donjohnston
henry(at)pericynthion.org Guest
Posted: Mon Jul 21, 2014 1:26 pm Post subject: Transmitting with no antenna? |
It's not a good idea; transmitting into an open circuit can damage
that final power amplifier stage as the signal is reflected back into
it. But most radios built in the past 20-30 years will have built-in
foldback protection to detect this condition and dial the power back
to avoid damage.
Henry
On Mon, Jul 21, 2014 at 1:27 PM, donjohnston <don(at)velocity-xl.com> wrote:
donjohnston
Posted: Mon Jul 21, 2014 1:50 pm Post subject: Re: Transmitting with no antenna? |
| henry(at)pericynthion.org wrote: | It's not a good idea; transmitting into an open circuit can damage
to avoid damage.
Henry
On Mon, Jul 21, 2014 at 1:27 PM, donjohnston <don> wrote:
Thanks!
What should I do to prevent any potential problem? Would a 50 ohm terminating resistor be a good idea? I'm not going to be able to connect the antennas for a while and I'd like to not have to worry about any problems.
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Mon Jul 21, 2014 1:54 pm Post subject: Transmitting with no antenna? |
Is it an OWT (old wives tale): I don't know but where are those 'ouput watts' going, if you don't have an aerial connected
----x--O--x----
| Quote: | On 21 Jul 2014, at 09:27 pm, "donjohnston" <don(at)velocity-xl.com> wrote:
I'm working on an audio panel/radio problem and I was told that pressing the PTT (transmitting) without an antenna will fry the radio. [Embarassed]
Is this correct or is it an OWT?
http://forums.matronics.com/viewtopic.php?p=427077#427077
billp(at)wwpc.com Guest
Posted: Mon Jul 21, 2014 1:59 pm Post subject: Transmitting with no antenna? |
It depends on the radio design. The problem is that the radio is meant
to have an antenna connected to it that is designed to operate on the
frequency the transmitter is transmitting at. When that doesn't happen
all the power that the transmitter is producing is "reflected" back into
the transmitter. That can fry things. Most well designed modern
transmitters have protection circuits that reduce the transmitter power
or disable the transmitter when it detects that condition. It's still a
bad idea to transmit with no antenna (or the wrong antenna) connected.
This goes for Comm radios, Transponders, Radio Altimeters, TCAS boxes...
Posted: Mon Jul 21, 2014 2:22 pm Post subject: Transmitting with no antenna? |
Most 50 Ohm terminating resistors are rated for a half watt or less.
Most Comm radios put out 5 watts or more. The terminating resistor won't
last long. 1) Keep the radio turned off when you're working on things.
2) Disconnect the PTT wire from the radio connector if that's feasible.
Termination resistors are made to keep a constant impedance connection
on something like a spare antenna diplexer port, not dissipate the power
from a transmitter. You can get 50 dummy loads that are designed to be
transmitted into all day long. They're a lot more expensive than a
terminator and much bulkier. Even a dummy load will only operate at it's
rated power for a limited time. Make sure you look at all the specs for
what you buy. Most of the time you're going to be transmitting without
you knowing it because a wiring short or sitting on the mic (or
something like that). You're likely to be transmitting for a long time
or until the stuck mic circuit in the transmitter shuts it down.
On 7/21/14, 2:50 PM, donjohnston wrote:
> to avoid damage.
> Henry
> On Mon, Jul 21, 2014 at 1:27 PM, donjohnston wrote:
Thanks!
http://forums.matronics.com/viewtopic.php?p=427085#427085
john.maccallum(at)bigpond Guest
Posted: Mon Jul 21, 2014 2:23 pm Post subject: Transmitting with no antenna? |
As per some other post in reply yes it can lead to damage to the output
stage of the connected radio. The high SWR presented to the
Output side by no Antenna or the wrong antenna causes significant heating to
the output transistors and can cause their internal junctions to fail.
You can go to your local Ham Radio shop and purchase a small 50 Ohm dummy
load for a few dollars to protect the connected radios or indeed test the
Radios without an antenna. You will need a VHF, 50 Ohm Dummy Load Capable of
handling 25 watts (less if you keep the transmissions short say 4-5
seconds).
