AvMAP Ultra EFIS
pa3arw(at)ziggo.nl
PostPosted: Thu Aug 28, 2014 3:16 am    Post subject: AvMAP Ultra EFIS Reply with quote
Hi Yakkers,
I own a YAK52/PH-YAK, based in the Netherlands.
I am looking to replace the front horizon with the latest AvMAP Ultra EFIS.
Because of the Special CofA which we have in the Netherlands our CAA is not authorized to give their blessing on this possible installation.
They will, however, accept an approval from any other CAA or e.g. FAA.
Now on the website of AvMAP under the heading of the Ultra EFIS a photograph is shown of an installed EFIS in a YAK52 with callsign N58GC.
Does anybody know the owner of this YAK or does anybody else have a document which shows the approval of this device for use in a YAK52??
Thanks to the net for helping me out on this matter.
Hans Oortman
PH-YAK
dsavarese0812(at)bellsout
PostPosted: Thu Aug 28, 2014 4:00 am    Post subject: AvMAP Ultra EFIS Reply with quote
Hans,
Since all Yak 52's registered in the US are certified in the Experimental Exhibition category, (the key word is "experimental), they do not require any "approval" by the FAA other than the annual condition inspection which confirms the airplane is in a condition for safe operation. So we here in the US may not be much help with regards to an "approval". Effectively all that is normally done is a log book entry stating the installation of such and such device. Then during the condition inspection an FAA certified mechanic signs off the condition inspection certifying the airplane is "in a condition for safe operation".
The owner of N58GC is listed in the FAA aircraft registration data base. Use this link and enter the N number of the airplane and it will pull up all public information pertaining to that specific airplane.
http://registry.faa.gov/aircraftinquiry/NNum_Inquiry.aspx
Hope this helps.
Dennis
From: Hans Oortman <pa3arw(at)ziggo.nl> To: yak-list(at)matronics.com Sent: Thursday, August 28, 2014 6:15 AM Subject: Yak-List: AvMAP Ultra EFIS
AvMAP Ultra EFIS Hi Yakkers, I own a YAK52/PH-YAK, based in the Netherlands. I am looking to replace the front horizon with the latest AvMAP Ultra EFIS. Because of the Special CofA which we have in the Netherlands our CAA is not authorized to give their blessing on this possible installation. They will, however, accept an approval from any other CAA or e.g. FAA. Now on the website of AvMAP under the heading of the Ultra EFIS a photograph is shown of an installed EFIS in a YAK52 with callsign N58GC. Does anybody know the owner of this YAK or does anybody else have a document which shows the approval of this device for use in a YAK52?? Thanks to the net for helping me out on this matter. Hans Oortman PH-YAK [quote][b]http://forums.matronics.com style="" class="" rel="nofollow" target="_blank" href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
GeorgeCoy
PostPosted: Thu Aug 28, 2014 4:01 am    Post subject: AvMAP Ultra EFIS Reply with quote
58GC is owned by Grant Farrell in Illinois. unfortunately it will not help you, as it is an experimental aircraft here in the U.S. and FAA approval is not required to install the AVmap Ultra EFIS. Your might be better off with a Dynon system as they are installed in several Light Sport aircraft and sort of 1/2 way are blessed by the FAA.
George Coy
PS the GC in 58GC are my initials. It means it was one the we imported.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Hans Oortman
Sent: Thursday, August 28, 2014 7:16 AM
Subject: AvMAP Ultra EFIS
Hi Yakkers,
Hans Oortman
PH-YAK
Dale
PostPosted: Thu Aug 28, 2014 11:27 am    Post subject: Re: AvMAP Ultra EFIS Reply with quote
AvMap is a Eu company based in Italy. You might see if there is any chance they are working on a Eu cert. Grant works for AvMap.
pa3arw(at)ziggo.nl
PostPosted: Fri Aug 29, 2014 12:20 am    Post subject: AvMAP Ultra EFIS Reply with quote
Thanks George...
It’s a small world.... I am looking specifically for Yak52’s. Our CAA doesn’t care about other aircraft.
My best chance will probably be in the UK or France for this matter.
Thanks again for the info.
Hans O.
PH-YAK
Op 28-08-14 14:00, George S. Coy <[url=george.coy(at)gmail.com]george.coy(at)gmail.com[/url]> schreef:
[quote]58GC is owned by Grant Farrell in Illinois. unfortunately it will not help you, as it is an experimental aircraft here in the U.S. and FAA approval is not required to install the AVmap Ultra EFIS. Your might be better off with a Dynon system as they are installed in several Light Sport aircraft and sort of 1/2 way are blessed by the FAA.
George Coy
From: mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Hans Oortman
To: [url=yak-list(at)matronics.com]yak-list(at)matronics.com[/url]
Hi Yakkers,
Hans Oortman
PH-YAK
ail Forum -
">http://www.matronics.com/Navigator?Yak-List
; - MATRONICS WEB FORUMS -
matronics.com
;- List Contribution Web Site -
;   -Matt Dralle, List Admin.
jan.mevis(at)informavia.b
PostPosted: Fri Aug 29, 2014 12:34 am    Post subject: AvMAP Ultra EFIS Reply with quote
Hello Hans,
I think that you can get support for this from Lithuania. The odds are that they (Termikas) already did this.
