the temperature.
Alan
G-OBJT
h&jeuropa
Posted: Sun Oct 05, 2014 4:26 am Post subject: Re: OAT probe location |
Fred,
Ours is just tie wrapped to wires in the space covered by the starboard wing fairing aft of the spar and works fine. Our fairing is taped to the fuselage but the rear end is open, not sealed like yours. We had it in the fairing for the port flap cross tube hinge (FL18) but it got a lot of heat from the exhaust.
Heather reports the forward face of the starboard footwell stays comfortable with our 914 setup since it gets air from the inlet for the turbo but that probably is different on your Subaru setup.
How about locating it in the access panel on the starboard side under the starboard tailplane?
Jim & Heather
budyerly(at)msn.com Guest
Posted: Sun Oct 05, 2014 6:16 am Post subject: OAT probe location |
Fred,
I have seen a number of installations and tried a few myself.
Flap area as you have heard works well.
Just aft of the rear wing attach (good airflow through the pip pin hole I
guess).
At the fairing for the stabilator just forward of the metal bracket TP12.
If centered it doesn't interfere with the stab.
In the tail post lower end, in a trigear with the bottom of the rudder cut
off as per the manual.
Under the passenger seat near the wing fillet out in the stream. (Retrofit
idea it put the magnatometer and OAT together under the pax seat. Quick and
easy worked great. On autopilots installed though.)
In a NACA duct coming into the cockpit. The duct was equipped with a plenum
off the NACA to allow ball type inlet control, and this gave room for the
probe.
In a tail fin mounted NACA duct which funneled air up to the cockpit.
In the 914 engine inlet metal duct work just forward of the air filter.
Note that his is subject to the heated duct and must be insulated from
that heat transfer. Terrible on the ground between sorties.
In the 914 duct on the vertical metal below the oil tank. (Ran high all the
time.)
In the 912 XS Airbox. Just under the filter in the fiberglass box, it is
not bad but is just a bit warmer than outside air, better if attached just
in the free air coming into the filter on the top of the airbox where it can
sense the NACA airflow coming into the engine...
Note, same problem on the ground above.
In the metal air inlet face just inside the fiberglass cowl on the XS.
Note, same problem on the ground as above. Lots of bugs too.
In a custom made flap bracket cover on the starboard side (a modified
teardrop, with a 1/4 inch hole dedicated to allow air to impact the probe
and go out through a vent in the rear of the teardrop.) Nicely done.
Supposedly worked and I can't see why not.
The above positions all worked in-flight OK.
Lessons learned:
Anything in the tail meant more wire, voltage drop and weight.
Anything in the engine, meant insulation from heat.
Anything on the outside of the skin meant hitting it when washing. Not
unlike civil air probes. They just stick it out the side of the aircraft
where convenient.
Anything on the gaps in the flight controls meant extreme care to assure no
interference.
Not so well working:
Mounted on top of the aircraft near the fuel vents in a mono. The sun
heated it and it was always high in the summer and just OK in winter.
In the port wing near the end of the flap in a Classic. Hot exhaust must
collect under the wing or something. Plus it was another connector to
disconnect. I had to move this clients probe to the starboard side.
In the cockpit tunnel for the mono forward of the gear just below the panel.
Seems hot air coming in from the leaky firewall was the culprit. Moved to
belly.
Good luck Fred.
Bud
Sent: Saturday, October 04, 2014 5:13 PM
To: <europa-list(at)matronics.com>
Subject: OAT probe location
All,
with appreciation,
Fred
Fred Klein
Posted: Sun Oct 05, 2014 2:16 pm Post subject: OAT probe location |
All…thank you very much for all the thoughtful replies…many good choices indeed…Fred
Posted: Mon Oct 06, 2014 7:07 am Post subject: OAT probe location |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Fred,
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> [img]cid:00eb01cfe177$05a63450$266A5CEF(at)BudsPC[/img][img]cid:00ec01cfe177$05a63450$266A5CEF(at)BudsPC[/img] Photo E-mail View slideshow | Download images That's why its called Custom Flight. We do all this kind of stuff based on the needs and wants of the client. Does it add speed..No. Just costs more time.
While doing the inlet for the teardrop Fred, you might as well add a bit of an extension for it to cover those 525s that stick out. Get it all done at once.
[url=C:\Documents and Settings\Administrator\My Documents\Wheel Pants\IMG_20141006_104202_503.jpg][img]cid:00ed01cfe177$05a63450$266A5CEF(at)BudsPC[/img][/url]
Bud
842 Bytes |
12495 Time(s) |
1.11 KB |
12495 Time(s) |
16.4 KB |
12495 Time(s) |
Fred Klein
Posted: Mon Oct 06, 2014 10:33 am Post subject: OAT probe location |
On Oct 6, 2014, at 8:05 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
| Quote: | That's why its called Custom Flight. We do all this kind of stuff based on the needs and wants of the client. Does it add speed..No. Just costs more time.
Bud…those look terrific…I had no idea you made them up…as for “time cost”, tis in the mind of the builder!
They look very similar to mine, courtesy of Kingsley Hurst…pix below.
Thanks again for the tip of placing my OAT within.
Fred
[img]cid:D3689CA3-E04B-45EA-819E-61FAE94E6514[/img]
[img]cid:9B5D1330-86FA-43A6-BCC4-1046C19FACE3[/img]
33.65 KB |
12490 Time(s) |
39.36 KB |
12490 Time(s) |
rampil
Posted: Fri Oct 10, 2014 2:08 am Post subject: Re: OAT probe location |
Thanks to Kevin Horton in the RV group who looked this up:
COmpression heating or ram air heating can be calculated as:
TAS in kt, and temperatures in deg C:
IOAT = OAT + ((K * TAS^2)/7592)
OAT = Outside air temperature
IOAT = indicated OAT (i.e. the value you actually see on the OAT indicator)
K = OAT probe recovery factor - usually somewhere between 0.8 and 1, if the probe is truly stuck out in the airflow.
Therefore, in a Europa. don't expect more than about a 2°C change in OAT
reading. At 200 kts, expect roughly 4°C
