Pocono John
Joined: 22 Aug 2011 Posts: 118 Location: Stroudsburg, PA
Posted: Sun Jul 13, 2014 6:20 pm Post subject: Air Impact wrench |
Getting ready to disassemble a Corvair. I don't have any air tools/compressor. It would cost close to $300 for a impact wrench, compressor and hose. Is it worth it? Thanks!
| - The Matronics CorvairEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?CorvairEngines-List |
_________________ John Cronin |
dlj04(at)josephson.com Guest
Posted: Mon Jul 14, 2014 9:05 am Post subject: Air Impact Wrench |
it? Thanks!
You don't need any air tools to disassemble a Corvair engine, just a
regular 3/8" socket set. And a compressor you can buy for under $300
will not produce enough air for an impact wrench anyway.
sblack
Posted: Mon Jul 14, 2014 12:10 pm Post subject: Air Impact Wrench |
Penetrating oil, some heat, elbow grease and a mastery of colorful language are all you need.
Scott
Quote: | On Jul 14, 2014, at 1:05 PM, D L Josephson <dlj04(at)josephson.com> wrote:
> it? Thanks!
You don't need any air tools to disassemble a Corvair engine, just a regular 3/8" socket set. And a compressor you can buy for under $300 will not produce enough air for an impact wrench anyway.
_________________ Scott Black
Montreal
Jodel F11 O-200 |
dave(at)algoa.net Guest
Posted: Mon Jul 14, 2014 3:02 pm Post subject: Air Impact Wrench |
"Penetrating oil, some heat, elbow grease and a mastery of colorful language are all you need."
If you use Kroil from Kano Labs as the penetrating oil, you can replace the heat with beer (while you wait for the Kroil to work its magic). The rest of the list stays the same.
Dave
On Mon, Jul 14, 2014 at 3:09 PM, Scott black <scott-black(at)sympatico.ca (scott-black(at)sympatico.ca)> wrote:
[quote]--> CorvairEngines-List message posted by: Scott black <scott-black(at)sympatico.ca (scott-black(at)sympatico.ca)>
Scott
> On Jul 14, 2014, at 1:05 PM, D L Josephson <dlj04(at)josephson.com (dlj04(at)josephson.com)> wrote:
> --> CorvairEngines-List message posted by: D L Josephson <dlj04(at)josephson.com (dlj04(at)josephson.com)>
>> it? Thanks!
um -
gines-List" target="_blank">http://www.matronics.com/Navigator?CorvairEngines-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Pocono John
Posted: Tue Jul 15, 2014 6:42 am Post subject: Re: Air Impact wrench |
Thanks. On the subject oil, The Machinist's Workshop published a report regarding various penetrating oils.
Torque to remove a rusted nut:
No oil….516 lbs
WD-40…238 lbs
PB Blaster…214 lbs
Liquid Wrench…127 lbs
Kano Oil…106 lbs
50/50 mix Automatic Transmission Fluid and Acetone…53 lbs
John Pitkin
Posted: Sun Sep 13, 2015 9:08 pm Post subject: Re: Air Impact wrench |
Pocono John wrote: | Thanks. On the subject oil... To remove a rusted
nut...
50/50 mix Automatic Transmission Fluid and Acetone…53 lbs |
I used the magic juice of ATF and acetone to disassemble my
Corvair engine. when I first heard of the formula I thought it was some
folklore. When I tried it on some rusty tractor implements it made me a believer.
Be sure to use it on the Corvair head nuts to avoid pulling the studs
out of the case.
raymondj(at)frontiernet.n Guest
Posted: Mon Sep 14, 2015 10:50 pm Post subject: Air Impact wrench |
I'll put that formula in my bag of tricks.
One recipe that I use is a mix of wintergreen oil and ATF. If I remember
correctly the mix is about 5-10 % wintergreen in the ATF. You have to
give it overnight, at least, and a couple of days is better, with
applications every 12 hrs or so. It's surprised me more than once when
I used it as a last ditch effort.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 09/14/2015 12:08 AM, John Pitkin wrote:
Quote: |
> nut...
out of the case.
http://forums.matronics.com/viewtopic.php?p=447049#447049
DaveC
![](images/avatars/6699439684783c719eac7c.jpg)
Posted: Tue Sep 15, 2015 3:54 pm Post subject: Air Impact wrench |
Plus it makes your shop smell amazing!
Dave On Sep 15, 2015 1:49 AM, "rayj" <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)> wrote:[quote]--> CorvairEngines-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>
One recipe that I use is a mix of wintergreen oil and ATF. If I remember correctly the mix is about 5-10 % wintergreen in the ATF. You have to give it overnight, at least, and a couple of days is better, with applications every 12 hrs or so. It's surprised me more than once when I used it as a last ditch effort.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968)
Quote: | --> CorvairEngines-List message posted by: "John Pitkin" <john(at)cedarcreekrun.com (john(at)cedarcreekrun.com)>
Pocono John wrote:
Quote: | Thanks. On the subject oil... To remove a rusted
nut...
out of the case.
um -
airEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?CorvairEngines-List
_________________ Dave
Alvin, Texas
CH-750 wanna-be building Wynne Corvair conversion |
