sundry questions
PostPosted: Wed Jul 09, 2014 1:18 pm    Post subject: sundry questions Reply with quote
At 10:07 AM 7/9/2014, you wrote:
BTW, I've read your book. Very nice for a first time builder.
Thank you.
Hope you don't mind a few questions.
Not at all . . . but I would like for you to join the AeroElectric-List
for any future conversation. It's always a good thing when we share
these conversations with the community.
I plan on going with fuses for the majority of the circuit
protection as you recommended. When I went to your web site to find
fuse blocks and bus bars, I had a hard time navigating through the
site. Do you have an online product catalog, or is that something I
have to buy? When I clicked on the link the first time, an order
form came up. I tried again at a later time and finally made it to
the fuse block section, but the pdf descriptions that came up was
hardly readable.
I don't sell any hardware at present. I have in the
past but right now, B&C at http://bandc.biz has the
vast majority of my legacy products and merchandise.
I'm talking with them about upgrades to products and
getting some new items. Time is my tight commodity.
I'm contracting for Beech/Cessna/Hawker and there
aren't very many gray-beards around to remember how
and why some things were done . . . waayyyyy back when.
I'm a vfr only pilot and am considering surface mounting an I-pad
mini on the dash as a backup. It would run Foreflight and
communicate with a Stratus Two. I've heard the pads tend to
overheat and was thinking about installing a cooling fan behind it
in the panel. Do you have any thoughts on this? What type fan
should I use to avoid RFI, etc? How many cfm? Do you have a
simpler idea, or am I needlessly worrying about the overheating problem?
Folks on the List can better sources of information
on this than I. I'm surprised about 'heat issues' . . .
these things draw about 3-5 watts in operation, the
vast majority of which gets turned into heat. Unless
there are items with localized heat-dissipation issues
(doubtful for a hand-held device), I would not expect
there to be any problems for operational heating.
However, these things are not designed to RESIDE on a
panel of an airplane parked out in the sun. I sure
wouldn't leave one in a parked airplane.
The other thing I was looking for was 12v usb port I could hardwire
near my panel (not a cigarette lighter adapter) so the pad would be
charged while in flight. Blue Sea makes usb ports for marine
application that looks good, but didn't know if you had any.
That's a popular topic on the List. A number of
builders have tried various commercial off the self
12v/USB power adapters with varying degrees of
success. Depending on how handy you are with
a soldering iron, you could craft an airplane-
friendly, 14V to 5VUSB adapter starting with
a reasonably robust assembly as a core . . .
something like these . . .
http://tinyurl.com/ovowqbu
http://tinyurl.com/px42t7f
. . . mounted in a metal enclosure and fitted with
sure-to-work filters and over-load protection.
Alternatively, something like this . . .
http://tinyurl.com/pbvmbb3
. . . might be just fine in terms of performance
and noise . . . you'd just have to try it.
I also read your article on using shielded cable for the LIghtspeed
electronic ignition instead of the coax. The use of epoxy to seal
the wiring seemed like a pain and was wondering if using a tighter
fitting, larger shielded wire with shrink wrapping would be ok. Are
the reasons for not using larger cable expense, flexibility, and weight?
Klaus had a cow when I wrote that article . . . seems
that coax cable was necessary if the system were going
to generate 2" long sparks between coil towers. Going
to shielded wire dropped the output to 1.5" sparks.
Still about 100x more than needed to make the engine run
but I'll have to concede a 'drop in performance'.
The original problem with coax was his recommendation
for using RG-58 . . . with insulation that drips off
the wire when you try to solder it. He has since revised
his recommendation to RG-400 coax . . . modern, hi-temp
insulation.
tim2542(at)sbcglobal.net
PostPosted: Wed Jul 09, 2014 2:42 pm    Post subject: sundry questions Reply with quote
I think you'll be unhappy with a panel mounted Ipad, they will heat soak from the sun in a hurry and simply turn off. I use one however and love it, but I stow it out of the sun (and thieves) view when parked and just set it on my legs in flight.
FWIW
On Jul 9, 2014, at 2:16 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
Thank you.
> I plan on going with fuses for the majority of the circuit protection as you recommended. When I went to your web site to find fuse blocks and bus bars, I had a hard time navigating through the site. Do you have an online product catalog, or is that something I have to buy? When I clicked on the link the first time, an order form came up. I tried again at a later time and finally made it to the fuse block section, but the pdf descriptions that came up was hardly readable.
> I'm a vfr only pilot and am considering surface mounting an I-pad mini on the dash as a backup. It would run Foreflight and communicate with a Stratus Two. I've heard the pads tend to overheat and was thinking about installing a cooling fan behind it in the panel. Do you have any thoughts on this? What type fan should I use to avoid RFI, etc? How many cfm? Do you have a simpler idea, or am I needlessly worrying about the overheating problem?
> The other thing I was looking for was 12v usb port I could hardwire near my panel (not a cigarette lighter adapter) so the pad would be charged while in flight. Blue Sea makes usb ports for marine application that looks good, but didn't know if you had any.
