RV10 performance
dlm34077
PostPosted: Tue Jun 24, 2014 4:23 pm    Post subject: RV10 performance Reply with quote
Does anyone have TO performance data? I have been using the only data point I have; I have an experimental point of 2800 gross, 80F and 5200 field elevation the tower confirmed a ground roll of 2500 feet. This was not a wind the engine prior to brake release type of data point. My rule of thumb has been any density altitude less than 10000 and runway length in excess of 5000 is Ok for a gross departure. Of course there are other factors to consider like nearby terrain and weather but these are all subjective.. Has anyone created or seen the Van's data on takeoff and landing performance data? My C177RG had an empty weight of about 1800 and a gross of 2800 on 200HP; Given the 260 HP of the RV10 I would expect at least a 30% improvement in density altitude performance. Has anybody other DA data points?
pilotdds(at)aol.com
PostPosted: Tue Jun 24, 2014 4:56 pm    Post subject: RV10 performance Reply with quote
You wont be disappointed-but I would be cautious of a gross weight departure at 10000 density altitude in a cardinal but that's just me.TVL is a common airport for me and the rv-10 is one of the best,no,the best non turbo performers I have flown out of there.Havent had to circle the lake yet.Every rv-10 is a little different things like ei and higher compressions can make an even bigger difference at high da.
dave.saylor.aircrafters(a
PostPosted: Tue Jun 24, 2014 5:14 pm    Post subject: RV10 performance Reply with quote
I've done a max performance T/O near gross weight at a DA that was just over 10,000.
Years ago we departed KEMM (ele. 7300') returning to California from Oshkosh.
Not much wind, warm afternoon.  We used RWY 34, which is 8000' long.
Weight was gross less 15 gallons, call it 2600.  We ran up and leaned for max power holding the brakes, and used half flaps.
We were well off the ground and climbing abeam the terminal, which is about 3500' of runway.  I decided before T/O to abort if not airborne by that point since it was easy to identify.
That departure has been my rule of thumb ever since.
For example, we departed KCDC last earlier this month.  DA was over 9000, right at gross weight, and T/O was a complete non-event.  We were at least 1000' off the ground by the end of the 8600' runway.
--Dave
On Tue, Jun 24, 2014 at 5:22 PM, DLM <dlm34077(at)cox.net (dlm34077(at)cox.net)> wrote:
[quote] Does anyone have TO performance data? I have been using the only data point I have; I have an experimental point of 2800 gross, 80F and 5200 field elevation the tower confirmed a ground roll of 2500 feet. This was not a wind the engine prior to brake release type of data point. My rule of thumb has been any density altitude less than 10000 and runway length in excess of 5000 is Ok for a gross departure. Of course there are other factors to consider like nearby terrain and weather but these are all subjective.. Has anyone created or seen the Van's data on takeoff and landing performance data? My C177RG had an empty weight of about 1800 and a gross of 2800 on 200HP; Given the 260 HP of the RV10 I would expect at least a 30% improvement in density altitude performance. Has anybody other DA data points?
tp://forums.matronics.com
Bob Turner
PostPosted: Tue Jun 24, 2014 5:47 pm    Post subject: Re: RV10 performance Reply with quote
If you're using 2800 lbs for gross you will have a tough time finding comparisons, since most people are using 2700. Remember climb rate is very sensitive to weight.
Bob Turner
RV-10 QB
jesse(at)saintaviation.co
PostPosted: Tue Jun 24, 2014 7:52 pm    Post subject: RV10 performance Reply with quote
We took off from UIO (SEQU) at probably 2,800 lbs, rolling uphill, and used about 3,000 ft or less. I think one notch of flaps. The -10 performs great there.
A -10 in Mexico is operating out of a 5,000 MSL airport 600M long and has to stay about 2,500-2,600 max.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
On Jun 24, 2014, at 9:13 PM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)> wrote:
[quote]I've done a max performance T/O near gross weight at a DA that was just over 10,000.
