still fighting
jflan(at)zianet.com
PostPosted: Fri Jun 23, 2006 11:25 am    Post subject: still fighting Reply with quote
Have had to hold right stick (initial flight about dislocated right shoulder and elbow) and a bit of rudder and right wing continues to want to rise. Flaps and ailerons are fairly close to level with underside of wing. Tried four-inch wide aluminum tab and slight relief, but this said to be '91 Mark III Classic certainly hasn't flown hands off since last person may have tried it.
Haven't been up with this tab, yet. Further ideas?
jsf
 Filesize:  82.52 KB
 Viewed:  274 Time(s)
jeepacro(at)cox.net
PostPosted: Fri Jun 23, 2006 11:44 am    Post subject: still fighting Reply with quote
Can you put shim's in the wing swivel attach joint to help change the trailing edge angle of attack? Can you put one the top (right hand side) to lower, and one on the bottom of the left to lift?
Rob.
jsf
rlaird
PostPosted: Fri Jun 23, 2006 12:01 pm    Post subject: still fighting Reply with quote
Do you know about the "English" u-joint that Kolb sells to help this
problem? I bought it (I had the same problem) and it cured it
completely. I no longer need bungee cords to act as trim (which would
be a temporary fix for you).
Contact Kolb and they'll send one out to you.
-- Robert
Rob.
> jsf
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
jflan(at)zianet.com
PostPosted: Fri Jun 23, 2006 1:28 pm    Post subject: still fighting Reply with quote
Many thanks. None of the three Kolb people IU have talked to at length have
said a word about this item. I can't imagine why.
If I can get this bird to fly hands off, I shall be pleasantly surprised.
Wouldn't mind flying ultralights for pleasure rather than just survival.
Again, gracios.
jsf in NM
PostPosted: Fri Jun 23, 2006 2:34 pm    Post subject: still fighting Reply with quote
surprised.
survival.
| Again, gracios.
| jsf in NM
jsf in NM:
Reckon most all of us will be surprised if you get your Kolb to fly
hands off, for more than a few seconds.
BTW what model Kolb do you have? and where are you located?
Richard Pike
PostPosted: Fri Jun 23, 2006 2:44 pm    Post subject: still fighting Reply with quote
Don't know what model Kolb you have, but our Firestar II flies hands off
real well.
But it has dihedral. Lots of dihedral. I think about 4.5 inches per wing.
You can fly it with just rudder pedals. Pictures here -
http://www.bcchapel.org/pages/0003/kolb.htm
And there is also a link on this page to an adjustable aileron trim tab.
I think I might put some dihedral in my MKIII, see how it does.
Richard Pike
MKIII N420P (420ldPoops)
have said a word about this item. I can't imagine why.
surprised. Wouldn't mind flying ultralights for pleasure rather than
just survival. Again, gracios.
jsf in NM
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
slyck(at)frontiernet.net
PostPosted: Fri Jun 23, 2006 4:55 pm    Post subject: still fighting Reply with quote
John, that is quite a tab. First I would level the cabin and
check/compare wing
incidences. Then check tailplane (horizonal stab) incidence
differential.
If only off a little I would go with the TNK offset universal.
-Anybody know what they get for them? $$$?
The air was nice today here in the northeast. I got in a neighborhood
tour
to check if anything is currently trying to fall off after last weeks
rough
return trip. Felt good.
-BB
jsf<tab right aileron_7690.jpg>
HShack(at)aol.com
PostPosted: Fri Jun 23, 2006 6:11 pm    Post subject: still fighting Reply with quote
In a message dated 6/23/2006 8:56:07 PM Eastern Standard Time, slyck(at)frontiernet.net writes:
I think I paid $75 plus frt. for one.
Howard Shackleford
FS II
SC
jflan(at)zianet.com
PostPosted: Fri Jun 23, 2006 6:21 pm    Post subject: still fighting Reply with quote
First, thanks. Appreciate the good feedback I've had. Here's what we did and
realized today had skipped putting protractor under horizontal stabilizer
(flying wires don't twang like my friends Kolb Ultarstar II...more base,
while his are treble, but left and right not far apart). I had been tweaking
for a week or more, trying different approaches, then went back to basics
as level as possible, since dropping left flap had produced 5 or more mph
less indicated at same rpms.
We set boom at 0 degrees with protractor and then checked angle under wings.
Both were 10.3 degrees or at least within a degree of each other.
Then leveled stick and measured slope under wings
Left aileron 13 degrees.
Left flap 14.5 degrees
Right aileron 13.5 degrees
Right flap 12 degrees
The pipes controlling flaps and ailerons were last measurements:
Left 22.5 degrees
Right 21 degrees.
The four inch length tab with about two extended aft and bent about 15
degrees helped, but stick was still needed to keep it near level in flight.
Still feels like yawing. Replaced the aileron tab with 12" length and have
not flown. Not a good morning. Today, hopefully monsoons will start here in
the drought-stricken Southwest.
jsf
ulflyer(at)verizon.net
PostPosted: Fri Jun 23, 2006 9:24 pm    Post subject: still fighting Reply with quote
Many different things can contribute to the flight characteristics
your experiencing. Sounds like a rigging problem. In order to
determine the likely cause it will be necessary to properly level the
aircraft in the proper attitude to take correct meaningful
measurements. This becomes a process of elimination. Refer to the
builders manual on how measurements should be taken and how the
aircraft needs to be leveled during the process.
- Level the Aircraft - see the builders manual for reference points
and detailed procedure.
- Wing incidence at the wing root - where it should be and equal on both sides.
- Wing twist on each wing - equal both sides - inboard station near
wing root compared to last full rib station.
- Wing dihedral at the wing tip - equal on both sides.
- Flaps - do they have equal deflection (reflect) relative to the
lower surface of the wing,
- Ailerons/Flaperons - are they both centered when stick is in the
center, neutral position.
- is the trailing edge position correct relative to the
training edge of the flaps.
- Tail vertical stab alignment, centered, or off set in the correct direction.
- Horizontal stabilizer - incidence and dihedral set within the
proper range and equal both sides.
- Engine thrust line - is the engine set in the proper position,
- up/down tilt, rotated the proper amount and in the correct
direction from the plans
specified reference point.
jerb
jsf
