yellowbird1
Posted: Sun Aug 31, 2014 2:19 pm Post subject: Rudder Failure on my Xtra. |
Kolbers,
The good news is that no one was ingured and the aircraft damage was relatively minor. It could have been a lot worse if it happened in the air.
Recently we had a taxi test in my Xtra with a once around the pattern and shortly after landing the right rudder failed! Atfter a sharp left turn to exit off the runway, without the benefit of a taxiway, the Xtra ending up off the runway with both axels sheered off at the wheel and a bent right wing tip.
After getting the plane back to the hanger I found that the rudder failure was caused by the weld failing between the upright square bar that connects the rudder to the cables. I also noticed that the axel is hollow. Should the axel be solid?
Have any of the Kolbers experienced this before and if so, any suggestions as to the cause of the failure and the best course of action, repair or replace the failed part?
I have attached the photos of the failed part and the sheered axel.
Brad Nation
MK III Xtra
[img]cid:09A6A75C-863B-49A9-9F0D-1B415299FCDF(at)home.network[/img]
[img]cid:1967EC0B-118F-44CE-93C9-8FB1326113CC(at)home.network[/img]
[img]cid:B071CC03-B143-4A02-8895-FBA574E18573(at)home.network[/img]
[img]cid:E6DE017F-4284-4CCF-A700-DDC7BD3E70D0(at)home.network[/img]
84.14 KB |
21807 Time(s) |
60.28 KB |
21807 Time(s) |
86.63 KB |
21807 Time(s) |
102.71 KB |
21807 Time(s) |
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
neilsenrm(at)gmail.com Guest
Posted: Sun Aug 31, 2014 6:47 pm Post subject: Rudder Failure on my Xtra. |
The kolb list is very valuable in spreading the word if there is an issue.
Thanks for reporting it.
I think the issue might be that the rudder control system wasn't designed
to handle the load that toe brakes put on the rudder control system. Flight
loads and ground control steering just doesn't put that much load on it.
Like so many things when a seemingly small change is made it can effect a
bunch of other things. Those of us that have the old heal brakes shouldn't
have a issue. For those that have toe brakes check for stress in the area
described. Also check the rudder control horn on the rudder and the rudder
hinges. It would seem that some beefing up of the rudder system is in order
when using the newer toe brake setup. Seems like there was one toe brake
installation that increased the leverage to the master cylinders for this
very reason. Maybe both areas need to be looked at. In the mean time don't
stand on those toe brakes.
As always worth what you paid for it and refunds anytime.
Rick Neilsen
Redrive VW Powered MKIIIC
On Sun, Aug 31, 2014 at 8:47 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
[quote] Not rudder failure, but what looks like a rudder crank that failed, not
because the weld failed, but the round tube wall stressed cracked over time
and failed. I had a similar aileron crank failure on a Ultrastar in 1985
Posted: Mon Sep 01, 2014 7:57 am Post subject: Rudder Failure on my Xtra. |
Brad/All
The both axles failing at the same time got me thinking. I see dual Matco brake calipers (one may be a bigger caliper) along with the failed rudder controls. I would bet that the brakes were slammed on extremely hard sheering off the axles and braking the rudder system. Not sure what to say. It looks like the brakes were instantly locked up putting way too much torque on the axles. What landing gear legs did you have? Â I would guess a nose over could have occurred if things hadn't failed.
 I have the original Kolb optional solid tapered spring steel gear legs. Not sure how they would handle that much braking force.
Again worth what you paid and refunds anytime.
Rick Neilsen
On Sun, Aug 31, 2014 at 6:19 PM, Brad Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)> wrote:
| Quote: | Kolbers,
Recently we had a taxi test in my Xtra with a once around the pattern and shortly after landing the right rudder failed! Â Atfter a sharp left turn to exit off the runway, without the benefit of a taxiway, the Xtra ending up off the runway with both axels sheered off at the wheel and a bent right wing tip.
After getting the plane back to the hanger I found that the rudder failure was caused by the weld failing between the upright square bar that connects the rudder to the cables. I also noticed that the axel is hollow. Â Should the axel be solid?
Brad Nation
MK III Xtra
84.14 KB |
21780 Time(s) |
102.71 KB |
21780 Time(s) |
86.63 KB |
21780 Time(s) |
60.28 KB |
21780 Time(s) |
yellowbird1
Posted: Mon Sep 01, 2014 1:25 pm Post subject: Rudder Failure on my Xtra. |
The rudder control failed first causing the hard left turn and running into the soft dirt embankment which caused the wheels to sheer off. The gear legs are tapered steel. The gear legs were buried in the dirt about 4 - 5 inches. Most of the time around here the dirt would have been as hard a concrete, but we have had a very wet rainy season, and would most likely just ridden up the embankment and not into it.
