yellowbird1
Posted: Wed Jul 02, 2014 6:48 pm Post subject: Annual |
Kolbers,
It’s time for my first annual on my Xtra. As I purchased the plane I don’t have any reference on doing an annual. What can I do myself and what must be done by an A&P? I would think that I should have an A&P do the engine portion. Any suggestions would be appreciated.
Brad Nation
Yellowbird1
N952DK
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
ceengland7(at)gmail.com Guest
Posted: Wed Jul 02, 2014 7:49 pm Post subject: Annual |
On 7/2/2014 9:50 PM, Brad Nation wrote:
Kolbers,
Brad Nation
Yellowbird1
N952DK
What kind of a/w cert? If it's experimental homebuilt, the only thing
you need an A&P to do is sign off the annual condition inspection.
Legally, anyone can do anything else. Repairs, mods, general service,
anything.
Having said that, it doesn't necessarily mean that just anyone *should*,
at least until they gain some experience. Anyone in your area that has
experience with Kolbs? If so, they could probably help the A&P, because
most A&Ps don't deal with experimentals much.
Charlie
woody
brubakermal(at)yahoo.com Guest
Posted: Thu Jul 03, 2014 5:38 pm Post subject: Annual |
$50. omg I only charge. $42
Sent from Yahoo Mail on Android From: woody <n3022.176(at)gmail.com>;
To: <kolb-list(at)matronics.com>;
Subject: Re: Annual
Sent: Fri, Jul 4, 2014 1:09:07 AM
--> Kolb-List message posted by: "woody" <[url=javascript:return]n3022.176(at)gmail.com[/url]>
When I first purchased my Firestar II, I had an A&P do an annual for me.
He charged me the outrageous sum of $50. There are no panels to open &
no hidden control housings. He took about half an hour & I was right beside him. We then did a weight & balance to check the numbers. The paperwork took almost as much time.......
http://forums.matronicsator tp://www.matronics.com/Navigator?Kolb-List" target=_blank >http://www.matnbsp; -Matt .com/contribution" target=_blank >http://www.matronics.com/contribution</=============
russk50(at)gmail.com Guest
Posted: Thu Jul 03, 2014 6:30 pm Post subject: Annual |
Woody.
I don't know where you are, but $50 seems reasonable to me (I'm in Maine) for an hour's work by a certified professional, who's spent a lot of time & money getting certified.
Russ K
On Jul 3, 2014, at 9:09 PM, woody wrote:
http://forums.matronics.com/viewtopic.php?p=426045#426045
Posted: Thu Jul 03, 2014 7:35 pm Post subject: Annual |
Russ,
I don't know, but strongly suspect that there was a missing in that
message from woody.
Charlie
On 7/3/2014 9:30 PM, kinne russ wrote:
Woody.
Russ K
Posted: Fri Jul 04, 2014 7:42 am Post subject: Annual |
I think you're right!
On Jul 3, 2014, at 11:35 PM, Charlie England wrote:
Russ,
I don't know, but strongly suspect that there was a missing in that message from woody.
Charlie
> Woody.
> Russ K
yellowbird1
Posted: Mon Aug 11, 2014 8:00 pm Post subject: Re: Annual |
My kolb is registered as an N numbered experimental
Albuquerque, NM
MK3 Xtra |
rickofudall
Posted: Tue Aug 12, 2014 7:18 am Post subject: Annual |
Brad, There are two types of experimental certificates most commonly. One is experimental amateur built (EAB), and the other is experimental light sport aircraft (ELSA).Only the original builder can get a repairman certificate for an EAB so a non-builder owner has to hire an A & P to do the annual conditional inspection.
The owner of an ELSA can take a 16 hour class and get a repairman inspection certificate for his/her airplane ONLY. When you get the license from the FAA it will have the N number of your aircraft on it.
There's also the off chance that your aircraft is registered experimental exhibition (EE). If you have that you'd be making annual reports to your local FAA Flight Standards District Office (FSDO) outlining what flying you're going to be allowed to do, so I doubt your aircraft is EE, but you should check, just in case.
For all you $50, one hour annual folks. Go to FAR 43 Appendix D and take a look at all the things required on an annual and tell me how you check all that in one hour and do the paperwork. Either you've hired Speedy Gonzalez or you're doing a pencil whip.
Since you're already in FAR 43, go to 43.12 and contemplate what it says. Take a moment to think about what a lawyer could do to you if there were a crash involving serious injury or loss of life. Think about having everything you've worked for in life taken from you, possibly even your freedom.
Still think that $50 looks reasonable?
Rick Girard
On Mon, Aug 11, 2014 at 11:00 PM, yellowbird1 <nationcap(at)comcast.net (nationcap(at)comcast.net)> wrote:
| Quote: | --> Kolb-List message posted by: "yellowbird1" <nationcap(at)comcast.net (nationcap(at)comcast.net)>
Brad Nation,
Albuquerque, NM
http://forums.matronics.com/viewtopic.php?p=428339#428339
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
e -
     -Matt Dralle, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
 - Groucho Marx
yellowbird1
Posted: Tue Aug 12, 2014 3:29 pm Post subject: Annual |
It is listed as an EAB.Is it even possible to get the registration changed to ELSA?
