Charles Heathco
flying-nut(at)cfl.rr.com Guest
Posted: Mon Jul 07, 2014 7:35 am Post subject: running tubing for lift reserve indicator. |
You might try to fix a step drill to the end of the PVC and rotate the PVC slowly so the step drill catches in the hole and lifts the PVC up. Make sure that the step drill is firmly attached .... getting that sucker out of the wing might be a real exercise.
You might also try to fix a tapered piece of wood dowel in the end of the PVC ..... anything to lift the PVC up enough to slide through.
Linn
On 7/7/2014 10:54 AM, cheathco(at)cox.net (cheathco(at)cox.net) wrote:
[quote] I have had this for a while, had the probe and gauge installed for a while. I am trying to run the tubbing while down for annual. I had planned to use a 3/4 in pvc pipe to put the two tubes thru, cant get it into the wing. tubes to flexible to thread thru the holes. Any Ideas? This is an RV6A.
charlie Heathco
This email is free from viruses and malware because avast! Antivirus protection is active.
Checked by AVG - www.avg.com
07/07/14 [b]