> I also read your article on using shielded cable for the LIghtspeed electronic ignition instead of the coax. The use of epoxy to seal the wiring seemed like a pain and was wondering if using a tighter fitting, larger shielded wire with shrink wrapping would be ok. Are the reasons for not using larger cable expense, flexibility, and weight?
insulation.
JOHN TIPTON
PostPosted: Wed Jul 09, 2014 3:39 pm    Post subject: sundry questions Reply with quote
This is my 4year old grandson, flying P2, with my IPad suction mounted on my C172
----x--O--x----
FWIW
> Thank you.
> insulation.
> Bob . . .
 Filesize:  264 KB
 Viewed:  6990 Time(s)
BobsV35B(at)aol.com
PostPosted: Wed Jul 09, 2014 4:00 pm    Post subject: sundry questions Reply with quote
Test!
Old Bob
In a message dated 7/9/2014 4:19:18 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Thank you.
hardly readable.
insulation.
Bob . . .  = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
shaunwilkinson(at)cloud9a
PostPosted: Thu Jul 10, 2014 12:18 am    Post subject: sundry questions Reply with quote
Excellent Photo
On 10 Jul 2014, at 00:38, John Tipton <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
[quote]<image.jpeg>
----x--O--x----
On 9 Jul 2014, at 11:40 pm, Tim Andres <tim2542(at)sbcglobal.net (tim2542(at)sbcglobal.net)> wrote:
--> AeroElectric-List message posted by: Tim Andres <tim2542(at)sbcglobal.net (tim2542(at)sbcglobal.net)>
FWIW
On Jul 9, 2014, at 2:16 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Thank you.
insulation.
<pre><b><font size=2 color="#000000" face="courier - The AeroElectric-List Email Forum href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List">ht--> <a href="http://forums.matronics.com">http://forums.matronics.com - List Contribution Web Site --> <a href="http://www.matronics.com/contribution">http://www.matron=======================
</b></font></pre></body></html>
Mauledriver(at)nc.rr.com
PostPosted: Thu Jul 10, 2014 1:34 am    Post subject: sundry questions Reply with quote
As others have and will point out, you won't really want to 'hard mount' your iPad but rather install it so it can removed and replaced as you enter and exit the plane. Left in a closed cockpit in the sun they will overheat. Practically speaking, I think you'll find that you'll want to keep the iPad with you for Foreflight flight planning, weather checking and general usage.
Many possible solutions. I used a RAM mount which let's you slip the iPad in and out with just a bit of finger pressure. Having RAM mount on a center console lets me have the iPad right over my lap - ideal for me.
Kitlog - O2 Console for RV10
You might try experimental avionics supplier/builder Steinair. They have a USB unit that mounts to the panel quite nicely and it works.
deej(at)deej.net
PostPosted: Thu Jul 10, 2014 6:59 am    Post subject: sundry questions Reply with quote
FWIW
FWIW, I am very happy with my panel mounted iPad2, and have never had
any heat issues with it. I use a RAM mount so that I can easily remove
it and take it with me when not using the airplane.
Here are some old pics before my panel upgrade:
http://deej.net/glastar/pics/ipad/
The new panel is still under construction, but here is a recent picture:
http://deej.net/glastar/pics/panel/install/photob-3181.jpg
The iPad will be mounted vertically (rather than horizontally as it was
in the previous pictures) and will be running WingX for moving map and
IFR charts.
You could easily mount a simple paper shade behind/above the iPad if you
needed to keep the sun off the backside.
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
PostPosted: Thu Jul 10, 2014 11:22 am    Post subject: sundry questions Reply with quote
I agree a ram mount would be fine, but mounted on the panel so you can't move it to adjust for glare or direct sun was what I thought he had in mind. Also, if you leave one in the sun with or even without the canopy closed, both of mine will overheat and shut down. iPhone also for that matter.
Your mileage may vary!
> FWIW
> Tim
IFR charts.
-Dj
bbradburry(at)verizon.net
PostPosted: Thu Jul 10, 2014 3:34 pm    Post subject: sundry questions Reply with quote
DJ,
You need 10 lbs of ballast in the baggage to fly solo????! Where is your
battery mounted?
deej(at)deej.net
PostPosted: Thu Jul 10, 2014 4:19 pm    Post subject: sundry questions Reply with quote
battery mounted?
Hi Bill,
No, I do not. My guess is the original builder didn't weigh the
plane properly, because when I used a set of calibrated scales to do it,
my results were somewhat different. No ballast needed other than my
butt in the front seat. Smile
Those are old pics taken shortly after I bought the plane a few
years ago, and that label hasn't been in the plane for a long time. Nice
catch though! Smile
-Dj
Larry Ford
PostPosted: Sun Jul 13, 2014 9:18 pm    Post subject: sundry questions Reply with quote
My experience with the Ipad is similar to Tim Andres’. I set it in my lap (out of its case) and unless I have
a fresh air vent directly blowing on the device it will shut down with an over temp announcement within 30 minutes of
operation. My IT friend believes the Blue Tooth communication with the Stratus ADS-B receiver creates a larger drain
than the Ipad would normally produce. I fly with another older handheld moving map as backup. The Foreflght + Stratus has
tremendous capability when it’s working but I don’t trust it as a sole nav source. Reliability needs improvement.
Larry Ford
Glasair I RG N149LF