--Dave
List"">http://www.matronics.com/Navigator?RV10-List
Tim Olson
PostPosted: Tue Jun 24, 2014 8:11 pm    Post subject: RV10 performance Reply with quote
The thing I keep thinking of when I think of our RV-10's is how amazingly easy we have it. We basically can operate safely at most any temperature even at high altitude, and we can carry nearly as much luggage as we can physically fit into the plane. These planes are just amazing. The only real problem is, once you get used to these amazing capabilities, I'd bet that we become far worse off as pilots if we moved back into the spam cans that we came from. I've become so attached to my airplane that I don't know that I could ever be happy owing a Cessna 172 or piper warrior again.
Spoiled rotten, we are.
Thanks VANS for the great kit!
On Jun 24, 2014, at 10:51 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]We took off from UIO (SEQU) at probably 2,800 lbs, rolling uphill, and used about 3,000 ft or less. I think one notch of flaps. The -10 performs great there.
Jesse Saint
352-427-0285
--Dave
arplnplt(at)gmail.com
PostPosted: Tue Jun 24, 2014 8:20 pm    Post subject: RV10 performance Reply with quote
I am curious what the highest altitude anyone has taken their -10 up to?I had mine up to 17,000 this weekend twice to get over some cloud build ups coming back from OR to WI. I was no where near gross but it made it up there with ease.
Dave Leikam
On Jun 24, 2014, at 11:10 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]The thing I keep thinking of when I think of our RV-10's is how amazingly easy we have it. We basically can operate safely at most any temperature even at high altitude, and we can carry nearly as much luggage as we can physically fit into the plane. These planes are just amazing. The only real problem is, once you get used to these amazing capabilities, I'd bet that we become far worse off as pilots if we moved back into the spam cans that we came from. I've become so attached to my airplane that I don't know that I could ever be happy owing a Cessna 172 or piper warrior again.
Jesse Saint
352-427-0285
--Dave
Mike Whisky
PostPosted: Wed Jun 25, 2014 2:32 am    Post subject: Re: RV10 performance Reply with quote
I attached my T/O table based on my T/O performance test. Please note that max RPM is reduced to 2500 due to noise regulation here in CH. Aircraft was at MTOW 2700 lbs / 1225 kg. take-off configuration flaps 1 = 0 degrees.
 Filesize:  195.43 KB
 Viewed:  13862 Time(s)
RV-10 builder (flying)
#511
PostPosted: Wed Jun 25, 2014 3:09 am    Post subject: RV10 performance Reply with quote
We have hit 22,000 close to gross, but it sure didn't like it up there. Over 18,000 the climb us terrible and the IAS is approaching stall.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Jun 25, 2014, at 12:19 AM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
[quote]I am curious what the highest altitude anyone has taken their -10 up to?I had mine up to 17,000 this weekend twice to get over some cloud build ups coming back from OR to WI. I was no where near gross but it made it up there with ease.
Dave Leikam
Jesse Saint
352-427-0285
--Dave
carl.froehlich(at)verizon
PostPosted: Wed Jun 25, 2014 5:00 am    Post subject: RV10 performance Reply with quote
17.5K in mine. Photo taken just after leveling off. This was during the 40 hour test phase – so solo (light).
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Wednesday, June 25, 2014 7:09 AM
Subject: Re: RV10 performance
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Dave Leikam
Jesse Saint
352-427-0285
--Dave
get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3DList"">http://www.matronics.com/Navigator?RV10-List
6
5get="_blank">http://www.matronics.com/Navigator?RV10-List
6
7
8
9
5
6
7
8
9
5
6
7
8
9
 Filesize:  93.11 KB
 Viewed:  13858 Time(s)
rene(at)felker.com
PostPosted: Wed Jun 25, 2014 5:38 am    Post subject: RV10 performance Reply with quote
20,100 with rate of climb of 100’ a minute.  Gross weight of 2800 at takeoff, CG on the aft edge and a little beyond.  Done during testing to determine service ceiling
IFR flight between Ogden Utah and Las Vegas with just me and my wife…plus bags… 19,000.  My wife does not like to fly in the clouds……O2 mask is a pain…..
Rene' Felker
N423CF
801-721-6080
Sent: Wednesday, June 25, 2014 5:09 AM
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Dave Leikam
Jesse Saint
352-427-0285
--Dave
6
6
7
8
9
5
6
7
8
9
5
6
7
8
9
Tim Olson
PostPosted: Wed Jun 25, 2014 6:41 am    Post subject: RV10 performance Reply with quote
16,500 with the family fully loaded....but it didn't climb very well.