Brad Nation
On Aug 12, 2014, at 9:18 , Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Brad, There are two types of experimental certificates most commonly. One is experimental amateur built (EAB), and the other is experimental light sport aircraft (ELSA).Only the original builder can get a repairman certificate for an EAB so a non-builder owner has to hire an A & P to do the annual conditional inspection.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Albuquerque, NM
MK3 Xtra |
alienwes
gliderx5
Posted: Tue Aug 12, 2014 6:06 pm Post subject: Annual |
Brad
I believe that you cannot change to ELSA. Only airplane kits that have been demonstrated to be SLSA (factory built LSA) and are offered as a kit that cannot be modified at all are eligible to be ELSA. Furthermore, once it's registered EAB it cannot be changed. The only change allowed is for an SLSA to move to ELSA.
Malcolm Morrison
wienerdogaero.com
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Tuesday, August 12, 2014 7:32:41 PM
Subject: Re: Re: Annual
Brad Nation
| Quote: | Brad, There are two types of experimental certificates most commonly. One is experimental amateur built (EAB), and the other is experimental light sport aircraft (ELSA).Only the original builder can get a repairman certificate for an EAB so a non-builder owner has to hire an A & P to do the annual conditional inspection.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
-List"" target="_blank" data-mce-href="3D"http://www.matronics.com/Navigator?Kolb-List"">http://www.matronics.com/Navigator?Kolb-List
et="_blank" data-mce-href="3D"http://forums.matronics.com"">http://forums.matronics.com
uot;" target="_blank" data-mce-href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/contribution
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Wed Aug 13, 2014 3:44 am Post subject: Re: Annual |
Please correct me if I am wrong; but why in hell would anyone even want to change the registration from EAB to ELSA? If the airplane is registered with a max gross takeoff weight of 1320 pounds or less, most any Kolb qualifies for operation as a Light Sport Aircraft.
_________________ Jerry King |
gliderx5
Posted: Wed Aug 13, 2014 7:21 am Post subject: Annual |
Jerry
Someone might want to so that they could do their own inspections (assuming they don't hold the repairman certificate for their EAB already). By taking the 2 day course you can do your own inspections on your ELSA. But, since you can't change the certification on your EAB it is dosen't matter.
Malcolm Morrison
Wiener Dog Aero
Sent: Wednesday, August 13, 2014 7:44:48 AM
Subject: Re: Annual
--> Kolb-List message posted by: "racerjerry" <gki(at)suffolk.lib.ny.us>
Jerry King
http://forums.matronics.com/viewtopic.php?p=428398#428398
bsp; -================
yellowbird1
Posted: Wed Aug 13, 2014 2:38 pm Post subject: Annual |
Because according to my understanding of the FAR if it registered as a ELSA and I take the 16 hour maintenance course I can do my own annuals.
Brad
___________________________
“Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free.”
-- President Ronald Reagan
On Aug 13, 2014, at 5:44 , racerjerry <gki(at)suffolk.lib.ny.us (gki(at)suffolk.lib.ny.us)> wrote:
[quote]--> Kolb-List message posted by: "racerjerry" <gki(at)suffolk.lib.ny.us (gki(at)suffolk.lib.ny.us)>
Jerry King
- The Kolb-List --> &n========================
Albuquerque, NM
MK3 Xtra |
rickofudall
Posted: Fri Aug 15, 2014 6:55 am Post subject: Annual |
Brad, The short answer is no. Since the grandfathering clause for "fat ultralights" ended on Jan 31st 2010 the only way to get an ELSA certificate is to have a kit built from a qualifying SLSA. See FAR 21.191 (i) 2.
Rick
On Tue, Aug 12, 2014 at 6:32 PM, Brad Nation <nationcap(at)comcast.net (nationcap(at)comcast.net)> wrote:
| Quote: | It is listed as an EAB.Is it even possible to get the registration changed to ELSA?
Brad Nation
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
rickofudall
Posted: Fri Aug 15, 2014 7:00 am Post subject: Annual |
Malcolm, all, An ELSA must only be exactly like its SLSAÂ qualifying aircraft at the time of inspection for the experimental certificate. Once the certificate is issued it's an experimental and you can change ANYTHING you want.
Rick Girard
On Tue, Aug 12, 2014 at 9:04 PM, <gliderx5(at)comcast.net (gliderx5(at)comcast.net)> wrote:
| Quote: | Brad
Malcolm Morrison
wienerdogaero.com
From: "Brad Nation" <nationcap(at)comcast.net (nationcap(at)comcast.net)>
To: "kolb-list" <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
Subject: Re: Kolb-List: Re: Annual
Brad Nation
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
