LED Ghosting
Goto page Previous  1, 2, 3, 4, 5  Next
donjohnston
PostPosted: Sat Jun 21, 2014 1:49 pm    Post subject: Re: LED Ghosting Reply with quote
Okay... The MOSFET approach isn't going to work. Sad
The LEDs and resistors are on a circuit board. This type of change isn't going to work given the constraints of the board.
So I guess I'll have to fall back to my plan B and add resistors to dim all the other LEDs so they're about the same as that pesky engine analyzer.
Maybe Bob will have an idea.
PostPosted: Sat Jun 21, 2014 1:55 pm    Post subject: Re: LED Ghosting Reply with quote
Unfortunately, I am way outside my element. Not quite sure how to wire this sucker now.
Not to worry, use Eric's (edpav8r) last post as a guide and draw a new circuit. Post it and others will offer suggestions.
Diodes added to the bright LED circuits is starting to look easier, if it works. I think that it is worth a try. Two of 1N4148 in series will drop about 1.5 volts when conducting 20 ma and will drop 1.6 volts at 30 ma, according to the data sheet. That will equal the voltage drop across the Engine Analyzer Alarm and hopefully make all LEDs the same brightness. I have some extra diodes that I could mail to you if you wanted to try them.
Of course you already have the P-Channel MOSFET. Use this circuit
http://electronics.stackexchange.com/questions/3599/basic-p-type-mosfet-question and ignore the N-Channel circuit. Substitute your dimmer for the power supply, use your 390 ohm for the load resistor. Put your LED in series with the 390 ohm load resistor. Connect the Engine Analyzer Alarm output and the pull-up resistor to the gate.
Joe Gores
PostPosted: Sat Jun 21, 2014 2:02 pm    Post subject: Re: LED Ghosting Reply with quote
Dan,
I would try adding 2 diodes in series instead of adding resistors. The diodes are very small, maybe even smaller than the resistors that you have. They should fit on the circuit board.
Joe Gores
raymondj(at)frontiernet.n
PostPosted: Sat Jun 21, 2014 2:09 pm    Post subject: LED Ghosting Reply with quote
Instead of dimming all the other ones. Can the problem one be replaced
with a brighter one so that in it's lower than maximum light output
mode, which the current one is apparently in, it is the same brightness
as the others?
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
http://forums.matronics.com/viewtopic.php?p=425221#425221
edpav8r(at)yahoo.com
PostPosted: Sat Jun 21, 2014 8:11 pm    Post subject: LED Ghosting Reply with quote
Laying in bed thinking about this and couldn't sleep...
Don, I presume this is because your board has a common trace that feeds dimmer output to all of the cells in the annunciator panel, with each cell separately switched to ground for activation. If so, could you use a razor blade to cut the PCB trace for this "dimmer bus" on either side of the oil pressure cell, install a jumper wire to bypass this cell, then feed the oil pressure cell directly from the MOSFET drain?
Eric
donjohnston
PostPosted: Sun Jun 22, 2014 4:22 am    Post subject: Re: LED Ghosting Reply with quote
Here's (what I think is) the correct circuit. Still not sure I can integrate this into the existing PCB though.
LED circuit 3.pdf
 Filename:  LED circuit 3.pdf
 Filesize:  29.1 KB
 Downloaded:  717 Time(s)
PostPosted: Sun Jun 22, 2014 4:46 am    Post subject: Re: LED Ghosting Reply with quote
Your LED circuit 3.pdf looks correct to me.
Joe Gores
donjohnston
PostPosted: Sun Jun 22, 2014 5:57 am    Post subject: Re: LED Ghosting Reply with quote
Definite improvement! Probably usable. There's a small range where the MOSFET controlled LEDs go out before the others. But it's such a small range that I doubt it's an issue.
Now I have to see if it's a doable mod to the PCB.
rickofudall
PostPosted: Sun Jun 22, 2014 6:07 am    Post subject: LED Ghosting Reply with quote
Paul, IMHO the variance in brightness would be a distraction the pilot would not need to deal with when any of the warning LED's started lighting. Even if you know that brightness is not an issue the difference would draw the eye and the thinking away from the real problem. For that reason I would want uniform brightness, but as I said, it's just my opinion.
Rick Girard
On Thu, Jun 19, 2014 at 3:15 PM, Fisher Paul A. <FisherPaulA(at)johndeere.com (FisherPaulA(at)johndeere.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Fisher Paul A." <FisherPaulA(at)johndeere.com (FisherPaulA(at)johndeere.com)>
I'm confused by this thread.  Back to the original issue - why is it important that all of the LEDs in the annunciator panel have the same brightness?  Don't you just need to know if any particular one is on or off?  Aren't they used to indicate a problem? I would hope that during most flights they would all be off.  And if more than one of them was on, I certainly wouldn't be worried about one being brighter or dimmer than another - I'd be busy looking for a place to land!
