Compressor shearing shaft.
YAKY52
PostPosted: Wed Sep 10, 2014 2:46 pm    Post subject: Compressor shearing shaft. Reply with quote
I toke off compressor from the airplane because I didn't have any pressure building in the bottle.
Results the two pieces of the shafts sheared in correspondence of the joining rivets.
No big deal simple repair but.....
How many rivets are supposed to be fitted in the two half of the shafts??
There is space for 6 of them but I found just 2 steel rivets which looks a bit too weak setting to me.
Any suggestion or personal experience or knowledge???
Thank you.
cjpilot710(at)aol.com
PostPosted: Wed Sep 10, 2014 5:17 pm    Post subject: Compressor shearing shaft. Reply with quote
There only 2 rivets that act as shear points.
Pappy
In a message dated 9/10/2014 6:52:56 P.M. Eastern Daylight Time, vulavula(at)libero.it writes:
--> Yak-List message posted by: "YAKY52" <vulavula(at)libero.it>
Thank you.
http://forums.matronics.com/viewtopic.php?p=430325#430325===============================================
_-= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
richard.goode(at)russiana
PostPosted: Thu Sep 11, 2014 12:08 am    Post subject: Compressor shearing shaft. Reply with quote
There are just two rivets, but they are a special and quite soft steel that
is designed to shear if the load to the compressor becomes too great. If,
however, they are too strong, then they will not shear and can cause damage
elsewhere.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
byronmfox(at)gmail.com
PostPosted: Thu Sep 11, 2014 5:59 am    Post subject: Compressor shearing shaft. Reply with quote
This compressor shear pin failure has happened twice to the M14P on my CJ. In both cases, the compressor overheated because of insufficient ram air cooling. The compressor's piston was gummed up with deteriorated oil which had become a gritty substance.
The fix was to copy the compressor cooling horn/shroud from a Yak 18T. It delivers more cooling ram air because it half surrounds the compressor. It's constructed of carbon fiber. The local fellow who built it for me intends the produce more, but can't seem to find the time to create a master plug from which copies can be replicated. He's had several requests. I'll bug him again. Hope the photos come through.
Blitz Fox
415-307-2405
[quote] On Sep 11, 2014, at 1:05 AM, "Richard Goode" <richard.goode(at)russianaeros.com> wrote:
elsewhere.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
 Filesize:  35.44 KB
 Viewed:  6225 Time(s)
 Filesize:  40.08 KB
PostPosted: Thu Sep 11, 2014 9:07 am    Post subject: Compressor shearing shaft. Reply with quote
It is also worth saying that these compressors are not that strong and often
fail before the engine reaches its TBO. There are two solutions - the first
is to make sure it is well-cooled, in that I know of many installations
where they do not have cold air ducted onto them and will inevitably fail,
or, at its least, reduce the life.
The other is to have a cockpit controlled tap with which one can
remove all the load from the compressor once pressure has been built up,
which means that, for most the time, it is operating at no load and will
have a much longer life. Of course, you need to remember to shut the tap
before landing so you still have a compressor for flaps and brakes!
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
GeorgeCoy
PostPosted: Thu Sep 11, 2014 9:41 am    Post subject: Compressor shearing shaft. Reply with quote
We have new couplings with original shear pins installed in stock. Contact
off list.
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com
http://motorstarna.com/
SKYPE george.coy
kingcj6(at)aol.com
PostPosted: Thu Sep 11, 2014 9:17 pm    Post subject: Compressor shearing shaft. Reply with quote
No info/data showing...
