Kelvin Weston
Joined: 14 Apr 2010 Posts: 90 Location: Hampshire, UK
Posted: Fri Sep 26, 2014 11:51 am Post subject: Ultimate Ventilator |
Hi all
Have just purchased a couple of ultimate ventilators to fit under the windscreen either side of the fuselage just forward of the doors.
I saw them fitted to a Europa at Sywell and thought they were a good solution to the ventilation problem.
My question to those that are flying and already have them fitted is:
Do you have any problem with water ingress when it rains?
I notice that there is no rubber seal or anything fitted and there is quite a gap between the centre flap and the circular frame when it is closed.
In fact, I am a bit disappointed with them as they have no positive closure device and can be pushed open from outside when fitted.
I can imagine a lot of rain entering the fuselage when the aircraft is stored outside.
Hope I am wrong because they were bloody expensive.
_________________ Regards
Kelv Weston
Kit 497
kelv@kdweston.co.uk |
klinefelter.kevin(at)gmai Guest
Posted: Fri Sep 26, 2014 12:23 pm Post subject: Ultimate Ventilator |
I've hade no water enter though them. Once you paint them the gap gets smaller. They work quite well for me.
Kevin
| Quote: | On Sep 26, 2014, at 12:51 PM, "Kelvin Weston" <kelv(at)kdweston.biz> wrote:
Hi all
Kelv Weston
Kit 497
http://forums.matronics.com/viewtopic.php?p=431150#431150
Fred Klein
Posted: Fri Sep 26, 2014 12:45 pm Post subject: Ultimate Ventilator |
sure doesn’t sound like a value at $125 each (as I recall when I considered buying a couple)…do not archive
On Sep 26, 2014, at 12:51 PM, Kelvin Weston <kelv(at)kdweston.biz> wrote:
Hi all
Kelv Weston
Kit 497
dpark748(at)icloud.com Guest
Posted: Fri Sep 26, 2014 2:11 pm Post subject: Ultimate Ventilator |
I have something like you describe in my Europa G-LDVO and find them a simple and effective solution. Have flown through some rain and no problem.
When parked outside the pic shows the cover over the vent in front of the door.
Regards Dave Park (PS. Pic shows me stuck in Rochester on way to Texel with fog)
| Quote: | On 26 Sep 2014, at 21:44, Fred Klein <fklein(at)orcasonline.com> wrote:
> Hi all
> Regards
> Kelv Weston
> Kit 497
1.32 MB |
8385 Time(s) |
pmorgans
Posted: Fri Sep 26, 2014 4:52 pm Post subject: Ultimate Ventilator |
Hi Kelv,
Was it mine - G-CFKZ? There is a small circumferential gap, metal to metal, of about 0.010". These units provide superb controllable ventilation compared to the original units. Have not noticed any problems with rain ingress or water after washing. In flight, with vents closed, there is a slight draft through the gap.
Peter Morgans
Sent: Friday, 26 September 2014, 20:51
Subject: Ultimate Ventilator
--> Europa-List message posted by: "Kelvin Weston" <kelv(at)kdweston.biz (kelv(at)kdweston.biz)>
Hi all
Kelv Weston
Kit 497
http://forums.matronics.com/viewtopic.php?p=431150#431========================http://www.matronics.com/Navigator?Eurp; --> [quote][b]
_________________ The Titanic was built by professionals; the Ark by an amateur |
Jim Kelly
Posted: Fri Sep 26, 2014 11:08 pm Post subject: Ultimate Ventilator |
Hi Kelv, do you have a close up pic or a drawing ?G-BWEG Jim
On Saturday, September 27, 2014, PETER MORGANS <petermorgans181(at)btinternet.com (petermorgans181(at)btinternet.com)> wrote:
[quote]Hi Kelv,
Peter Morgans
From: Kelvin Weston <[url=javascript:_e(%7B%7D,'cvml','kelv(at)kdweston.biz');]kelv(at)kdweston.biz[/url]>
To: [url=javascript:_e(%7B%7D,'cvml','europa-list(at)matronics.com');]europa-list(at)matronics.com[/url]
--> Europa-List message posted by: "Kelvin Weston" <[url=javascript:_e(%7B%7D,'cvml','kelv(at)kdweston.biz');]kelv(at)kdweston.biz[/url]>
Hi all
Kelv Weston
Kit 497
arget="_blank">http://www.matronics.com/Navigator?Europa-List
_________________ Jim GBWEG |
rlborger(at)mac.com Guest
Posted: Sun Sep 28, 2014 1:56 am Post subject: Ultimate Ventilator |
Jim,
See — http://europaowners.org/main.php?g2_itemId=63921 for pictures of an ultimate ventilator.
I installed them in my Europa. They work great at providing plenty of ventilation. Maybe leak a tiny bit when closed but not enough to worry about. Have never flown in precipitation so I can’t speak to leaking.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Sep 27, 2014, at 12:27 PM, James Kelly <europajimkelly(at)gmail.com (europajimkelly(at)gmail.com)> wrote:
[quote]Hi Kelv, do you have a close up pic or a drawing ?G-BWEG Jim
| Quote: | Hi Kelv,
Peter Morgans
From: Kelvin Weston <[url=javascript:_e(%7B%7D,\'cvml\',\'kelv(at)kdweston.biz\');]kelv(at)kdweston.biz[/url]>
To: [url=javascript:_e(%7B%7D,\'cvml\',\'europa-list(at)matronics.com\');]europa-list(at)matronics.com[/url]
--> Europa-List message posted by: "Kelvin Weston" <[url=javascript:_e(%7B%7D,\'cvml\',\'kelv(at)kdweston.biz\');]kelv(at)kdweston.biz[/url]>
Hi all
Kelv Weston
Kit 497
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
| [b]
Kelvin Weston
Posted: Sun Sep 28, 2014 10:47 am Post subject: Re: Ultimate Ventilator |
Hi Jim
The gap is very small. Hopefully, when painted it should be almost a touch fit when closed.
Pictures attached.
108.23 KB |
8306 Time(s) |
112.19 KB |
8306 Time(s) |
104.7 KB |
8306 Time(s) |
111.03 KB |
8306 Time(s) |
Kelv Weston
Kit 497
