Access to tire vale stems
kearney
PostPosted: Mon Jul 07, 2014 6:40 pm    Post subject: Access to tire vale stems Reply with quote
Hi
I saw a couple of pix from of -10s in SA that appear to have nicely sized access ports on the wheel pants. Does anyone know about these. I would be interested in being able to access tire valve stems simply and easily.
Cheers
Les
flying-nut(at)cfl.rr.com
PostPosted: Mon Jul 07, 2014 6:53 pm    Post subject: Access to tire vale stems Reply with quote
Do yourself a favor and convert you wheels to take 90 degree valve
stems. Use a valve stem extender sold in truck tire stores through a
small hole in the wheel pant to air up the tire. To make it easy to
line up the stem/hole paint a white stripe vertically on the inside of
the tire ..... you can see the stripe when you're handling the tow bar.
Linn
On 7/7/2014 10:40 PM, kearney wrote:
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=426264#426264
Checked by AVG - www.avg.com
jesse(at)saintaviation.co
PostPosted: Mon Jul 07, 2014 6:59 pm    Post subject: Access to tire vale stems Reply with quote
You can drill a 2" hole centered 2-2.5" aft and 1/2" above the axle screw. Cirrus sells a 2" plug that will fit the hole. You have to leave the valve cover off, but you can easily add air.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Jul 7, 2014, at 10:40 PM, "kearney" <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
rleffler
PostPosted: Mon Jul 07, 2014 7:09 pm    Post subject: Access to tire vale stems Reply with quote
I drilled 3/4" holes then used a metal cover like Cleaveland sells. You can buy the same thing at the local hardware store for about a quarter per wheel. I also painted a mark on the tire when the valve stem is aligned with the hole. The system works well, except its a PITA if you are by yourself. It's impossible to see the marks on the tires while holding the tow bar.
Hi
Cheers
Les
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Bob Turner
PostPosted: Mon Jul 07, 2014 7:39 pm    Post subject: Re: Access to tire vale stems Reply with quote
Yes, it's a bit of a pain to take off the pants. But, unless your tubes leak badly, you really ought to be looking at brakes, wheels, etc., about as often as your tubes need air.
Bob Turner
RV-10 QB
Tim Olson
PostPosted: Mon Jul 07, 2014 10:09 pm    Post subject: Access to tire vale stems Reply with quote
That's been my standard reply to this for years too. I personally
don't need the added temptation to SKIP taking the fairings off,
because I know I'd succumb. I generally only have to take them
off in spring and fall,with the leak guard tubes, and I think brake
pads deserve inspection more often than that.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=426269#426269
charliewaffles
PostPosted: Tue Jul 08, 2014 8:20 am    Post subject: Re: Access to tire vale stems Reply with quote
I added in a small door to each wheel pant. Just took a hole saw and then built up a fiberglass flange and some nutplates. Each enough to do and free.
http://myrv10factory.files.wordpress.com/2014/04/20140401_222133489_ios.jpg
http://myrv10factory.files.wordpress.com/2014/02/20140205_231629512_ios.jpg
kearney
PostPosted: Tue Jul 08, 2014 7:42 pm    Post subject: Re: Access to tire vale stems Reply with quote
Linn et al
Thanks for the suggestions. I have the caps for the pants already. I didn't know that 90 degree extensions were available so I will definitely go that route.
I do take Tim's point about not skipping the brake inspections though.
Cheers
Les
Lenny Iszak
PostPosted: Wed Jul 09, 2014 4:31 am    Post subject: Re: Access to tire vale stems Reply with quote
Les,
The extensions are straight, valve stems are 90 degrees, so they point straight out instead of towards the axle nut.
Lenny
johngoodman
PostPosted: Thu Jul 10, 2014 3:50 am    Post subject: Re: Access to tire vale stems Reply with quote
Try going pantless, like me....
 Filesize:  32.57 KB
 Viewed:  9123 Time(s)