Cheers
John MacCallum
VH-DUU
RV10 41016
edpav8r(at)yahoo.com Guest
Posted: Mon Jul 21, 2014 5:10 pm Post subject: Transmitting with no antenna? |
Alternatively, you could build this dummy load: http://bit.ly/1wSMtI1
..using 20 of these (buy 25 for the price break): http://bit.ly/1lnVgfM
Note: Do *not* substitute wire-wound resistors!
Eric
| Quote: | On Jul 21, 2014, at 5:22 PM, John MacCallum <john.maccallum(at)bigpond.com> wrote:
You can go to your local Ham Radio shop and purchase a small 50 Ohm dummy load for a few dollars to protect the connected radios or indeed test the Radios without an antenna. You will need a VHF, 50 Ohm Dummy Load Capable of handling 25 watts (less if you keep the transmissions short say 4-5 seconds).
Cheers
John MacCallum
VH-DUU
RV10 41016
Posted: Mon Jul 21, 2014 5:46 pm Post subject: Transmitting with no antenna? |
radio. [Embarassed]
I wouldn't make a habit of it . . . there's no
good reason to do it. If you need to listen to
your transmitted signal without radiating it more
than a few dozen yards, build yourself a dummy
load to put on the transmitter's coax connector.
http://tinyurl.com/cchp3pf
This load is good for 2W continuous and will handle
10W transmitters for the few seconds necessary to make
a vocal test transmission to deduce audio quality.
If you need a bigger load, it too can be fabricated
from R-S parts.
But the caveat about keying a transmitter into
an open antenna jack is a carry-over from the state
of solid state radios of the 60-70's. It didn't
take the industry long to figure out ways to build
protections into their products . . . so keying
an unloaded transmitter no longer represents
a serious hazard.
Posted: Tue Jul 22, 2014 7:46 am Post subject: Transmitting with no antenna? |
At 08:43 PM 7/21/20, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
Is this correct or is it an OWT? |
After crafting my reply last night I was curious as to
modern approaches to crafting SWR ruggedness into a
VHF transmitter.
The last time I dug through the innards of a solid state
vhf transmitter, the output stage was crafted from NPN
silicon junction transistors . . . about 4 of them in
push-pull for 100W of output at 145MHz. The antenna
matching network was fitted with a directional coupler
(SWR meter) that sampled reverse-voltage as a product of
high SWR . . . that voltage was used to reduce drive
to the output stage for the purpose of protecting the
transistors should the transmitter be presented with
a high swr. Works good, lasts a long time.
Just for grins, I got a copy of the KX165 transceiver
service manual to bone up on contemporary design
philosophies. Got an interesting surprise.
Here is an excerpt from the transmitter schematic . . .
Yup . . . there it is . . . the expected directional
coupler. But when I read the accompanying text, I was
informed that the directional coupler output was
used to sample FORWARD power for the purpose of leveling
the transmitter's output power. No mention was made
for 'high SWR protection' . . .
In fact, a search of the entire service manual
for "standing" or "SWR" produced no hits. Say
what????
[img]cid:.0[/img]
Here are some excerpts from the manufacturer's data sheets
on the KX165 powuer output transistor.
[img]cid:.0[/img]
This is a MOSFET rated at 80W of output in VHF operation.
Further we read the following . . .
[img]cid:.1[/img]
Down in the tabulation of characteristics we also
find . . .
[img]cid:.2[/img]
I was pleased to find that my original assertion was
correct but for the wrong reasons. It seems the MOSFET is
immune to damage from the stresses that would have
shot its ancestors out of the saddle. Hence no wrap-around
protection was needed. The directional coupler was still
there but pressed into service other than output
stage protection.
Another interesting feature from the schematic excerpt:
Notice the "stub" depiction on the antenna output line.
A search of the manual doesn't speak to its existence
or purpose. Given that this is a deign from the hallowed
halls of the Nav/Comm gods, I suspect that 'stub' is an
shunt filter element tuned to reject transmitter harmonics
that fall on or close to GPS frequencies. Garmin used to
offer a 330-00067-00 Notch Filter intended to be 'scabbed
on' to the nav/comm antenna connector.
