Stator
Goto page 1, 2  Next
tkondrat(at)roadrunner.co
PostPosted: Sun Sep 21, 2014 4:52 am    Post subject: Stator Reply with quote
I am going to attempt to rewind the stator off my AeroVee engine. Has
anyone done this before? What words of wisdom can you impart, such as what
to be wary of, where to buy components, etc.
Tom
Sonex 1414X
ceengland7(at)gmail.com
PostPosted: Sun Sep 21, 2014 6:16 am    Post subject: Stator Reply with quote
Tom
Sonex 1414X
To repair it, or to change its characteristics? If just repair, have you
tried to find a replacement stator? Odds are very high that its an
off-the-shelf item from a motorcycle or other small engine.
skywagon
PostPosted: Sun Sep 21, 2014 1:48 pm    Post subject: Stator Reply with quote
Tom,
I do not know anything about the alternator used on your engine.
However, I would bet that it is used in many other applications, such that
you could find the replacement instead of going thru the trouble of a
rewind. Example, Most Cessna alternators and regulators are really Ford
products. D
_______________________________________________________________
PostPosted: Sun Sep 21, 2014 3:04 pm    Post subject: Stator Reply with quote
At 16:47 2014-09-21, you wrote:
--> AeroElectric-List message posted by: "David Lloyd" <skywagon(at)charter.net>
Tom,
However, I would bet that it is used in many other applications, such that you could find the replacement instead of going thru the trouble of a rewind. Example, Most Cessna alternators and regulators are really Ford products. D
Tom's alternator isn't anything like you'd
find on a Cessna . . .
[img]cid:7.1.0.9.0.20140921180034.01f97ff0(at)aeroelectric.com.0[/img]
It's a permanent magnet alternator with windings
that look something like this . . .
 Filesize:  104.57 KB
 Viewed:  22234 Time(s)
PostPosted: Mon Sep 22, 2014 4:55 am    Post subject: Re: Stator Reply with quote
I am curious to know the purpose of rewinding the alternator. Is the winding open or partially shorted? Is the winding stationary and permanent magnets rotate with the engine? Is a new winding available from Sonex at a reasonable price? Maybe the same winding is available from Briggs & Stratton or Tecumseh. The stator of an alternator is usually pretty robust and unlikely to fail. What are the symptoms that suggest that winding replacement is necessary? Or is the goal to improve the alternator output?
Joe
Joe Gores
PostPosted: Mon Sep 22, 2014 5:13 am    Post subject: Re: Stator Reply with quote
Here are some sources for magnet wire:
http://www.magnet4less.com/?cPath=9
http://www.powerwerx.com/wire-cable/magnet-wire.html
It is also available at eBay and Amazon and Digikey.
Joe
Joe Gores
jan(at)CLAVER.DEMON.CO.UK
PostPosted: Mon Sep 22, 2014 3:35 pm    Post subject: Stator Reply with quote
It is easy testing the stator with a isolation and continuity test. No point rewinding it if that test is ok. Visually the stator looks fine. Maybe the rotor has been so hot that the permanent magnets have partly demagnetised. You need some green magnet paper or a gaus meter to verify even magnetisation of you pm rotor
All the best
Jan
On Sep 23, 2014, at 4:36, Jim Kale <jimkale(at)roadrunner.com (jimkale(at)roadrunner.com)> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
That is a single phase alternator. The windings in this photo look perfectly good. The only reason to rewind one would be if the windings were somehow damaged or shorted internally somewhere. The big factor on rewinding is to get the correct size wire and then make sure the direction of the turns on each element are correct. Normally the winding direction is reversed on every other element. Since these windings don’t turn, there is no problem with the wire being thrown off by centrifugal force. I agree with the other advice though. It would be much easier all around to just get a new one.
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Robert L. Nuckolls, III
Sent: Sunday, September 21, 2014 6:03 PM
Subject: Re: AeroElectric-List: Stator
--> AeroElectric-List message posted by: "David Lloyd" <skywagon(at)charter.net (skywagon(at)charter.net)>
Tom,
<image001.jpg>
PostPosted: Mon Sep 22, 2014 5:08 pm    Post subject: Stator Reply with quote
The picture I posted for the PM alternator stator was
and exemplar NEW device. I think the stator that
started this thread was toast. They're not hard to rewind
as long as care is taken to insure insulation integrity
between windings and the stator core. Hopefully his
original core was powder coated and not damaged.
skywagon
PostPosted: Mon Sep 22, 2014 5:34 pm    Post subject: Stator Reply with quote
One of the oddest stator failures I have ever witnessed was a hairline crack in the stator wiring that only opened when the alternator group reached a certain temperature. In that case, it was where the end of the heavy stator wire was swaged into the case for grounding. I think the wire was stressed during manufacture and the fault did not fully materialize until much later.
When the alternator was reviewed and bench tested no failure could be found. On the test stand it was not subject to the temps needed to open the fault. . !!
It was an old grey haired, very wise, electrical alternator wizard guy that unraveled that mystery.
PostPosted: Mon Sep 22, 2014 6:35 pm    Post subject: Stator Reply with quote
PostPosted: Mon Sep 22, 2014 6:42 pm    Post subject: Stator Reply with quote
Always a good thing to test at operating temperature. Just stick it in a oven .. Or outside in a black box in the sun .... Smile .. Poor mans heat chamber ... Then do your readings ...