The reason for the dual breaks is that the single ones were not providing enough break pressure. I wasn’t able to hold the plane while doing a run up. I could have replaced the masters or added another set of pads, I opted for the extra pads.
On Sep 1, 2014, at 9:56 , Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote:
[quote]Brad/All
The both axles failing at the same time got me thinking. I see dual Matco brake calipers (one may be a bigger caliper) along with the failed rudder controls. I would bet that the brakes were slammed on extremely hard sheering off the axles and braking the rudder system. Not sure what to say. It looks like the brakes were instantly locked up putting way too much torque on the axles. What landing gear legs did you have? I would guess a nose over could have occurred if things hadn't failed.
Rick Neilsen
| Quote: | Kolbers,
Brad Nation
MK III Xtra
<IMG_0971.jpg>
<Rudder failure close up.jpeg>
<IMG_0973.jpg>
<IMG_0993.jpg>
Albuquerque, NM
MK3 Xtra |
Dennis Kirby
Joined: 05 Dec 2013 Posts: 35 Location: Albuquerque, NM
Posted: Wed Sep 03, 2014 1:23 pm Post subject: Rudder Failure on my Xtra. |
J.Hauck wrote:
<< Not rudder failure, but what looks like a rudder crank that failed, not because the weld failed, but the round tube wall stressed cracked over time and failed. I had a similar aileron crank failure on a Ultrastar in 1985. Weld was good but the rotating tube wall stress cracked and failed. First I have heard of this type failure in a rudder crank. >>
Kolbers -
Hauck is correct: It was the torque tube on the rudder pedal assembly that failed on Brad's Xtra ... not the weld. Failure was likely due to accumulated stress on the part. This Kolb aircraft has 240 hours of time on it.
What concerns me is, this was a critical, safety-of-flight component that failed. Good thing this happened on a landing rollout, and not in flight. Why did this steel part fail? Is anybody else who flies the Mark-III Xtra concerned that this same part might fail on YOUR aircraft? No amount of rudder pedal pressure exerted by a person in the cockpit should cause this part to break. Otherwise, the part is not designed strong enough.
Rick Neilsen suggested that the extra stress from the pedal-mounted toe brakes may have contributed to the failure. OK, but that is still a Kolb-provided option - not some homebuilder's one-off modification. The part should be built to take that kind of stress.
Seems to me that Kolb should be making this part from thicker-walled steel tubing. I hope the Kolb factory doesn't wait until another failure of this kind happens - with a possible horrible aftermath - before they decide to improve the design of that part.
Sorry for the rant here, but the somewhat lukewarm response from our Kolb community to this alarming failure has motivated me want to ask these questions. I guess you could say my confidence in the Kolb design is a little bit shaken after seeing this. Should we worry about any of the OTHER welded steel parts that we trust will remain intact to fly our Kolbs safely?
Dennis Kirby
Mark-III (Classic)
Flying it for 12 years
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Thu Sep 04, 2014 7:55 am Post subject: Re: Rudder Failure on my Xtra. |
I agree, it is disconcerting to have a flight critical part fail. Please remember you are flying an experimental aircraft. It is built with non aircraft (approved) parts and not designed and built to approved aircraft standards. Even when planes are built with approved parts they fail. I would use this as a wake up call to inspect every piece of steel on your aircraft for cracks. I would mention this desire to the next person who annuals the aircraft. It is good you have posted this on the list so others can immediately go inspect their aircraft. Use this as an opportunity to adjust your perspective and make yourself safer.
Posted: Thu Sep 04, 2014 10:21 am Post subject: Rudder Failure on my Xtra. |
Jason O/Kolbers:
The reason I bought my first Kolb aircraft kit, an Ultrastar, February 1984,
was because it was delivered with, primarily, aviation parts and material.
Even then, I had an aileron bell crank fail like the MKIIIx rudder bell
crank. Pulled the crank right out of the tube wall, weld and all. As far
as I know, I am the only one that achieved that mark of distinction. There
may have been others, but Homer Kolb kept it a secret if there was.
Kolb aircraft are built with standard aviation parts and material,
especially in flight critical areas. There are non-standard items on Kolb
aircraft, but most all of them are not used in flight critical systems.
I got a feeling our friend has a strong leg and a strong arm on the
controls. Took some work to weaken the rudder pedal bell crank and axles,
to the point they failed his last landing. I may have the heaviest MKIII in
the inventory, and probably fly with heavier loads than most. I used those
same axles and wheels for more than two thousand hours and thousands of
landings. Never broke an axle but broke the weld/tube wall from the gear
leg/axle socket. I have a feeling if I had kept on accumulating hours and
landings on those 5/8" axles, they would have failed too.