I do appreciate the electronics discussion about the physics of getting them to the same brightness.  I just don't understand why that is important in this use case.
Paul A. Fisher
RV7A N18PF
PostPosted: Sun Jun 22, 2014 6:28 am    Post subject: LED Ghosting Reply with quote
Don,
New diagram looked perfect. Glad to hear it works acceptably well. Hope you can bodge it into your PCB for a permanent solution!
Eric
donjohnston
PostPosted: Sun Jun 22, 2014 7:06 am    Post subject: Re: LED Ghosting Reply with quote
edpav8r(at)yahoo.com wrote:
Don,
Eric
Thanks. Looks like I may be able to mod the board (I wish it didn't cost so much to get these small one-off boards made Sad ).
I was worried that I was going to run into the same problem with the LR3C voltage regulator low voltage warning. But B&C apparently did it right. A 1K resistor across the LEDs eliminates the ghosting but doesn't dim the LEDs when on. WooHoo! Very Happy
-Don
PostPosted: Sun Jun 22, 2014 8:05 am    Post subject: LED Ghosting Reply with quote
Your voltage measurements confirmed that the annunciator
output from your engine analyzer is decidedly not capable
of driving an incandescent bulb . . . in fact, it appears
that this particular output is not well thought out. Have
you had any contact with the factory about this? What
brand and model analyzer are we talking about. Are the
installation manuals available on line?
[img]cid:.0[/img]
This is the best alternative for 'buffering' the
output port as it was handed to you. The size of
the resistor still leaves some risk for 'ghosting';
there might be sufficient leakage in their output
to produce a source-gate voltage that is greater than
the threshold voltage on the FET . . . typically
on the order of 2-3 volts.
A resistor on the order of 470 ohms is suggested.
I was worried that I was going to run into the same problem with the LR3C voltage regulator low voltage warning. But B&C apparently did it right. A 1.5K resistor across the LEDs eliminates the ghosting but doesn't dim the LEDs when on. WooHoo! Very Happy
That incandescent lamp driver was designed by yours
truly about 30 years ago for some devices being
offered to Cessna and Beech . . . it got folded into
the B&C products when I did their early designs.
But nobody was driving LEDs back then. Turn-off
resistors had to be added to accomodate the
conversion.
The FET buffer is the obvious 'fix' in this instance
but should not have been necessary.
 Filesize:  16.55 KB
 Viewed:  20906 Time(s)
PostPosted: Sun Jun 22, 2014 8:14 am    Post subject: LED Ghosting Reply with quote
The Perhelion dimmer is linear as opposed to duty-cycle
switched so yes, at some lower voltage, the gate-turn-on voltage
for the FET becomes a significant part of the supply
voltage out of the dimmer and LEDs controlled by the FET
will go out first.
A refinement of the design could consider duty-cycle
switched dimming or going to logic-level gate FET with
a much lower threshold voltage.
This has been an excellent study in the relative chaos
that can arise from poorly tested products. We were
recently discussing how poorly designed tachometer
circuits for sampling ignition signals can add risk
affecting engine performance.
This "ghosting" problem is a case where less than passing
grades on a manufacturer's homework caused a lot of unnecessary
work-arounds that are STILL less than ideal.
donjohnston
PostPosted: Sun Jun 22, 2014 11:08 am    Post subject: Re: LED Ghosting Reply with quote
But... It does work with an incandescent bulb... As long as it's wired to 12v and not a dimmer.
The Engine Analyzer is a Grand Rapids EIS 6000.
Doc's are here:
http://grtavionics.com/manualseis.html
PostPosted: Sun Jun 22, 2014 2:43 pm    Post subject: LED Ghosting Reply with quote
At 02:08 PM 6/22/2014, you wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
??? What size of bulb . . . how many milliamps
does the bulb draw?
The voltages you observed in circuit 2 say
that with JUST the two LEDS and their companion
resistor attached to the engine analyzer, all
measured voltage drops add up to the supply
voltage. This means that for that current level,
the engine analyzer will pull the lamp port
nearly to ground. I believe the resistor was
390 ohms . . . so load on the engine analyzer
in case #1 was 8.07/390 = 20.6 milliamps.