I'm sure we could have made it higher, but I don't find much point
in going over 14K very much. It starts to become work again.
We don't carry O2 on all flights. I kind of missed it on the one
we just got back from though (write-up coming within 24 hours).
The problem (in my mind at least) with using 16-17k+ to stay above
the weather is that you don't have any performance margin left.
If you're plenty happy to be stuck back into the CB's, then fine,
but if you really want to stay "on top", you have already pushed
into the area where performance of the plane may not give you
much room. To each their own, but I just find it to be more
work as you pass 14K.
rene(at)felker.com
PostPosted: Wed Jun 25, 2014 8:08 am    Post subject: RV10 performance Reply with quote
For you flat landers that may be high enough, but for us guys with granite
at that altitude higher is needed. Smile
Rene' Felker
N423CF
801-721-6080
jchang10
PostPosted: Wed Jun 25, 2014 8:11 am    Post subject: RV10 performance Reply with quote
+1 from me. The main challenge for me at high altitude airports like TVL is to remember to let the speed build up sufficiently and not expect it to literally jump off the ground like usual. My home airport is at sea level, so it is too easy to get used the power. Now at home when i am solo, i typically TO with partial power 1 or 2" less MP and save the WOT for higher altitudes.
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
On 6/24/2014 9:10 PM, Tim Olson wrote:
[quote] The thing I keep thinking of when I think of our RV-10's is how amazingly easy we have it.  We basically can operate safely at most any temperature even at high altitude, and we can carry nearly as much luggage as we can physically fit into the plane.  These planes are just amazing.  The only real problem is, once you get used to these amazing capabilities, I'd bet that we become far worse off as pilots if we moved back into the spam cans that we came from.  I've become so attached to my airplane that I don't know that I could ever be happy owing a Cessna 172 or piper warrior again.
#40533 RV-10
Tim Olson
PostPosted: Wed Jun 25, 2014 8:30 am    Post subject: RV10 performance Reply with quote
HAHA! Yeah, you got me pegged. Wink
Actually, 15K I think will get you over any granite in the lower 48,
right? (But definitely not with proper IFR clearances).
I wouldn't mind some day, just once, taking a cross country flight
where I only have the wife and I, and minimal baggage. I'm sure my
opinions are set because of my common mode of flight....loaded to
about gross, 4 seats filled. Man what that plane could do if it
were just me in the front, and the wife in the baggage area...for
better cruise C.G. performance, of course. Smile
Rene' Felker
N423CF
801-721-6080
bwestfall
PostPosted: Wed Jun 25, 2014 8:48 am    Post subject: RV10 performance Reply with quote
Or better yet with your wife in the front and you in the baggage area!!! Wink
Tim Olson
PostPosted: Wed Jun 25, 2014 9:44 am    Post subject: RV10 performance Reply with quote
Ha! Yeah, with me back there the cruise would be even faster!
[quote] On Jun 25, 2014, at 11:48 AM, "Ben Westfall" <rv10(at)sinkrate.com> wrote:
Bob Turner
PostPosted: Wed Jun 25, 2014 9:58 am    Post subject: Re: RV10 performance Reply with quote
Guys, we need OAT data too. It's density altitude that matters here.
I've been no higher (that I recall) than 16,500' density altitude but that was with just 2 adults and some luggage, and it flew fine. Weight makes a big difference.
As to the original post: you cannot compare a 177 and -10, even of similar weight, and extrapolate climb rates, without knowing more information, like lift and drag data. But if you could magically put 260 HP into the cardinal and keep the weight the same, you'd see a huge increase in climb rate - a lot more than 30%.
Bob Turner
RV-10 QB
Rocketman1988
PostPosted: Wed Jun 25, 2014 3:19 pm    Post subject: Re: RV10 performance Reply with quote
Y'all be careful out there...
Mike Whisky
PostPosted: Thu Jun 26, 2014 7:50 am    Post subject: Re: RV10 performance Reply with quote
Here you go! During my climb performance test. I had to stop at 15k due to airspace clearance. OAT -9C at MTOW 2700lbs still climbing with 350ft/min at Vy. CHT gets quite high though.
 Filesize:  151.45 KB
 Viewed:  13807 Time(s)
#511