All the best
Jan
On Sep 23, 2014, at 9:33, David Lloyd <skywagon(at)charter.net (skywagon(at)charter.net)> wrote:
[quote] One of the oddest stator failures I have ever witnessed was a hairline crack in the stator wiring that only opened when the alternator group reached a certain temperature. In that case, it was where the end of the heavy stator wire was swaged into the case for grounding. I think the wire was stressed during manufacture and the fault did not fully materialize until much later.
PostPosted: Tue Sep 23, 2014 1:53 pm    Post subject: Stator Reply with quote
I am not sure if I am doing this right, but I wanted to thank everyone that
responded to my stator problem. I can not find a replacement because there
are no numbers to cross reference and a new one from Sonex is $500. I think
the material would be less than $100 and it would be a good learning
experience!
Thanks again,
Tom
PostPosted: Tue Sep 23, 2014 3:14 pm    Post subject: Stator Reply with quote
At 16:52 2014-09-23, you wrote:
<tkondrat(at)roadrunner.com>
experience!
The material should be MUCH less than $100 . . . Have
you un-wound the existing wire, measured its length
and put a caliper or micrometer on its diameter? I
have access to several aircraft motor wind shops that
will have class-h insulation magnet wire suited to
your task.
PostPosted: Tue Sep 23, 2014 3:17 pm    Post subject: Stator Reply with quote
By the way, how much load is on this alternator
in flight? What kind of rectifier/regulator
do you run?
There are two techniques for voltage regulation
on PM alternators . . . the legacy, easy to do,
shunt regulator that essentially has the alternator
running full load all the time. Then there's the
more modern series regulators that load the
alternator only to meet system requirements.
This winding may have failed because of a shunt
regulator . . . I can help you make sure that
your newly rewound alternator is not unnecessarily
taxed.
rickofudall
PostPosted: Tue Sep 23, 2014 4:11 pm    Post subject: Stator Reply with quote
Thomas, I don't know if you could make it fit, but Harley Davidson has a couple of different sizes of alternator (dynamo) that you might be able to adapt. When I replaced mine due to a pinched wire the whole kit was $140 minus the regulator.
Rick Girard
On Tue, Sep 23, 2014 at 4:52 PM, Thomas Kondrat <tkondrat(at)roadrunner.com (tkondrat(at)roadrunner.com)> wrote:
--> AeroElectric-List message posted by: Thomas Kondrat <tkondrat(at)roadrunner.com (tkondrat(at)roadrunner.com)>
experience!
Thanks again,
Tom
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
PostPosted: Tue Sep 23, 2014 4:39 pm    Post subject: Stator Reply with quote
experience!
Thanks again,
Tom
Tom,
Have you tried ebay, google, amazon, etc? How about posting a pic with
accurate measurements? Here's the 1st site I found with a google search
for 'motorcycle alternator stator':
http://www.jpcycles.com/motorcycle-stators
It shows pics of dozens of models; you should be able to narrow down the
choices a lot just by appearance, and then counting generating coils &
trigger coils (likely one or at most two trigger coils; should be
obviously different).
You can also try googling 'outboard motor alternator stator'.
Or better yet, have you asked on lists that are frequented by users of
aerovee engines? Odds are good that *somebody* has already found an
aftermarket solution.
PostPosted: Sat Sep 27, 2014 8:16 am    Post subject: Stator Reply with quote
Has anyone actually rewound a stator? My plan is to chamfer the edges of
the poles slightly since they are square and quite sharp on the edge. Then
cover the stator in kapton tape. Then use two strands of 16 gauge to wind
19 turns on each pole (total of 2x19=3Cool which is what is there now.
Does anyone have a better idea??
Tom
PostPosted: Sat Sep 27, 2014 11:33 am    Post subject: Stator Reply with quote
Sounds good. The chamfer doesn't need to be
much more than to 'break' the sharp corner.
The Kapton is probably good. I've also seen
multiple layers (like 10 or so) of the Teflon
thread tape as an insulation between wires
and laminations.
Your present winding is bi-filar? Connected
in series or parallel?
Eric M. Jones
PostPosted: Sun Sep 28, 2014 6:02 am    Post subject: Re: Stator Reply with quote
I've also seen multiple layers (like 10 or so) of the Teflon
thread tape as an insulation between wires and laminations. Bob N.
That's probably true, but that doesn't make it right. Don't use it.
As for rewinding things, I've rewound a few motors and transformers in my salad days. I've even had to rewind the same Volvo wiper motor twice...it's a learning process. I even used an old record player to wind 10,000 turns of hair-thin wire on an early audio transformer. You can do well at this with the right materials and advice. And I wouldn't be surprised if you find someone to do it for you for short money.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Sun Sep 28, 2014 7:19 am    Post subject: Stator Reply with quote
Can you elaborate?
To be sure, education was never cheap in terms of time
and expense . . . but we're free . . . at least for now
to choose what topics in which we wish to invest our
educational budget.
The List is an opportunity to share lessons learned and
to sift alternatives. The teacher's imperative "Don't
use it" is of little value unless the underlying foundations
are offered as to why.
Until he mentioned what appears to be a bi-fillar
winding, the task was relatively low risk. Now, if
we are to serve the questioner well, we need to
make sure that WE and ultimately HE understands
the significance of two wires laid down together.
Goto page 1, 2  Next
Page 1 of 2
