alan_hunter1664
flyingphil2
Posted: Wed Aug 20, 2014 4:47 am Post subject: Re: Fitting new tail plane torque tube |
Hi Alan,
I have the new torque tube as well. Have you asked the factory about this? If so, any response?
Phil
alan_hunter1664
Posted: Thu Aug 21, 2014 5:36 am Post subject: Re: Fitting new tail plane torque tube |
I posed the question to Europa the same time I posted on here. I'll send the response when I get it.
Alan
alan_hunter1664
Posted: Fri Sep 19, 2014 11:44 pm Post subject: Re: Fitting new tail plane torque tube |
I received the following response from Europa but i'm still not 100% happy with just "trim to fit". Anyone else fitted this new standard torque tube that can offer advice?
| Quote: | Dear Alan,
I have looked into the issue you raised and fully agree that the on-line instructions do not in their entirety refer to the current tailplane torque tube standard. The latest standard has pre-drilled shouldered black plastic sleeves fitted, ref: pt no. TP38 rather than the undrilled plain white sleeves, ref: pt no. TP10.
As soon as possible we will proceed to update the online assembly instructions to include the latest design standard whilst retaining the existing instructions for the previous design standard.
But in the mean time you may proceed with your tailplane assembly as I believe the only additional instruction you require, ref: Step 6 onwards is to "Trim the outboard ends of the pre-drilled shouldered TP 38 sleeves in order to achieve the no end float requirement".
In the previous design you had to determine the hole positions in order to achieve the no end float requirement, mark the hole centers and drill them. |
Many thanks
Alan[/b]
alan_hunter1664
Posted: Sat Apr 18, 2015 10:14 am Post subject: Re: Fitting new tail plane torque tube |
Further to the above, I'm now at the stage of fitting the tailplane torque tube but contrary to my first post it appears the new pre-drilled black bushes are too short giving a total of nearly 12mm of end float. I've taken some dimensions noted in the attached. I've sent a query to Europa.
 Download |
| Filename: |
Torque tube.doc |
125.5 KB |
| Downloaded: |
709 Time(s) |
alan_hunter1664
Posted: Wed Apr 22, 2015 7:55 am Post subject: Re: Fitting new tail plane torque tube |
Response from Europa is that I have the issue 2 TP38s but need issue 1TP38s which are Slightly longer.
Alan
flyingphil2
Posted: Thu Apr 23, 2015 2:13 am Post subject: Re: Fitting new tail plane torque tube |
Hi Alan,
Are you saying that the Issue 1 part is correct and the up-issued version is now wrong?
I've no idea what version I have - do you dimensions of the two versions?
Phil
alan_hunter1664
Posted: Thu Apr 23, 2015 12:50 pm Post subject: Re: Fitting new tail plane torque tube |
Hi Phil,
Yes I have the issue 2 TP38s and I need the issue 1 and there is one other builder that has contacted me who has the same problem.
The following information was provided by Europa.
Issue 2 TP38s are 1.625" long
Issue 1 TP38s are 2.25" long.
Best regards
Alan
flyingphil2
Posted: Fri Apr 24, 2015 8:59 am Post subject: Re: Fitting new tail plane torque tube |
Many thanks Alan,
I'll go and see what I have.
You seem to be the 'NG' kit pioneer, breaking new ground, from what I can tell !