[img]cid:.3[/img]
163.36 KB |
13685 Time(s) |
96.28 KB |
13685 Time(s) |
37.64 KB |
13685 Time(s) |
8.05 KB |
13685 Time(s) |
donjohnston
Posted: Tue Jul 22, 2014 3:42 pm Post subject: Re: Transmitting with no antenna? |
radio. [Embarassed]
from R-S parts.
a serious hazard.
Bob . . . |
Using the logic of "if some is good, more must be better", I picked up some 10w, 100ohm resistors.
Checked with the manufacture (Val) and they said that I'm probably okay:
| Quote: | | In regards to circuit protection, the COM 2KR doesn't have any active protection against keying the unit without a proper load attached. As such, you run a small risk of damaging your radios keying them up without an antenna. However, the radios are resistant to damage from being keyed without an antenna and should be fine. |
33.78 KB |
13674 Time(s) |
Posted: Tue Jul 22, 2014 4:28 pm Post subject: Transmitting with no antenna? |
Don,
Just be sure the resistors you sourced are not wire-wound types. At a 10W rating, most are. These are inductive and will make a very poor dummy load.
Examples to avoid: http://bit.ly/1A3zd7U -or- http://bit.ly/1rImumj
Bob's 2W-10W dummy load appears to be built with Metal Film or Metal Oxide resistors.
Eric
| Quote: | On Jul 22, 2014, at 7:42 PM, "donjohnston" <don(at)velocity-xl.com> wrote:
donjohnston
Posted: Wed Jul 23, 2014 6:05 am Post subject: Re: Transmitting with no antenna? |
| edpav8r(at)yahoo.com wrote: | Don,
Eric
Yep... They're wire wound.
I can't get anything right lately.
Posted: Wed Jul 23, 2014 7:14 am Post subject: Transmitting with no antenna? |
Eric
This is a time-honored and relatively easy methodology
for crafting a low SWR dummy load. Built one of these
when I was in high-school . . . my can was salvaged
from some painting project around the house and I used
Havoline motor oil . . . but as you can see, the time
to fabricate this thing is not trivial. Be sure to store
this thing rihgt-side-up . . . if it lays over then atmospheric
breathing will push oil past connectors that are not
liquid tight. The commercial-off-the shelf alternative
may prove more attractive.
Posted: Wed Jul 23, 2014 8:38 am Post subject: Transmitting with no antenna? |
On Jul 23, 2014, at 10:13 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
| Quote: | This is a time-honored and relatively easy methodology for crafting a low SWR dummy load. [SNIP] The commercial-off-the shelf alternative may prove more attractive.
Indeed. I always seem to forget that you can buy virtually anything cheaply on eBay! For $19, the economics of building one yourself, in $ and time, make little sense.
Eric
donjohnston
Posted: Wed Jul 23, 2014 11:54 am Post subject: Re: Transmitting with no antenna? |
I was skeptical and disappointed when your conversation
with VAL suggested that 'your were probably going to be
okay' with the 10W resistors.
It would have been nice if the design I posted was
a little beefier . . . but getting resistors
with low inductance at VHF frequencies isn't a trivial
task. The venerable carbon composition resistor popular
to this legacy DIY task are not easy to find and not cheap
when you do find them. The 2W design proved to be the
best I could do with limited resources . . . although
suited to the task as long as you don't get into long-winded
test transmissions. As I recall, I produced that suggestion
as a test tool for proving that some appliance sensitivity
to transmitters was a function of energy radiated from
the antenna. Short transmissions would suffice. |
Uh... Val didn't say I would be fine with 10W resistors.
They said that the radios should be fine.
I'm going to redo with the 1W metal oxide resistors. I'm only tracking down an audio panel switching issue. As such, I'm only keying the mic long enough to see if I get a transmit indicator on the display. So about a half second whenever I hit the PTT.
Posted: Wed Jul 23, 2014 12:00 pm Post subject: Transmitting with no antenna? |
| Quote: | Indeed. I always seem to forget that you can buy virtually anything
But we won't talk about the things we do, buy,
read or just dream about . . . 'cause it's FUN!
It's probably cheaper than a gambling habit . . .
