Alternative Tail Wheel Steering System
jbhart(at)onlyinternet.ne
PostPosted: Mon Oct 13, 2008 7:53 am    Post subject: Alternative Tail Wheel Steering System Reply with quote
At 07:09 AM 10/13/08 -0700, you wrote:
You say the "s" hook broke. Why did it break? I'm using the connector that
came with the compression springs from aircraft spruce, and I don't really
like the way it atttaches to the stock kolb tailwheel arm ( seems like a bad
wear point.)
Rob,
I had a similar problem with tension springs breaking and ground looping.
Came up with the following system. It may be of interest to you. See:
http://www.thirdshift.com/jack/firefly/firefly133.html
I have made a few changes since posting the above page. The spoke nuts are
shortened to save weight and round throttle stop collars are used to safety
the spoke nuts. I will be updating the page in the near future.
Jack B. Hart FF004
Winchester, IN
JetPilot
PostPosted: Mon Oct 13, 2008 8:11 am    Post subject: Re: Alternative Tail Wheel Steering System Reply with quote
Compression Springs also make tail wheel steering much more positive and precise. The centering actions of properly set up compression springs is much better than two springs in tension. I made the conversion on my MK III Xtra and it makes a huge difference in the way the plane handles on the ground.
Kolb MK-III Xtra, 912-S
lcottrell
PostPosted: Mon Oct 13, 2008 3:34 pm    Post subject: Alternative Tail Wheel Steering System Reply with quote
Mike B:
I use compression springs also.
Wouldn't leave home without them.
[quote] Compression Springs also make tail wheel steering much more positive and precise. The centering actions of properly set up compression springs is much better than two springs in tension. I made the conversion on my MK III Xtra and it makes a huge difference in the way the plane handles on the ground.
barry9315
PostPosted: Wed Jul 23, 2014 9:32 am    Post subject: Re: Alternative Tail Wheel Steering System Reply with quote
Would love to see a few pics of the tail wheelcompression springs
Rex Rodebush
PostPosted: Wed Jul 23, 2014 12:34 pm    Post subject: Re: Alternative Tail Wheel Steering System Reply with quote
I went to compression springs also but had to disassemble them and pinch the inside hooks to clear the spring I.D. so they would extend freely.
undoctor
PostPosted: Wed Jul 23, 2014 12:36 pm    Post subject: Alternative Tail Wheel Steering System Reply with quote
Hi Barry,
Here's a shot of the compression springs (other side is the same, of
course) on the FlagFly. Also shows a wider tail wheel to replace pizza
cutter.
Dave Kulp
Bethlehem, PA
11DMK
http://forums.matronics.com/viewtopic.php?p=427213#427213
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
 Filesize:  167.33 KB
 Viewed:  8528 Time(s)
PostPosted: Thu Jul 24, 2014 9:45 am    Post subject: Alternative Tail Wheel Steering System Reply with quote
Google tail wheel compression springs and hit photos.
Lake City, Colorado
ceengland7(at)gmail.com
PostPosted: Thu Jul 24, 2014 5:08 pm    Post subject: Alternative Tail Wheel Steering System Reply with quote
Or, google 'screen door springs'. Much easier to find. Smile
http://www.lowes.com/pd_192145-37672-543001_4294710978__?productId=3115801&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
Lake City, Colorado