You added a resistor across the array in case
#3 which says that voltage across the 390 ohm
resistor dropped to 6.55 volts . . . so indeed,
current through the lamps went down to 6.55/390
equals 7.2 millimaps . . . approximately 1/3
that of case #1. Further, you cite 10.7 volts
across the 1K resistor for an additional
10.7 milliamps of load on the engine analyzer
lamp port . . . for a total of 17.9 milliamps
which is less than case #1. Yet you LOST some
voltage in the engine analyzer. Total voltage
drop in the lamps and resistor is 10.65 volts
with a system voltage of 12.37 . . . or 1.72
volts went missing in the engine analyzer's
lamp driver. In case #4 we see the same thing
happening . . . with the disappearance of about
1.5 volts.
The output switching device should not have that
much loss . . . I would expect tens of millvolts
tops. The voltages say yes, the LEDs are indeed
biased up significantly lighter when the anti-
ghosting resistor is added. But it's not clear
why.
Doc's are here:
Okay, the warning light output is described thusly:
[img]cid:.0[/img]
The fact that it can 'shut down' automatically implies
some kind of protective 'smarts' on this pin. At the same
time, the rated switching current is more than
adequate to the task of handling either LED or incandescent
lamps . . . although the 'ghosting' phenomenon is not
understood.
Have you talked with GR about this? This still not
making sense.
 Filesize:  66.63 KB
 Viewed:  20891 Time(s)
donjohnston
PostPosted: Sun Jun 22, 2014 3:46 pm    Post subject: Re: LED Ghosting Reply with quote
??? What size of bulb . . . how many milliamps does the bulb draw?
The voltages you observed in circuit 2 say that with JUST the two LEDS and their companion resistor attached to the engine analyzer, all measured voltage drops add up to the supply voltage. This means that for that current level, the engine analyzer will pull the lamp port nearly to ground. I believe the resistor was 390 ohms . . . so load on the engine analyzer in case #1 was 8.07/390 = 20.6 milliamps.
You added a resistor across the array in case #3 which says that voltage across the 390 ohm resistor dropped to 6.55 volts . . . so indeed, current through the lamps went down to 6.55/390 equals 7.2 millimaps . . . approximately 1/3 that of case #1. Further, you cite 10.7 volts across the 1K resistor for an additional 10.7 milliamps of load on the engine analyzer lamp port . . . for a total of 17.9 milliamps which is less than case #1. Yet you LOST some voltage in the engine analyzer. Total voltage drop in the lamps and resistor is 10.65 volts with a system voltage of 12.37 . . . or 1.72 volts went missing in the engine analyzer's lamp driver. In case #4 we see the same thing happening . . . with the disappearance of about 1.5 volts.
The output switching device should not have that much loss . . . I would expect tens of millvolts tops. The voltages say yes, the LEDs are indeed biased up significantly lighter when the anti-ghosting resistor is added. But it's not clear why.
Have you talked with GR about this? This still not making sense.
The bulb I used is a bulb that I got from B&C with the LR3C. I hooked it up just to see if it would behave properly (and it did). If you want, I can check the specs on it.
I can't speak to or dispute the numbers or calculations that you present as that's not my area of expertise. I can only say with certainty what happens when the switch is thrown.
I have spoken to GRT as I mentioned in the original post. They said the alarm output is designed for an incandescent bulb and that to make it work with an LED I would have to put a 1.5K resistor across the LED. Now I didn't explain complex (elaborate, convoluted, bizarre, whatever term you wish to use to describe my annunicator panel) nature of the warning light I had. Only that I was using an LED. They would have assumed that it was a single LED powered by a constant power source.
I appreciate all the help and suggestions from everyone. I wish that this would have been a simple fix but it would seem that something is going on inside the engine analyzer that defies explanation.
-Don
PostPosted: Sun Jun 22, 2014 5:49 pm    Post subject: LED Ghosting Reply with quote
Actually, it's very explainable . . . given all
the facts. Can you give me a name/number at GRT?
donjohnston
PostPosted: Sun Jun 22, 2014 6:47 pm    Post subject: Re: LED Ghosting Reply with quote
Phone number for GRT is on their contact page.
http://www.grtavionics.com/contact.html
I don't recall who I spoke to about this.
PostPosted: Mon Jun 23, 2014 5:27 am    Post subject: Re: LED Ghosting Reply with quote
Don,
Good going getting your project working to your satisfaction.
The readers of this forum would love to see a picture of your finished circuit board and display.
Joe
Joe Gores
donjohnston
PostPosted: Mon Jun 23, 2014 5:59 am    Post subject: Re: LED Ghosting Reply with quote
Details on the annunicator panel are here:
http://www.velocity-xl.com/blog/2013/08/03/13-99-annunicator-panel/
http://www.velocity-xl.com/blog/2013/08/15/13-99-annunicator-panel-3/
Page 4 of 5
