GNS430 Microphone/Sidetone Problem
email(at)jaredyates.com
PostPosted: Thu Jul 24, 2014 9:54 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Today when I started my flight, all seemed well.  Shortly after takeoff I tried to make a radio call, but when I held the mic key, instead of getting the usual sidetone, I got a series of clicks.  I don't recall it doing that when I made my departing radio calls. I plugged a second headset into the other front seat and got the same results when I pushed the other PTT.  I put the second headset back into the original side and tried again with the same result, as to help ensure that the headset wasn't the problem. The first headset was a Bose X through a LEMO plug (which is wired to the adjacent two-plugs per Bose instructions), and the second was a David Clark through the usual two plugs.  I'm away from my usual shop and tools, so I wonder if anyone might have any tips about where to focus my troubleshooting?  Has anyone encountered this type of behavior before out of the 430 or another radio?  This is a single-radio installation with a Flightcom 403 intercom.  The left and right PTT keys are consolidated in the intercom, but with the behavior being the same on both sides, I'm doubtful that the problem would be there.
PostPosted: Fri Jul 25, 2014 10:04 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
clicks. Â I don't recall it doing that when I
the same results when I pushed the other PTT. Â
David Clark through the usual two plugs. Â I'm
focus my troubleshooting? Â Has anyone
the 430 or another radio? Â This is a
intercom. Â The left and right PTT keys are
Does the intercom work? Can you talk between
two headsets? Do people hear your transmissions?
Do you hear their transmissions?
PostPosted: Fri Jul 25, 2014 10:30 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Yes, yes, it doesn't seem so, and yes.
PostPosted: Fri Jul 25, 2014 12:16 pm    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
When you push the PTT, does the transceiver
go into transmit mode?
PostPosted: Fri Jul 25, 2014 2:20 pm    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
I'll have to check Monday, but it seemed to. I should modify my description of the sound to "Static with clicks" when I key the mic, since there is a static element to it also.
PostPosted: Sat Jul 26, 2014 4:44 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
At 05:22 PM 7/25/2014, you wrote:
--> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com>
Okay. If the intercom is working then the
AUDIO paths to the two microphone inputs to
the intercom are intact. Without having
a schematic of the IC . . . I have
no way to deduce how the PTT commands
are processed going though the IC.
In one of the Flightcom installation manuals
I found a suggested tool for bypassing
the IC . . . which is also useful for trouble-
shooting.
[img]cid:.0[/img]
Suggest you check your manual for such a
recommendation and have the tool on hand.
With the IC bypassed the radio should
work normally as if only the pilot's headset
is connected directly to the radio. Whether
or not this produces improved behavior is
an important clue for tracking down root cause
of your problem.
 Filesize:  19.32 KB
 Viewed:  12066 Time(s)
mapratherid(at)gmail.com
PostPosted: Sat Jul 26, 2014 8:03 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Wasn't there some discussion awhile back about how the GNS has two power feed paths and that if one of them opened, the radio would appear to work but it wouldn't transmit? I think someone had this issue when their radio wasn't fully inserted into the tray/rack. Might not be the case here, but could be worth checking out.
Matt-
On Jul 26, 2014, at 6:43 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] At 05:22 PM 7/25/2014, you wrote:
--> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)>
shooting.
<227d876f.jpg>
of your problem.
tim2542(at)sbcglobal.net
PostPosted: Sat Jul 26, 2014 8:32 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
The 430 does have separate comm and NAV power feeds, but I believe most often they are on a single fuse/CB/wire and simply "Y" into the two pins inside the D-sub connector. If the comm side is not powered the comm info display on the RHS of the screen will not be there.
On Jul 26, 2014, at 9:01 AM, Matthew Prather <mapratherid(at)gmail.com (mapratherid(at)gmail.com)> wrote:
[quote]Wasn't there some discussion awhile back about how the GNS has two power feed paths and that if one of them opened, the radio would appear to work but it wouldn't transmit? I think someone had this issue when their radio wasn't fully inserted into the tray/rack. Might not be the case here, but could be worth checking out.