Personally, and my opinion only, the failure of a rudder pedal or bell crank
is not flight critical on a Kolb. If you were club footed enough to break
one in the air, you can fly and land the Kolb without killing yourself.
Here's where it is nice to have good differential braking, that works. Very
easy to maintain and control yaw, and steer the Kolb on the ground with
differential brakes. Because I have around 100 lbs on my tail wheel, I
depend on differential brakes most of the time to help me control my MKIII
on the ground.
Kolbs are experimental to a point. For the most part, Hauck's opinion
again, that doesn't mean much except the aircraft may have been amateur
built and has not been certified. I have an FAA Airworthiness Certificate
issued for N101AB. That's good enough for me. I like to think Homer Kolb's
airplanes have been tested with thousands and thousands of flight hours over
the past 30 plus years. Like Jason said, there are parts that wear out and
break on certified aircraft. When something like that happens to our Kolbs,
this is a good place to share so we can all make note of it and take
necessary action to fix it.
_________________ John Hauck
Titus, Alabama |
rickofudall
Posted: Thu Sep 04, 2014 2:17 pm Post subject: Rudder Failure on my Xtra. |
Jason, The 4130 seamless steel tubing used in a Kolb IS aircraft quality, so are the aluminum alloys that make up the spars, ribs and control surfaces, the AN bolts that hold parts together and the cloth that covers it all. Please take the time to think before you post such nonsense. Now about the break. The best thing to do is have the part analyzed to see what caused the break. Too much heat used during the welding process? Allowing the weld to cool too fast? There are a number of causes that a metallurgical lab would be able to pinpoint, Then we could all make a reasoned decision about what steps to take AFTER we know the TRUE cause. What we don't need is incoherent raving.
My 2 cents. Carry on.
Rick Girard
On Thu, Sep 4, 2014 at 10:56 AM, Jason Omelchuck <jason(at)trek-tech.com (jason(at)trek-tech.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com (jason(at)trek-tech.com)>
http://forums.matronics.com/viewtopic.php?p=429973#429973
-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
rickofudall
Posted: Thu Sep 04, 2014 2:36 pm Post subject: Rudder Failure on my Xtra. |
As long as I'm thinking about it, here's a simple thing Brad could do that would help start the investigation. Pull out the part that broke off and look at the nature of the break. Is there a part that shows signs of corrosion, i.e. rust? This would most likely be where the crack started. Is there a portion that appears as though the weld did not penetrate both sides of the weld line? Is there a portion of the crack that appears polished? This would indicate that after the crack started the two parts worked against each other as the crack grew. How much of the material appears grainy? This would be the area that finally gave up when the last stress was applied and the part finally failed. >From this visual analysis reasonable ideas about whether the failure was caused by a manufacturing defect, a design defect, or a material defect.
Anyway, that's where I'd start if it were my rudder pedal weldment.
Again, my 2 cents, or is that 3?
Rick Girard
On Thu, Sep 4, 2014 at 5:16 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
| Quote: | Jason, The 4130 seamless steel tubing used in a Kolb IS aircraft quality, so are the aluminum alloys that make up the spars, ribs and control surfaces, the AN bolts that hold parts together and the cloth that covers it all. Please take the time to think before you post such nonsense. Now about the break. The best thing to do is have the part analyzed to see what caused the break. Too much heat used during the welding process? Allowing the weld to cool too fast? There are a number of causes that a metallurgical lab would be able to pinpoint, Then we could all make a reasoned decision about what steps to take AFTER we know the TRUE cause. What we don't need is incoherent raving.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
Jason Omelchuck
Posted: Thu Sep 04, 2014 4:02 pm Post subject: Re: Rudder Failure on my Xtra. |
Rick, your MKIII must have been different than mine because mine was not built to any aircraft standard. I did not compare the parts I received to the engineering drawings, I did not even receive dimensional drawings to compare the parts to. Heck I even put a plaque in my that stated it was amateur built and did not comply with FAA standard aircraft rules. Mine was put together with a couple of thousand hardware store stainless steel pop rivets. The poly fiber I used was not FAA/PMA stamped. I think you take my post the wrong way. I like Kolbs and think they are fine aircraft and for me that is not diminished by the fact it does not meet aircraft standards. Some of the parts I used may be the same alloys or manufactured the same way as aircraft parts but that does not make the airplane built to FAA aircraft standards.
