Keeping temperatures on the ground in the "black"?
tonyrenshaw268(at)gmail.c
PostPosted: Mon Jul 28, 2014 6:30 pm    Post subject: Keeping temperatures on the ground in the "black"? Reply with quote
Leafblower??
TR
On 29 Jul 2014, at 9:05 am, rparigoris <rparigor(at)suffolk.lib.ny.us> wrote:
Hi Group
Has anyone tried to paint Europa radiator (and or inter-cooler) flat black using a leaf blower?:
https://www.youtube.com/watch?v=f1QL9veQaNg
Any help on the ground with cooling of my 914 mono and will be most welcome.
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=427476#427476
rparigoris
PostPosted: Mon Jul 28, 2014 9:18 pm    Post subject: Keeping temperatures on the ground in the "black"? Reply with quote
Hi Tony
He used a leaf blower to blow the paint into the radiator fins. Watch the video.
Ron Parigoris [quote][b]
rob(at)hyperion-ef.com
PostPosted: Tue Jul 29, 2014 9:34 am    Post subject: Keeping temperatures on the ground in the "black"? Reply with quote
I don't care what these clowns "proved" in that video, it is not supported by the science of heat transfer - at the rather low temperatures encountered in an air to air intercooler the dominant modes of heat transfer are convection and conduction, neither of which is affected in the least by the color of the heat exchanger. At much higher temperatures, say 400°C and hotter, then radiation starts to contribute a bit more to heat transfer compared to convection or conduction. Google “Stefan-Boltzmann” to learn a bit about radiative heat transfer.
Painting the surfaces of the heat exchanged will actually impede heat transfer because the paint is less conductive than the aluminum or copper usually used for this sort of heat exchanger. The thickness of the paint will also slightly reduce the area left for air flow thus further degrading the efficiency of the heat exchanger.
“Paint it Black” worked pretty well for the Stones but it won’t for intercoolers.
Best regards,
Rob Housman
Irvine,  California
Europa XS
Rotax 914
S/N A070
Airframe complete
Avionics in progress