Since Lithuania plays the European EASA game, if their CAA allows it, then that's a good argument towards the Dutch CAA.
BR,
Jan
From: Hans Oortman <pa3arw(at)ziggo.nl (pa3arw(at)ziggo.nl)>
Reply-To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Date: Friday 29 August 2014 09:35
Subject: Re: AvMAP Ultra EFIS
Re: AvMAP Ultra EFISThanks George...
Hans O.
PH-YAK
George Coy
Hi Yakkers,
Hans Oortman
PH-YAK
ail Forum -
matronics.com
com
Etienne Verhellen
PostPosted: Tue Sep 16, 2014 11:25 am    Post subject: Re: AvMAP Ultra EFIS ... or ... Dynon D10A. Reply with quote
Hello Hans !
Hope you are well ... in The Netherlands ... or in Florida Cool
A little while ago in August you sent me an e-mail
regarding installation of an EFIS on your European registered Yak-52 PH-YAK.
Sorry I did not reply straight away ... Have been very busy lately,
older daughter starting University in The Netherlands (TU Delft),
father passed away on Friday 5 September, BA flying keeping me away from home ...
just arrived in SΓ£o Paulo after a 11 hours and 13 minutes flight ...
Cannot find your message in Mailbox so posting on the Yak-List.
Our American friends cannot help you on this one because like George and Dennis mentioned,
they are lucky in the US of A, Yaks are EXPERIMENTAL
and installation of new equipment or modifications are no big deal
with the pragmatic approach adopted by the FAA.
But all is not lost because installation of EFIS is approved by the UK CAA.
And it has been for a while.
I really wonder on what basis the Dutch CAA would ban you to install
an EFIS in your Yak-52.
I would also find this quite ironic because for years they were happy to let Yaks fly
in The Netherlands with illegal Certificate of Airworthiness ...
(Just a quick reminder : Yaks cannot get C. of A. because they are Annex II aircraft
and that's why the UK CAA has always been issuing Permit to Fly to them
and why they are EXPERIMENTAL in the USA ...)
The Dutch CAA (like all other CAA in continental Europe) had absolutely no control
on what was going on regarding prescriptions from the manufacturers (YDB) regarding Life Items,
Airframe Life extensions, propeller overhaul. Engine TBO, ...
Different European CAAs have different ideas ...
For instance the French CAA is quite happy with installing fuel bladders ...
'Plug conversion' is EASA approved
http://www.yak-52.com/downloads/ac12419.pdf
The Belgian CAA has absolutely no clue about dealing with Yaks ...
Hopefully UK registered Yaks will soon be administrated by the LAA.
http://www.lightaircraftassociation.co.uk
But to answer your specific issue of installing equipments in Yaks, Hans,
your best port of call is probably the UK CAA itself.
Or contacting people dealing with Yaks in the UK, Richard of course, Yak UK
(they installed a DYNON EFIS - D10A in our Yak-52, see photo attached),
http://www.aerobuzz.fr/IMG/jpg/image-17.jpg
Horizon Aircraft Services in St Athan (EGDX), Wales :
http://www.horizonaircraft.co.uk/maintenance.html
https://www.flickr.com/photos/62441905(at)N03/14331355930/
https://www.flickr.com/photos/62441905(at)N03/14494914066/
my friend Jez Hopkinson from the YAKOVLEVS formation aerobatic display team.
He has installed EFIS (and Garmin GNS 530) in all his Yak-50 / Yak-52.
http://www.yakovlevs.com/team-yakovlevs/our-aircraft/
http://www.yakovlevs.com/wp-content/gallery/aircraft/img_0332.jpg
http://www.yakovlevs.com/wp-content/gallery/aircraft/cockpit.jpg
Anyway having said all that, installation of an EFIS is a good idea if you do a little be of travelling with your flying machine.
I decided to install the Dynon D10A a few years ago after flying
for 45 minutes in clouds coming back from the South of France
(a 4 hour 15 minutes flight) with my wife and our little dog in the back seat ...
I had to fly with a constant 5 degree of bank on the Russian Attitude Indicator
to stop the compass indicator from slowly spinning, trying to maintain a constant heading to get us home.
Since then I had the opportunity to use the Dynon Artificial Horizon quite a few times going places for Airshows
or coming back to base in less than ideal weather condition.
Quite a few missions I would not have been able to complete without it.
So highly recommended. I would not trust the Russian horizon installed in 99.9 % of Yaks.
VoilΓ  Hans, hope you will have an EFIS installed in your Yak soon.
Off with the Crew to the nearest Churrascaria on Paulista for some meat
and a couple of glasses of red wine Very Happy Cheers, Etienne.