FWIW
Jason
baberdk
Joined: 23 Jan 2014 Posts: 53 Location: East Moline, Il
Posted: Fri Sep 05, 2014 6:09 am Post subject: Rudder Failure on my Xtra. |
Has anyone thought about putting springs in series with the rudder cables to prevent overstressing the parts? Sincerely,
Denny Baber
rowedenny
Posted: Fri Sep 05, 2014 6:30 am Post subject: Rudder Failure on my Xtra. |
Absolutely not! 😬
Dennis "Skid" RoweMk3, Rotax 670,
Leechburg, PA
On Sep 5, 2014, at 10:09 AM, Denny Baber <baberdk(at)gmail.com (baberdk(at)gmail.com)> wrote:
[quote]Has anyone thought about putting springs in series with the rudder cables to prevent overstressing the parts? Sincerely,
Denny Baber
List"">http://www.matronics.com/Navigator?Kolb-List
rickofudall
Posted: Sat Sep 06, 2014 6:49 am Post subject: Rudder Failure on my Xtra. |
Denny, I don't know which model Kolb you have, but if it's a Mk III the next time you're flying take your feet off the rudder pedals. That's why you want a firm connection between pedals and rudder.
Rick Girard
On Fri, Sep 5, 2014 at 9:09 AM, Denny Baber <baberdk(at)gmail.com (baberdk(at)gmail.com)> wrote:
| Quote: | Has anyone thought about putting springs in series with the rudder cables to prevent overstressing the parts? Sincerely,
Denny Baber
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
Posted: Sat Sep 06, 2014 7:18 am Post subject: Rudder Failure on my Xtra. |
I have tension on my rudder pedals feet on or off. Kolbs, most of them, suffer from rudder shuffle, which may lead into rudder flutter if ignored, which is easy to do on long cross country flights over boring terrain. I double spring'd my rudder pedals which eliminates rudder shuffle. Richard Pike eliminated the problem on his MKIIIc by designing a rudder counter balance weight.
Overstressing the rudder control system is a pilot problem. Depends on how badly you scare yourself.
I've been around Kolb airplanes for a good while. First time I have heard of a rudder bell crank failure on a MKIIIx. The other model Kolbs don't use that system. I can testify how much abuse rudder pedals can take by relating a few of my accidents and screw ups. Sudden stops will peg the G meter in forward deceleration. Imagine what kind of stress that puts on the rudder pedals.
Titus, Alabama - Packing my bag and loading my MKIII for an early morning departure in the morning. All I have to do is get up and get going.
                  [quote] Denny, I don't know which model Kolb you have, but if it's a Mk III the next time you're flying take your feet off the rudder pedals. That's why you want a firm connection between pedals and rudder. Rick Girarddo not archive[b]
Titus, Alabama |
russk50(at)gmail.com Guest
Posted: Sat Sep 06, 2014 3:29 pm Post subject: Rudder Failure on my Xtra. |
HEY JOHN
BONG VOYAGE AND HAVE A GREAT FLITE!
WE ALL ENVY YOU
RUSS
undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
Posted: Sat Sep 06, 2014 3:56 pm Post subject: Rudder Failure on my Xtra. |
Ditto that, John. Big time envy!
Dave Kulp
Sent from my Verizon Wireless 4G LTE Smartphone
-------- Original message --------
Date:09/06/2014 7:29 PM (GMT-05:00)
Subject: Re: Kolb-List: Rudder Failure on my Xtra.
--> Kolb-List message posted by: kinne russ <russk50(at)gmail.com>
HEY JOHN
WE ALL ENVY YOU
RUSS
_-============================================================
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
Wish you all could fly along with me.
john
Titus, Alabama |
lcottrell
On Sat, Sep 6, 2014 at 5:29 PM, kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)>
HEY JOHN
WE ALL ENVY YOU
RUSS
Yeah, but John doesn't smoke!
LarryÂ
| Quote: | ===========
yellowbird1
Posted: Sat Sep 06, 2014 6:50 pm Post subject: Rudder Failure on my Xtra. |
You think we could stay with the topic of the original post? Just a suggestion
Yellow Bird 1
Brad Nation
MKIII Xtra
N952DK
On Sep 6, 2014, at 17:29 , kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)>
HEY JOHN
WE ALL ENVY - The Kolb-List --> http://www.matronics========================[b]http://www.matronics.com/co=================
Albuquerque, NM
MK3 Xtra |
baberdk
Posted: Mon Sep 08, 2014 5:08 am Post subject: Rudder Failure on my Xtra. |
I have a Mark III, but I didn't mean to imply to disconnect the rudders. What I meant to say was to put springs in series between the rudders and the pedals that would withstand around two hundred pounds of tension. The only time they would operate would be if you pushed on both pedals and exceeded the springs limits, but before you could damage metal parts. The only time they would operate would be to save the plane from pilot error. I have not tried this, I was wondering if anyone had thought about it and tried it so I wouldn't have to. Sorry for the misunderstanding.
Sincerely,
Denny Baber
