hgmckay
Posted: Mon Oct 06, 2014 1:22 pm Post subject: Mechanical Fuel Pump gasket |
I have just had my Rotax 912 UL Gearbox off and inspected after 700 hours. I am ready to reinstall it, and need to know if it is necessary to replace the existing mechanical fuel pump/gearbox gasket. The original gasket is in perfect condition. Advice and counsel would be appreciated.
Hugh G. McKay III, P.E.
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
 Download |
| Filename: |
Hugh.vcf |
79 Bytes |
| Downloaded: |
505 Time(s) |
Roger Lee
Posted: Mon Oct 06, 2014 5:27 pm Post subject: Re: Mechanical Fuel Pump gasket |
If it wasn't leaking to start with you can re-use it.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
BARRY CHECK 6
Posted: Tue Oct 07, 2014 1:46 pm Post subject: Mechanical Fuel Pump gasket |
If it ain't broke don't fix it!
But then again you went this far - Why not!
But then again it is a Rotax.
I want a CH601 so bad, just not with a Rotax... O-200 or O-235.
On Mon, Oct 6, 2014 at 5:21 PM, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
[quote] I have just had my Rotax 912 UL Gearbox off and inspected after 700 hours. I am ready to reinstall it, and need to know if it is necessary to replace the existing mechanical fuel pump/gearbox gasket. The original gasket is in perfect condition. Advice and counsel would be appreciated.
Senior Consultant
Denver, NC 28037
Ph. [url=tel:704-661-8271]704-661-8271[/url]
Fax [url=tel:704-483-5466]704-483-5466[/url]
email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