 Filesize:  595.12 KB
 Viewed:  23482 Time(s)
Yak-50 Display Pilot - Airshows - Π―ΠΊΠΎΠ²Π»Π΅Π² Π―ΠΊ-50
Yak-52 training anywhere - FI(A) Aerobatic Instructor - Specialised Yak-52.
https://www.yakoteam.com/
https://www.yakovlevs.com/the-team/pilots-and-crew/
Etienne Verhellen
PostPosted: Tue Sep 16, 2014 12:19 pm    Post subject: Boeing 747 EFIS instead of Yak-52 Dynon D10A ... Oops Reply with quote
Oops ... Exclamation
# Have sent photo of 747 EFIS ... Instead of Yak-52 !
http://forums.matronics.com//files/image_299.jpg
# Ground Speed of 612 knots with a 122 it's Tail Wind
would be interesting in a Yak-52 ...
Photo was taken during night flight across the Pond, from JFK
on our way to LHR on course to 30 degrees West (Mid-Atlantic)
FL 360 / M.84 at 02.56 in the morning ...
# Anyway find photo of Dynon EFIS D10A installed in our Yak
Attached below.
Cheers, Etienne.
 Filesize:  793.02 KB
 Viewed:  23470 Time(s)
 Filesize:  486.19 KB
Etienne Verhellen
PostPosted: Tue Sep 16, 2014 1:29 pm    Post subject: DYNON EFIS - D10A. Reply with quote
Before DYNON EFIS - D10A :
http://fanairplane.free.fr/affichage2.php?img=7323
http://users.skynet.be/B747/photogallery/Etienne%20G-CBSS/Copie%20de%20G-CBSS%20panel.JPG
After :
http://forums.matronics.com//files/image_232.jpg
β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
http://forums.matronics.com//files/image_571.jpg
pa3arw(at)ziggo.nl
PostPosted: Tue Sep 16, 2014 2:35 pm    Post subject: AvMAP Ultra EFIS Reply with quote
Thanks Etienne for the info. I am just going to build it is and see what happens.
Can you also send me the two previous emails please. My macbook just crashed and I lost the emails because they were not in the backup of course.
Thanks!
Hans
Verstuurd vanaf mijn iPad
Op 16 sep. 2014 om 23:29 heeft "Etienne Verhellen" <janie(at)yak52.fr> het volgende geschreven:
After :
http://forums.matronics.com/viewtopic.php?p=430636#430636
Viperdoc
PostPosted: Tue Sep 16, 2014 7:45 pm    Post subject: AvMAP Ultra EFIS Reply with quote
Etienne,
Are you using the RMU gyro or the internal gyro (oscillometers) in you D10. I have one in my 50 and love it. Have not put it in the 52 yet.
Doc
On Sep 16, 2014, at 4:29 PM, Etienne Verhellen <janie(at)yak52.fr> wrot
After :
Viperdoc
PostPosted: Tue Sep 16, 2014 7:53 pm    Post subject: AvMAP Ultra EFIS Reply with quote
Etienne, your information about the French authorities is inaccurate.
They are not at all "quite happy" with fuel bladders, it is considered
being a major modification.
But they are willing to consider it as a possibility because the French
inspection understood that Dennis' bladders are a good replacement.
Fuel bladders won't crack when flying serious aerobatics.
You are very familiar with that problem.
So they allowed me to continue with the bladders.
The French authorities are still making a detailed inventory of all the
Yaks in France.
The French inspectors are very knowledgeable AND they are open for
pertinent arguments, fortunately!
Sorry to hear about your father, bad news!
BR,
Jan
On 16/09/14 21:25, "Etienne Verhellen" <janie(at)yak52.fr> wrote:
Hello Hans !
PH-YAK.
home ...
Dennis mentioned,
CAA.
let Yaks fly
II aircraft
no control
UK
team.
seat ...
Indicator
99.9 % of Yaks.
http://www.airplane-pictures.net/photo/240525/g-cbss-private-yakovlev-yak-
52/
http://www.airplane-pictures.net/photo/215762/g-cbss-private-yakovlev-yak-
52/
http://www.airplane-pictures.net/photo/403690/g-cbss-private-yakovlev-yak-
52/
http://forums.matronics.com/viewtopic.php?p=430627#430627
Etienne Verhellen
PostPosted: Wed Sep 17, 2014 2:03 am    Post subject: Re: AvMAP Ultra EFIS Reply with quote
Roger that Jan. Take care buddy.
Etienne Verhellen
PostPosted: Wed Sep 17, 2014 2:19 am    Post subject: Re: AvMAP Ultra EFIS Reply with quote
Hi Doc,
using the RMU gyro for the DYNON EFIS -D10A.
And an extra pitot tube. Static from the main.
KR, Etienne.
 Filesize:  840.18 KB
 Viewed:  23432 Time(s)
Viperdoc
PostPosted: Wed Sep 17, 2014 5:43 pm    Post subject: AvMAP Ultra EFIS Reply with quote
Copy Etienne. I'm using a splitter off the original Pitot.
Do
On Sep 17, 2014, at 5:19 AM, Etienne Verhellen <janie(at)yak52.fr> wrote:
Hi Doc,
KR, Etienne.
http://forums.matronics.com/viewtopic.php?p=430664#430664
http://forums.matronics.com//files/image_218.jpg
Viperdoc