Matt-
shooting.
<227d876f.jpg>
of your problem.
lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List
//forums.matronics.com
uuccio(at)gmail.com
PostPosted: Sat Jul 26, 2014 10:22 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
I had that problem. The GNS430 wasn't fully inserted into its slot and although the RX and TX button lit up it did not seem to transmit (or receive as I remember). See
http://forums.matronics.com/viewtopic.php?t=98650&view=next&sid=a9694aaf0de05619e08664647aea1483
skywagon
PostPosted: Sat Jul 26, 2014 5:04 pm    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Sacha makes a very good point. .
The 430 chassis to box-chassis connector fit is finicky.
I know. . .I have the "T-shirt"
If the box-chassis is mounted in the aircraft panel a little to deep, this
causes a problem. For when the 430 is slid into the box, it will not seat
back deep enough to fully engage some connector pins.
The fix is to loosen up the panel mounted box chassis and pull it forward to
be flush with the panel or even a tad ( 1/16") out in front of the panel and
then re-bolt it back to the panel framing.
Another point. . .I do not recommend that you use the 430 locking jack
mechanism to pull the 430 back into its locked position. If something is
not aligned correctly you will not know it using the this method and could
damage pins.
I suggest that you get the 430 inserted by hand, fingers on each end of the
the 430 panel. Gently rock it back in place feeling for any obstruction.
Get it started in, turn the jacking system just enough to take up the slack.
Then, using fingers only, rock the 430 further back into place and again
feel for any odd resistance, then, using the jack, take up the slack.
Continue this until you "feel" it seat properly with it rear connectors.
Stop if you feel any odd resistance and start over after checking for any
bent pins, etc.
David
jloram
PostPosted: Sun Jul 27, 2014 11:32 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Sound like the voice of experience!
PostPosted: Mon Jul 28, 2014 9:44 am    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Thanks for all of the troubleshooting tips! I removed the 430, visually inspected the pins carefully, and reseated it as David suggests, and it is fixed!
[quote] On Jul 26, 2014, at 21:02, "David Lloyd" <skywagon(at)charter.net> wrote:
If the box-chassis is mounted in the aircraft panel a little to deep, this causes a problem. For when the 430 is slid into the box, it will not seat back deep enough to fully engage some connector pins.
The fix is to loosen up the panel mounted box chassis and pull it forward to be flush with the panel or even a tad ( 1/16") out in front of the panel and then re-bolt it back to the panel framing.
Another point. . .I do not recommend that you use the 430 locking jack mechanism to pull the 430 back into its locked position. If something is not aligned correctly you will not know it using the this method and could damage pins.
I suggest that you get the 430 inserted by hand, fingers on each end of the the 430 panel. Gently rock it back in place feeling for any obstruction. Get it started in, turn the jacking system just enough to take up the slack. Then, using fingers only, rock the 430 further back into place and again feel for any odd resistance, then, using the jack, take up the slack.
Continue this until you "feel" it seat properly with it rear connectors. Stop if you feel any odd resistance and start over after checking for any bent pins, etc.
David
uuccio(at)gmail.com
PostPosted: Mon Jul 28, 2014 12:23 pm    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Great to hear! David's tips are very useful (found out the hard way...)
On Jul 28, 2014, at 19:41, Jared Yates <email(at)jaredyates.com> wrote:
it is fixed!
PostPosted: Tue Jul 29, 2014 3:23 pm    Post subject: GNS430 Microphone/Sidetone Problem Reply with quote
Cool!
Matt-
On Mon, Jul 28, 2014 at 11:41 AM, Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
[quote]--> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)>
> On Jul 26, 2014, at 21:02, "David Lloyd" <skywagon(at)charter.net (skywagon(at)charter.net)> wrote:
> --> AeroElectric-List message posted by: "David Lloyd" <skywagon(at)charter.net (skywagon(at)charter.net)>
> David
